Old 11-16-2011, 01:51 PM   #1
blackswan
blackswan's Avatar
Drives: 2012 2LT/RS
Steering wheel now not straight? Mystery...
2600 miles on the car (don't drive too much per week and mostly on highway cruises) and suddenly - and I mean suddenly, as in wasn't like that the day before - I go for a ride and notice the wheel is tilted clockwise about 10 degrees while going straight. Nothing's changed, I haven't hit anything, etc. Same roads I usually drive, air pressures OK, generally status quo - except all of a sudden the steering wheel isn't true.
Now, we all know it's not like the steering has an elastic component that suddenly gives a little or adjusts. Steering is tight, checked tie rods and they seem good and tight. Bizarre...going into dealer on Friday but thought I'd share. I know, I know... "You hit something!". Nope.
blackswan is offline   Reply With Quote
Old 11-16-2011, 02:18 PM   #2
'11 cyber grey vert
"SHARK" Born Apr.26,2011
'11 cyber grey vert's Avatar
Drives: 2011 CGM 2LT/RS Convertible
same kind of thing happened to mine except counter-clockwise at about
600 miles.I took mine back to dealer, they put their best alignment technician on it and did the work no charge.They told me usually new cars of this nature ie camaros and corvettes will need adjustment after being driven for a while.
'11 cyber grey vert is offline   Reply With Quote
Old 11-16-2011, 02:19 PM   #3
Raptor626
Drives: 2011 Camaro SS Summit White
The 2012's have an electric steering system. If you really didn't hit anything, then something may have gone wrong with the system itself. I'm not sure how an electric steering system functions, but it sounds like you may have a gremlin.
Raptor626 is offline   Reply With Quote
Old 11-16-2011, 02:50 PM   #4
HDDAN
HDDAN's Avatar
Drives: 2010 Camaro 1SS 2007 HD FLSTC
mine has been ****ed CCW about 10 degrees since I got it in 2009.
HDDAN is offline   Reply With Quote
Old 11-16-2011, 02:58 PM   #5
DandD
DandD's Avatar
Drives: 2010 2SS and 2011 LS
Mine is off clockwise. It's in for the winter now but I will be getting a good alignment in the spring, we'll see if they can straighten this matter out, so to speak.
Around here we like baseball, hot dogs, apple pie, and Chevrolet
DandD is offline   Reply With Quote
Old 11-16-2011, 03:04 PM   #6
blackswan
blackswan's Avatar
Drives: 2012 2LT/RS
Oddly reassuring to hear, didn't know the 2012 has electric steering. Will let you know what dealer says, still odd though...
Old 11-16-2011, 03:05 PM   #7
ga0358
ga0358's Avatar
Drives: 2010 ABM LS
Mine too. I was told it was no big deal.....
ga0358 is offline   Reply With Quote
Old 11-17-2011, 03:55 PM   #8
blackswan
blackswan's Avatar
Drives: 2012 2LT/RS
Totally a big deal, can't see how it isn't, esp. when reaching for cruise or radio controls. It was straight for 2500 miles then... bammo, not straight.
BTW: who said the steering is electric, I see and hear hydraulics? Maybe electric assist of some kind?
Old 11-17-2011, 04:05 PM   #9
DangerZL1
Drives: 2023 Black ZL1 Auto
I believe the 2012 ZL1 will have electric assist, but I don't think any other model has it yet. The problem is in the toe setting in the alignment, not the steering system. I'm suprised the problem appears after a few miles, but at least it's an easy fix for the dealer.
DangerZL1 is offline   Reply With Quote
Old 11-17-2011, 04:37 PM   #10
Mach
Mach's Avatar
Drives: White M6 1LT RS
Are you sure the road is completely flat? The wide RS tires will follow the contours of the road. Sometimes being in the right lane of a 4 lane highway will require some left correction to keep the car going straight.
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done!
Mach is offline   Reply With Quote
Old 11-17-2011, 06:06 PM   #11
blackswan
blackswan's Avatar
Drives: 2012 2LT/RS
"Same roads I usually drive, air pressures OK, generally status quo - except all of a sudden the steering wheel isn't true."
Old 11-17-2011, 06:45 PM   #12
Caspers2SSRS
Caspers2SSRS
Drives: Summit White 2010 2SS/RS Camaro
Dang not another thread fixated on the new improvised 2012 "Function over Form" steering wheels............... I've got tell ya though I've had nary a problem with my old 2010-11 unfunctional one and after 30 thousand odd miles, of hill and dells, lump and bump's, its still aligned as straight as a arrow. Hmmmmmmmmmmmmmm............lol
Caspers2SSRS is offline   Reply With Quote
Old 11-17-2011, 06:55 PM   #13
StellarAuto
StellarAuto's Avatar
Drives: 2010 Camaro 2SS
Loose nut behind the wheel? hahah
C][SIGPIC] Going as fast as my accountant will let me!
StellarAuto is offline   Reply With Quote
Old 11-19-2011, 05:24 PM   #14
blackswan
blackswan's Avatar
Drives: 2012 2LT/RS
Funny...no... but how about loose bolts in the rear!
I kid you not, from the factory the dealer has discovered loose bolts in the rear suspension. This explains another symptom of every time I hit a bump, the rear would wiggle. This also explains why this happened "all of a sudden" with the steering wheel going ****eyed over night. The rear alignment went out on the drive the night before and the steering was then compensating for the rear misalignment.
All straight now, handling is much different (honestly, still a little sensitive to the crown in the road, but possibly expected) and much less clunking noises in the rear and NO MORE VIBRATION on the highway either!
Great dealer!
Custom Carbon Fiber/Leather Steering Wheel SS Mike Local Marketplace 3 02-22-2017 12:17 PM
What do all the abbreviations mean? CrzyGamr2 5th Gen Camaro SS LS LT General Discussions 77 12-07-2012 05:34 AM
Ace Custom Steering - Name Your Wheel! SparksAI Interior Parts & Accessories 30 04-13-2011 04:44 PM
Customize Your Steering Wheel In Any Leather & Stitching Colors (Pictures) dsvcustoms Interior Parts & Accessories 4 09-06-2010 01:50 AM
Steering wheel leather cracking!! meliss7567 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 5 09-17-2009 03:13 PM
