Old 06-03-2011, 12:19 PM   #1
Whiteside Customs
Drives: 2011 1lt/rs, 2010 2ss/rs, 2004 GTO
*** The Truth About BC Racing Coilovers and Installation Thread ***
First and foremost, I think it is important to put to bed some of the rumors and present the cold hard facts. BC Racing is one of the largest coilover manufacturers in the world. They are built and engineered in Taiwan. They are also the largest manufacturer of private label coilovers in the world. Simply put, most of the big name suspension companies use BC to produce their coilovers.
Now I understand and agree that we all should buy American products whenever possible. However, in today's world this is becoming increasingly hard to do. Take the Camaro for example. We have a car engineered in Australia and built in Canada using parts from literally all over the world. So with that in mind, what we must concentrate on is getting the best part we possibly can. And let me assure you, BC Racing builds the best coilovers in the world. And that is why the big suspension companies choose to private label with BC rather than produce their own.
Now, on to the install.
1) Out of the box.
2) Measuring the right height. The front measured 26 7/8 and the rear was 28. We are looking for 1 1/4 drop all the way around.
3) Remove top strut bolt with an impact and a 24mm socket. Loosen the top strut bolt while the vehicle is still on the ground, then replace the top bolt finger tight.
4) Lifting car and removing the wheels and tires
Stock setup:
5) Disconnecting brake lines / upper sway endlink / abs sensor
6) Take out clevis bolts
7) Reaching up, loosen the top strut bolt that we left finger tight and the strut assembly will come out.
8) Measuring for right height. Using a dial caliper we measure the distance between the two lock collars. In order to achieve our 1 1/4" drop we adjust to 22mm between the collars. Refer to the BC racing instructions for assembly order. *NOTE* You must remove the bottom metal insulator from the factory strut mount*
9) Reinstall reverse order
10) Repeat for other side.
That's it for the front. Now onto the rear.
12) We choose to loosen the entire cradle for removal of struts. This also gives us a chance to install cradle mount inserts. To remove the cradle washers a large slide hammer works GREAT!
Whiteline Bushings
13) With the cradle dropped down and the strut removed we take the upper strut mount and bolt it back into place for location of the whole we must drill in order to use the dampening adjusters
14) What we chose to do is inside the trunk we used our small drill hole as the locator for a 2" hole saw and drilled a 2" diameter hole for the adjuster. We then found a 2" rubber grommet to protect the edges. We then punched a small hole in the carpet and fed the extenders through. *NOTE* Red loctite on the set screws is a VERY good idea*
15) Now reassemble. In order to achieve our desired drop we measured 30mm between the two lock collars.
*NOTE* NEVER USE AN IMPACT DURING REASSEMBLY. THIS WILL DAMAGE THE STRUT AND VOID YOUR WARRANTY!*
*NOTE* Use a brass drift and hammer on the lock collars to ensure they are tight!
16) The finished product. Test drive vehicle slowly in a parking lot at first and make sure there are no weird noises. Then off to the alignment shop and enjoying your new coilovers!
Whiteside Customs is offline   Reply With Quote
Old 06-05-2011, 05:54 PM   #2
bkscott
bkscott's Avatar
Drives: 2010 Camaro 2SS/RS
I may have to get a test ride in your car. I want to do coilovers, but I am still on the fence about the cost/benefit as opposed to just doing springs. I want to maintain the ride at all cost, and I know Coilovers are best for that. But if the ride does not blow me away I may save the money and do springs instead.
94 Firebird Formula (Drowned 08/30/05)
2010 IBM 2SS/RS 6M Arrived 3/25/10.
ADM CAI, Borla Type S Cat Back, VMAX Ported TB, LG Short Throw Shifter, 1LE Shocks, Hotchkis Sway Bars, Whiteline Cradle Bushing Inserts, Custom Powdercoated ZL1's ,Michelin Pilot Supersports, Stainless Power Headers, Solo J Pipes, AAC LED Sidemarkers, ZL1 Rockers, SLP Splitter, ADM Stage II Cam,ZL1 Diffuser,Vitesse Throttle Controller.
bkscott is offline   Reply With Quote
Old 06-05-2011, 10:44 PM   #3
DMSDesign
Suspension Specialist
Drives: 2011 Camaro
Nice writeup
DMSDesign is offline   Reply With Quote
Old 06-06-2011, 11:02 AM   #4
ipimpthisc
Banned
Drives: @twinturbo, cammed, intrcooled@
Send a message via AIM to ipimpthisc
excellent article and demo... I am impressed thus far
ipimpthisc is offline   Reply With Quote
Old 06-06-2011, 11:29 AM   #5
Whiteside Customs
Barry,
Give me a call. 972 542 0255
Old 06-06-2011, 11:30 AM   #6
Whiteside Customs
Originally Posted by DMSDesign View Post
Nice writeup
Good to see ya hanging around Mike.
How are things treating you?
Old 06-22-2011, 01:52 AM   #7
GreenMonster
Its all about the U
GreenMonster's Avatar
Drives: 2010 SGM
So to be clear with the adjuster thats in the trunk you can adjust the height from there ?? You don't need to remove your wheels every-time you wanna switch height??
GreenMonster is offline   Reply With Quote
Old 06-22-2011, 02:29 AM   #8
MiSTER
Drives: 2010 2SS CGM Camaro, 1988 6.6L IROC
The adjuster is to control the dampening rate of the shock itself (how soft or firm you want the ride to be). It's not an external adjuster for ride height.
MiSTER is offline   Reply With Quote
Old 06-22-2011, 03:45 AM   #9
bkscott
bkscott's Avatar
Originally Posted by Whiteside Customs View Post
Barry,
Just checked back in. Will do.
Old 06-22-2011, 09:58 AM   #10
GreenMonster
Its all about the U
Drives: 2010 SGM
Ok so for height adjustment you would have to take the wheels off right? Sorry I'm a noob on the subject of coil overs ...
Their seems to be a lot of positive things being said on the BC C.O
Old 06-22-2011, 10:33 AM   #11
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
How much for these out the door installed?
[B]
Old 06-22-2011, 12:50 PM   #12
Whiteside Customs
In the front yes. The rear can be done just jack up the rear to get the weight off. For the front it's an access thing. You can't get to the adjusters without the wheels off. The back you can.
I encourage anyone looking into BC coilovers to do research outside of this forum. The GTO guys have had a TON of success with these coilovers.
Remember as well, there's a reason most other companies choose to private label with BC rather than design and build their own!
Old 06-22-2011, 12:52 PM   #13
Whiteside Customs
PM sent.
Old 06-22-2011, 04:18 PM   #14
DallasMike
DallasMike's Avatar
Drives: 2010 2ss/rs, 2004 pontiac gto
We have a special offer for ONE person willing to write a review on these coilovers.
PM me for details.
DallasMike is offline   Reply With Quote
BC Racing Coilovers 2010 Camaro Ultimate Performance | Ship Same Day| Best Price GTD! AutoAgenda Suspension / Chassis / Brakes 220 01-04-2016 01:19 AM
BC Racing BR Type Coilovers Now Available for the 2010+ Camaro! Height+Dampening Adj. AJ@ECSMotorsports Suspension / Chassis / Brakes 73 11-13-2010 04:52 PM
BC Racing coilovers Installed Saving41 Suspension / Brakes / Chassis 6 03-06-2010 11:51 PM
