Elite Engineering
Camaro ZL1 Forum - ZL1 Specific Topics Camaro ZL1 specific topics
Old 09-08-2011, 11:20 PM   #1
DarthNacho08
SoCal C5 Family Member
DarthNacho08's Avatar
Drives: 1999 camaro
Send a message via AIM to DarthNacho08
Exclamation NEW Official Details on Camaro ZL1 -- 580hp / 556 lb-ft torque!!
Featured on Camaro5 HOMEPAGE.
GM PRESS RELEASE:
  • Supercharged, 6.2L LSA V-8 delivers 580 horsepower (432 kW) and 556 lb.-ft. of torque (754 Nm)
  • ZL1 power complemented by exclusive Magnetic Ride Control and Performance Traction Management
  • Track-capable standard equipment includes high-performance fuel system, as well as engine, transmission and differential coolers
DETROIT – The 2012 Chevrolet Camaro ZL1’s supercharged 6.2L engine is SAE-rated at 580 horsepower (432 kW) and 556 lb.-ft. of torque (754 Nm) – making it the most-powerful production Camaro ever.
The ZL1’s outstanding power is complemented by advanced powertrain and chassis technologies, including exclusive Performance Traction Management and third-generation Magnetic Ride Control.
“The Camaro ZL1 delivers supercar performance and technology in the sports-car segment,” said Al Oppenheiser, Camaro chief engineer. “For sheer power, the ZL1 delivers more horsepower than a Ferrari 458, more torque than an Aston Martin DB9 V12, and a better power-to-weight ratio than a Porsche 911 Carrera GTS.
“The Camaro ZL1 also features exclusive chassis and traction technologies,” Oppenheiser said, “to offer the best of all worlds – including balanced handling for the track, acceleration for a drag strip, and the comfort of a daily driver.”
The most-powerful production Camaro ever
The 2012 Camaro ZL1’s surpasses the advertised power of the legendary 1969 Camaro ZL1’s 427 cubic-inch big block by more than 150 horsepower (112 kW) – while meeting modern emissions requirements. And, the new ZL1 is backed by General Motors’ five-year / 100,000-mile powertrain warranty.
“The torque is going to make the ZL1 a car you won’t want to get out of,” said John Rydzewski, assistant chief engineer for small block engines. “Not only will the ZL1 have more power and torque than the competition, we’re making it available with an optional automatic transmission, to appeal to a wider group of sports car enthusiasts.”
The all-aluminum LSA supercharged V-8 is part of GM’s legendary small-block engine family. For a solid foundation, the engine’s lower end uses six-bolt main bearing caps that clamp and lock in the forged steel crankshaft to the deep-skirt block. Its 1.9L Roots-style blower uses an efficient four-lob rotor set and compact intercooler to deliver boosted air into the high-flow cylinder heads.
For the Camaro ZL1, the LSA features a unique induction system, with a lower-restriction air filter, dual inlet paths, and improved airflow through the supercharger housing. Other changes include a higher-efficiency supercharger intercooler and electric power steering system, which consumes less engine power than hydraulic-steering systems.
The ZL1 will be offered with either a six-speed manual or automatic transmission. The Tremec TR-6060 “MG9” manual features 30 percent more torque capacity than in the Camaro SS. The higher torque capacity results from a strengthened output shaft, high-strength rear housing, and additional roller bearing. The MG9 has also been tuned for improved shift feel, with a dual-mass flywheel, twin-disc clutch, and triple synchros for smooth, precise shifts.
Similarly, the Hydra-Matic 6L90 automatic has been strengthened to handle the torque and horsepower produced by the 6.2L supercharged small block. The 6L90 features a strengthened input gearset with two additional pinion gears, additional clutch plate, and a strengthened output shaft and gearset. To make the ZL1 perform equally well on street and track, the 6L90 features three distinct drive modes:
  • Drive: The shift pattern is calibrated for optimal fuel economy, including second-gear starts, while the shift feel is tuned for a smooth driving experience. Engaging the tap-shift feature on the steering wheel or shift lever engages temporary manual mode.
  • Sport: The shift pattern is calibrated for more aggressing driving, including first-gear starts for maximum performance. The shift feel is also more aggressive, with a performance algorithm that holds the transmission in lower gears during aggressive driving.
  • Manual: Here, the 6L90 offers the driver true manual control, with no automatic up shifts, and staged upshifts for incredibly fast shifts and maximum performance.
Other track-ready features of the ZL1 include:
  • An engine-oil cooler, identical to the system on the Corvette ZR1. The integral liquid-to-liquid system is so effective that both the manual and automatic transmissions are deemed to be fully track-capable with the standard factory-installed cooling package.
  • A rear-differential cooler, which pumps transmission fluid to a heat exchanger, reduces temperatures in the differential by more than 100 F.
  • A high-performance fuel system delivers fuel to the LSA engine under any performance driving condition. For example, the system features additional fuel pickups on the primary side, and the secondary fuel pickup is moved outboard for continuous fuel access during high-g cornering under low fuel conditions.
Magnetic Ride Control 3.0 adjusts damping 1,000 times per second
The Camaro ZL1 will feature the third-generation of Magnetic Ride Control (MRC).
MRC employs valve-less damping and Magneto-Rheological (MR) fluid technology. MR fluid is a suspension of iron particles in a synthetic fluid. When the system is activated, the particles are magnetized and aligned into fibrous structures, changing flow resistance. By controlling the current to an electromagnetic coil inside the piston of the damper, the system varies the suspension firmness to match the road and driving conditions.
“Traditional suspension systems at some point compromise ride quality for road-holding grip and body control,” said Oppenheiser. “With Magnetic Ride Control, we can offer customers the best of both worlds: A comfortable ride that makes the ZL1 appropriate as a daily driver and the incredibly precise body control that makes the ZL1 so enjoyable on the track.”
For the third-generation, MRC uses new twin-wire/dual-coil dampers at all four corners. The smaller dual-coil system – with one coil at either end of the damper – replaces the larger single-core design of the previous generation.
The new design allows even more precise control of the electrical current (and magnetic flux), allowing greater range between the softest setting for ride comfort and the firmest setting for track driving. The new dual-coil design also enables faster response, with damping levels now adjusted up to 1,000 times per second – about one adjustment per inch of vehicle travel at 60 mph – making the system exceptionally responsive to changing driving and road conditions.
There are three settings for MRC in the ZL1: Tour, Sport, and Track.
Exclusive Performance Traction Management for the race course, and the drag strip
The Camaro ZL1 will also offer Performance Traction Management (PTM) as standard equipment, which is exclusive to General Motors. First introduced on the Corvette ZR1, PTM is an advanced system that integrates magnetic ride control, launch control, traction control and electronic stability control, to enhance performance on the racetrack and drag strip.
For example, the launch control feature (manual transmission only) automatically modulates engine torque for the best possible acceleration without excessive wheel spin. When the driver pushes the throttle to the floor, the system holds a predetermined engine speed until the driver releases the clutch. Then, the system modulates engine torque 100 times per second to maximize the available traction. The system is capable of approaching a skilled driver’s best effort and repeats it consistently.
Similarly, on a road course, the driver can apply full throttle when exiting a corner and PTM will automatically manage acceleration dynamics to maximize exit speed based on available traction.
Five PTM performance levels or modes are available to accommodate the given ambient and track conditions, driver experience/vehicle familiarity and driver comfort levels. They include:
  • Mode 1 – Traction control set for wet conditions, with stability control on and Magnetic Ride Control set on Tour.
  • Mode 2 – Traction control set for dry conditions, with stability control on and Magnetic Ride Control set on Tour.
  • Mode 3 – Traction control set on Sport 1, with stability control on and Magnetic Ride Control set on Sport.
  • Mode 4 – Traction control set on Sport 2, with stability control off and Magnetic Ride Control set on Sport.
  • Mode 5 – Traction control set on Race, with stability control off and Magnetic Ride Control set on Track. Launch control tuned for VHT-prepped drag strips.
“Like the Magnetic Ride Control, the Performance Traction Management system improves the ZL1 experience as a daily driver and on the track,” said Oppenheiser. “By offering five distinct modes of traction management, the driver can select what’s best for them based on their experience and the driving conditions. As a result, novice drivers will find the ZL1 is very enjoyable to drive, while expert drivers will find PTM supplements their driving skill without interfering with their intentions.”
DarthNacho08 is offline   Reply With Quote
Old 09-08-2011, 11:24 PM   #2
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2012 Camaro ZL1
Oh boy........
Look at that thing in silver...........
580 hp is nice, too!
"Keep the faith." - - Read Before You Post.
Old 09-08-2011, 11:27 PM   #3
DarthNacho08
Drives: 1999 camaro
thanks for the title name change dragoneye, I wanted to see how many people would pick up on it without putting zl1 in the title lol
Old 09-08-2011, 11:28 PM   #4
Mr. Wyndham
Well....it was clever....but this was too good to let anyone pass over, imo.
Old 09-08-2011, 11:28 PM   #5
DarthNacho08
Drives: 1999 camaro
just doing my duty as a fellow c5er
Old 09-08-2011, 11:29 PM   #6
Mr. Wyndham
Indeed, Sir! THANK YOU for the heads-up!
EDIT: I popped a link from MotorTrend up there too. They've got a slightly more detailed article written up on the subject!
I imagine GM will have their own press release at some point as well.
Old 09-08-2011, 11:32 PM   #7
hv92
Drives: .
Ok. NOW I am officially excited. It's great that they showed a different pic with the silver. PLEASE do something regarding the automatic shifter.
My name is Jake Huntsey. New YORK NEW YORK!
hv92 is offline   Reply With Quote
Old 09-08-2011, 11:37 PM   #8
NoSyT
It's a Three Six, Vee Six
NoSyT's Avatar
Drives: 2012 Ashen Gray Metallic 2LT/RS
Damn...just Damn that thing is going to be a beast!
NoSyT is offline   Reply With Quote
Old 09-08-2011, 11:37 PM   #9
CallMeWonder
Drives: Mercedes E350
If the 7.24 power to weight ratio is correct and the horsepower is 580 the car comes in at 4199.2 lbs.
Something to discuss perhaps?
2009 E92 M3.
CallMeWonder is offline   Reply With Quote
Old 09-08-2011, 11:39 PM   #10
CallMeWonder
2009 E92 M3.
Old 09-08-2011, 11:40 PM   #11
hv92
Drives: .
Interesting. One thing is for sure though, it's gonna RAPE the gt500.
Old 09-08-2011, 11:40 PM   #12
Mr. Wyndham
MotorTrend claims Chevy didn't give out weight information...I think Jalopnik guessed on that...
Old 09-08-2011, 11:41 PM   #13
CallMeWonder
Yea, I was looking at that...and the fact that they guessed down to the decimal is interesting...
2009 E92 M3.
Old 09-08-2011, 11:41 PM   #14
DarthNacho08
Drives: 1999 camaro
probably guessing that weight based on the cts-v
Old 09-08-2011, 11:43 PM   #15
CallMeWonder
The CTS-V is 7.6.
ZL1 lighter maybe?
2009 E92 M3.
Old 09-08-2011, 11:46 PM   #16
Mr. Wyndham
The CTS-V is 7.6.
ZL1 lighter maybe?
If they just guessed 4200 (CTS-V is 4222), then dividing that by 580 would give you 7.241379310344827586200689....Jalopnik guessed.
EDIT: I'm very interested to know what this "dual inlet induction system" is all about......sounds intriguing.
Old 09-08-2011, 11:49 PM   #17
Kluch
Drives: CTS-V
VERY nice indeed.
Kluch is offline   Reply With Quote
Old 09-08-2011, 11:52 PM   #18
hv92
Drives: .
So pretty much... New intake, tune, and a new pulley will push it up to...650 horsepower???
Old 09-08-2011, 11:59 PM   #19
The IOM Ninja
Drives: 10' IOM 2SS/RS, 13' GB Shelby GT500
The GT500 has a weight of about 3800 without a person in it, the ZL1 is expected to have a weight of at least 4K if not more. I have a feeling the ZL1 will rape the GT500 in the same way a 5.0 Mustang rapes the SS. I give a slight advantage to the Auto ZL1 just because most people that drive manuals (9/10) can't launch to save their lives. Once again only speculation the fact that a Camaro SS can even beat a 5.0 in a drivers race is beyond spectacular.
That being said I have no doubt in my mind that this will be a great car, a GT500 is my next car though. Want something new and the Camaro needs a brother.
If it's anything like the GT500 or the CTS-V (which it will be) then yeah it will be easy to bump up the horsepower
The IOM Ninja is offline   Reply With Quote
Old 09-09-2011, 12:03 AM   #20
brandotron
I am the internets.
brandotron's Avatar
Drives: dangerously
brandotron is offline   Reply With Quote
Old 09-09-2011, 12:11 AM   #21
SIM Curly
SIM Curly's Avatar
Drives: Silver 1LT 2011 camaro
I want the rims!
SIM Curly is offline   Reply With Quote
Old 09-09-2011, 12:14 AM   #22
blufin
blufin's Avatar
Drives: 2010 2SS/RS CGM M6
Very pleased to hear 580. I was honestly hoping for just a little more, but that'll do.
Sport cup tires... Nice.($$$$)
I'm really starting to get excited now!
12.618 @ 110.75 Bone Stock 1/4 mile
8.165 @ 86.52 Bone Stock 1/8 mile
11.189 @ 124.44 on a 1.73 60' TVS2300 3.4 pulley, JRE tuned, Kooks LT headers and HF cats, MBRP catback exhaust, CAI intake, ADM scoop. Stock wheels/tires
blufin is offline   Reply With Quote
Old 09-09-2011, 12:16 AM   #23
Padre
Only drives on Sundays
Padre's Avatar
Drives: 11 2SS/RS, Black/Inferno, L99 A6
The "Heretic": '11 2SS/RS L99 A6 Black/Inferno. Build Journal, Videos, Blog
D1SC GT9 JBA-LT = 720/680 | 10.330 @ 133.61, 1.546 sixty... Camaro King at ECS V, Darlington.
Padre is offline   Reply With Quote
Old 09-09-2011, 12:16 AM   #24
MrDew
MrDew's Avatar
Drives: 2012 ZL1 #165
2.) SO TIRE-SOME! Michelin devised for the ZL1 (and the Corvette line) a new, street legal, driveway-to-track tire — the Pilot Sport Cup Zero Pressure (ZP). They say it's as close to a racing compound you can get for street use, without hydroplaning over a puddle of spilled iced tea.
Who was wondering regarding the micheline cup tires?
How much will that option be since the goodyears are going to be the standard option?
MrDew is offline   Reply With Quote
Old 09-09-2011, 12:17 AM   #25
Mr. Wyndham
How much will that option most likely add since the goodyears are going to be the standard option?
I...think...the Goodyear's may have been a distraction....
I could be wrong...I hope I'm not. But
GT5 Camaro pics brantley847 Camaro Photos | Spyshots | Video | Media Gallery 93 05-27-2013 08:35 PM
Camaro vs Corvette? Dr Jkel Chevy Camaro vs... 71 11-12-2010 01:39 PM
Im sure this has been asked before.. But forgive my innocence :) gmag21 Suspension / Brakes / Chassis 23 02-21-2010 10:29 PM
Torque Converters Explained tbyrne V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 0 01-07-2010 12:38 PM
