11-12-2011, 11:54 AM | #1 |
Psssssssssshhhhhhhhhhhhh!
Drives: under contruction Join Date: Nov 2009
DIY: Make your own cradle bushing inserts.
I am not taking credit for this DIY mod, but I did help tkrupinski with this project, so we are posting this DIY as a joint venture.
Make your own street version cradle bushings. This mod is for someone that needs a cheap alternative to street bushings. 1 Purchase a large tube of self leveling two part seam sealer. Any brand will work fine but I do know that the 3m in the picture below gets very hard and sets up in about 10min. You also need the proper gun and tips to dispense the dual tube material. 2 remove or lower suspension cradle to access the top of the cradle bushings. (If you don't know how, then you'll need to find another DIY to show you how to do this.) 3 Remove dirt and debris from bushing air pockets with compressed air. 4 Apply self leveling seam sealer into the bushing filling the air pockets completely. 5 Wipe off all excess sealer before it starts to harden. Front bushing: Rear bushing: 6 After sealer starts to harden wipe mounting surface with some sort of paint thinner to avoid potential squeaks due to body rub. 7 Let dry one hour then reinstall suspension cradle. |
11-12-2011, 12:17 PM | #2 |
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova Join Date: Oct 2008
That right there is smart, That is Camaro Fabrications at its best.
11-12-2011, 05:40 PM | #3 |
086YN
Drives: Black 2SS/RS Demon of Madness Join Date: Aug 2011
What is the point?
I am missing something. |
11-12-2011, 06:11 PM | #4 |
Drives: Camaro Justice Join Date: Jun 2007
Creative as I have come to expect from D_E.
11-12-2011, 06:29 PM | #5 |
knows 2 facts about ducks
This mod saves you about $250.
11-12-2011, 08:04 PM | #6 |
Drives: COTW 8/29/11 2010 CAMARO Join Date: Jul 2009
looks good, wounder if it has the same effect.. also since its a lot of work to drop the cradle woundnt be best to just change out the bushings..
11-12-2011, 08:11 PM | #7 |
086YN
11-12-2011, 08:13 PM | #8 |
This is from the Pfadt website about using their solid subframe bushings:
With the Pfadt Camaro Solid Subframe bushings you can completely eliminate subframe movement. By solidly mounting the rear subframe you will find that the car feels more precise and reacts to your steering inputs more quickly. Drag racers will find that their launches will be more controlled and wheel hop will be drastically reduced if not eliminated. When launching the car before we found that the subframe would violently oscillate and cause a drastic reduction in traction. Now with the solid subframe mounts the launch is substantially smoother and more controlled. Auto-crossers and road-racers will find that the rear end is more controlled and the car is far more stable and predictable. After the installation of the solid subframe mounts the chassis and subframe are no longer acting as separate structures so the rigidity and strength of the rear subframe and chassis is also improved. This mod should provide similar results for a lot less money. The solid subframe bushings I put in my car cost about $700. This costs less than $50. The street kit inserts from some shops cost about $200. So, yeah, it saves some money. I'm pretty sure you have to drop the cradle to change out the bushings. |
11-12-2011, 08:44 PM | #9 |
Drives: 2010 IOM 1SS M6 Join Date: Jun 2011
Nice DIY DE!
Just want to point out that the title should be DIY Rear cradle bushing INSERTS as this will not perform the same as a solid bushing or a polyurethane replacement. If the seam sealer hardens to roughly the same durometer as the bushing inserts that are on the market, then the same performance could be expected. Oh and BTW dropping the cradle is not that big of a deal. Its easier than removing a solid rear axle. Changing out the entire bushing can be a major pain in the butt, depending on how well the OEM bushings are seated in the cradle. |
11-12-2011, 09:22 PM | #10 | |
We think that this method is even better than the cradle bushing inserts some vendors sell because it completely fills the bushings without there being any seams to make for extra play in the bushings. I've asked a mod to modify the title to make it more accurate. |
11-12-2011, 09:35 PM | #11 |
Drives: 2010 Camaro 1LT/RS M6 Join Date: Nov 2007
Nice Budget Mod!
Trifecta tune, Vararam Intake, VMAX throttle body and manifold insulator, RxPerformance Catch Can, , MRT v1.0 and Louvers, Barton shifter, BMR strut tower brace, RED dome light and Plasma LED DRL's, fieldgoal00's Halo 1 harness, hood spears/side stripes, rain guards, custom bowtie, Team LLT badges, headlight and foglight covers, taillight and side marker covers, backup light covers, WeatherTech floormats
11-13-2011, 01:08 AM | #12 |
It is a good budget mod, but does not come close to the stability a quality sub-frame bush insert will offer. The control surfaces that contact the monocoque are unchanged. The underside of the bushes are not filled. That said it is a step up from the OE deeply NVH voided sub-frame bushes coming close to the new improved OE rubber sub-frame bushes that began coming down the assembly line with the Vert.
I say cool mod and very creative! |
11-13-2011, 06:25 AM | #13 | |
Hugger Orange
Drives: 2010 Hugger Orange 2SS/ RS YSI/4l80 Join Date: May 2010
11-13-2011, 09:59 AM | #14 |
Drives: cars Join Date: May 2011
Similar Threads | ||||
Subframe Bushing Inserts - BMR, Pedders, Prothane, Energy, etc.??? | parietta | Suspension / Brakes / Chassis | 23 | 03-21-2013 08:11 AM |
BMR Launches New Product - 2010+ Camaro Delrin Rear cradle Bushing Kit (BK028) | BMR guy | Suspension / Brakes / Chassis | 3 | 11-07-2011 03:44 PM |
Bmr inserts rear cradle NEW need gone today! | jsharp | Suspension / Chassis / Brakes | 4 | 10-07-2011 04:35 PM |
Detroit Speed vs. Pedders | usmcjlp | Wheels and Tires Talk Sponsored by The Tire Rack | 35 | 07-22-2009 12:14 AM |
