Old 07-31-2011, 02:34 AM   #1
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
AAC sidemarker lights.......sealed mine.....Video
This is what I did.
The water actually was probably getting in on the corners of the lights and not on the connector more likely. I'd seal them both just in case.
Old 07-31-2011, 02:47 AM   #2
ZNOLMT
ZNOLMT's Avatar
Drives: Rally Yellow 2LT
Is water build-up typical of these side markers? Because I was thinking of getting these.
ZNOLMT is offline   Reply With Quote
Old 07-31-2011, 03:10 AM   #3
PQ
Booooosted.
PQ's Avatar
It's been an issue with some. But AAC has taken good care. Just a pita to have to go through. It's really easy to just run a bean of sealer on them.
Old 07-31-2011, 10:13 AM   #4
GB EB
GB EB's Avatar
Drives: 2014 Stingray 2LT/Z51
OK... I like it... but.... does it void the warranty......
I've got one being replaced under warranty right now for that exact issue...
If I can save the "pita" of sending the next one in when it fails.... It would make me happy.
(ps... maybe you should put an application in at AAC!)
*CAMARO5 CAMARO OF THE WEEK 3/21/11*
*1ST PLACE - NAVAL STATION SAN DIEGO CAR SHOW 4/17/11*
*PEOPLE'S CHOICE AWARD - SAN DIEGO FREEDOM FESTIVAL CAR SHOW 7/4/11*
*TROPHY RECIPIENT - GREATEST SHOW ON TURF 9/11/11*
*1ST PLACE MODERN MUSCLE - CORONADO SPEED FESTIVAL 9/23/11*
*AWARD OF EXCELLENCE - GOOD GUYS DEL MAR FALL NATIONALS 11/27/11*
*1ST PLACE / '82&UP CAMARO/FIREBIRD- FORT WALTON BEACH FF SHOW 2/16/13*
BUILD THREAD: http://www.camaro5.com/forums/showthread.php?t=120353
GB EB is offline   Reply With Quote
Old 07-31-2011, 10:28 AM   #5
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
i have 1 that has multiple burnouts within a month old..aac was quik to send me a warranty claim and i will send back...but i noticed that moisture got inside this 1 and within 24 hrs, led was burned out..could be a coicidnce..but i don,t believe it was...if aac can somehow fix this problem , there time spent handling these claims would dimenish...i have not really looked into where it may leak ..but might pull light today and check out, since its being returned..
mikepage0007 is offline   Reply With Quote
Old 07-31-2011, 10:44 AM   #6
The Stig
knows 2 facts about ducks
The Stig's Avatar
I think its so weird that people keep having issues with these. I've had mine for almost a year and they've been perfect.
Click to view my build thread
Old 07-31-2011, 10:49 AM   #7
GB EB
GB EB's Avatar
buy a lotto ticket
Old 07-31-2011, 11:34 AM   #8
CyberDan
CyberDan's Avatar
Drives: 1SS Camaro
You're just one of the lucky ones... I'm on my third set... And I too noticed the seal around the socket as being the weak link. I plastidipped the back sides of the marker, hopefully that does the trick.
CAI Cold Air Intake, VMax CNC TB, Borla Sport Catback Exhaust, EE Oil Catch Can, Eibach Sway Bars and Drop Springs, AAC concept side markers, stealth signal bulbs, Heritage grille, Sparks Restorations front and rear modern SS emblems
CyberDan is offline   Reply With Quote
Old 07-31-2011, 12:49 PM   #9
mikepage0007
Drives: 2010 camaro
i thought i just had moisture, when removing the 1 , it had at least a spoonful of water in it.. def leaking around the seams...reason i say this ....with bulb still in i could shake /flick light assy in my hand and would get 3-4 drops from corner of light...not from bulb area...did this for 5 minutes and water still came out from same area...not back of light assy where bulb installs..that was dry as bone... imo.. but will seal everything on the next one.
Old 07-31-2011, 02:49 PM   #10
PQ
Booooosted.
PQ's Avatar
I didn't think about it. I don't see why it should.
I did notice that the very corner had little to no sealant. Could swear I could see all the way into the inner chamber. I ran a bead all the way around.
Old 07-31-2011, 04:56 PM   #11
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
Epic. I don't know, maybe I'm old fashioned, but I just don't see why the consumer should have to jerry-rig a $$top dollar$$ product just to make it functional. AAC should re-market these as color-matched sea monkey tanks. Badly painted, bubbly sea monkey tanks.
[B]
Old 07-31-2011, 05:10 PM   #12
PQ
Booooosted.
PQ's Avatar
I won't argue with that.
And, Mike, I just looked REALLY closely at the two bad lights and they both have voids straight to the indside. Both had a ton of water in them. The very corners are where they were not sealed that well.
Old 07-31-2011, 06:26 PM   #13
mikepage0007
Drives: 2010 camaro
thats what i was thinking...some clear non latex silicon would be the best sealant..i would use some blue painters tape and tape out light real good just to make sure it don,t get on finished area
Old 07-31-2011, 06:33 PM   #14
PQ
Booooosted.
PQ's Avatar
Damn. Non-Latex? :(
Crap. Do I need to peel it off and redo it?
