Old 04-04-2011, 01:35 AM   #1
PCOLASHAN
Drives: 2SS
Cup holder lighting DIY
Here is a quick video explaining what I did, hope it helps!
Cup Holder plate: http://cgi.ebay.com/ebaymotors/Camaro-Chrome-Cup-Holder-Insert-2010-_W0QQcmdZViewItemQQhashZitem519357a21dQQitemZ35036 4344861QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccesso ries
LED's: http://www.oznium.com/prewired-surface-mount-led "I used Red LED's, they match
Inferno Orange interior perfectly"
Where to T-tap:
PCOLASHAN is offline   Reply With Quote
Old 04-04-2011, 07:06 AM   #2
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '26 Corvette Stingray
well there would be a lot easier place to tap into.....that is if you want the lights on all the time, and that would be the AUX power (cig lighters). as they are only powered up when the car is on....so as soon as you shut off the car and start to open the door it will go off. Just like like your radio does.
as far as the ABL wires.....it all depends on when your car was made. the early to mid 2010s had a connection on both sides that nothing is connected to, we believe it was originally for the dash abl that GM decided to delete....later models the wiring harrness were changed so its not there. BUT if its there, the connection that is easiest to get at is on the left side, just pop off the fuse panel. in this thread, in the first two posts there are good pictures of the connections you were asking about asnd how to access them.
http://www.camaro5.com/forums/showthread.php?t=40804
Old 04-04-2011, 07:13 AM   #3
TonyNo
TonyNo's Avatar
Drives: 2016 2SS, SW
You can get this in the console at the front, passenger side. X211 (8 position connector), YEL and BLK wires.
TonyNo is offline   Reply With Quote
Old 04-04-2011, 07:52 AM   #4
The Stig
knows 2 facts about ducks
The Stig's Avatar
There is a yellow wire that runs underneath the gauges/where the gauges should be if you don't have them. Tap into that, it's an ABL wire
Click to view my build thread
Old 04-04-2011, 08:16 AM   #5
PCOLASHAN
Drives: 2SS
Sweet, I will have to look for the yellow and black wires. I only want the lights to come on when the ABL comes on. If anyone has any recommendations that will make this mode easier please feel free to pass that good info! Thanks again!!
Old 04-04-2011, 08:41 AM   #6
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
You got the best recommendations from the member, its what you want and will work like you want.
Old 04-04-2011, 09:29 AM   #7
PCOLASHAN
Drives: 2SS
Awesome, thanks guys!!
Old 04-04-2011, 09:35 AM   #8
skuttduck
skuttduck's Avatar
Drives: 2010 RJT 2LT Camaro
Send a message via ICQ to skuttduck Send a message via AIM to skuttduck Send a message via Yahoo to skuttduck
Actually the ABL wire is Purple and Black. The Yellow and Black is the instrument panel lighting.
The difference being that ABL can be shut off when the lighting is dimmed to its lowest level. The Instrument panel can't.
The Traction control switch is a good spot for the yellow/black IP lighting. If you want the feature lighting, you'll want to go under the passenger kick panel, and tap the purple wire there.
skuttduck is offline   Reply With Quote
Old 04-08-2011, 11:20 AM   #9
PCOLASHAN
Drives: 2SS
Since the 4 gauges clusters light up at night like the ABL, I was wondering if anyone knows if I can tap into them? If so, what wires would I tap into?
Old 04-08-2011, 11:27 AM   #10
The Stig
The Stig's Avatar
yes you can. You want to tap into the yellow wire that goes to the gauges.
Old 04-08-2011, 11:40 AM   #11
PCOLASHAN
Drives: 2SS
Great!!!
Old 04-08-2011, 11:41 AM   #12
PCOLASHAN
Drives: 2SS
Do I just ground to the neg of the cig lighter?
Old 04-08-2011, 11:47 AM   #13
PCOLASHAN
Drives: 2SS
Here??
Old 04-08-2011, 12:22 PM   #14
bee sting
bee sting's Avatar
Drives: 1997 30th Ann. Z28 & 2010 2LT RS
Is there a ABL wire in the console area ? I'm also adding cup holder leds but also rear footwell lights. I know I can tap into ABL under the dash like i did for the front footwells but want something closer.
bee sting is offline   Reply With Quote
Installed full dash and doors ABL, foot lighting with custom cup holder switch plate! CamaroC-17 Camaro Photos | Spyshots | Video | Media Gallery 23 02-06-2013 09:45 PM
DIY add light to inside door handle overhaulengines Camaro DIY & HOW-TO instructions & discussions 32 07-21-2011 09:58 PM
DIY custom ABL BlueSteele Camaro DIY & HOW-TO instructions & discussions 5 02-07-2011 01:05 AM
ABL lighting and Footwell Light Install? JProberts USA - Mid-Atlantic 3 02-25-2010 10:17 PM
