Old 01-30-2012, 05:48 PM   #1
twentytwelvebee
twentytwelvebee's Avatar
Drives: 2012/2ss "transformers edition"
DIY:2012 steering wheel bezel removal
so the '12 steering wheel bezel removal is different than the 10/11 models. i did this mod in less than 30 minutes and its not hard at all. Lupe painted mine carbon flash metallic, it turned out perfect.
tools needed:
T15 torx head
pry tool
long allen wrench or similiar to disengage/remove the airbag
start by turning your wheel 180 degrees so that the bottom of the wheel is at the 12 o'clock position. on the back of the steering wheel there are 2 holes that look like key holes. i used a long allen wrench that would fit and there are 2 springs that need to be disengaged to release the airbag. dont forget to disconnect the negative battery cable! pry towards the center of the airbag(direction of arrows)you'll hear a click and the airbag assembly will release. do that to the other side as well.
gently pull out the airbag assembly and let it hang free.
using a pry tool, start at the top and gently pry the trim bezel. work your way around the rest of the bezel and it will come off.
next release the tabs on the electrical connectors and disconnect the steering wheel controls on both sides, they are just clipped in.
using a T15 torx head, remove the 4 nuts that hold the audio controls in.
assembly is reverse.
twentytwelvebee is offline   Reply With Quote
Old 01-30-2012, 07:06 PM   #2
overhaulengines
overhaulengines's Avatar
Drives: Red 2SS/RS M6
hi Jeremy, thanks for sharing and thank you for your business. thanks for the DIY
lupe
overhaulengines is offline   Reply With Quote
Old 01-30-2012, 07:24 PM   #3
StOrM TrOOpEr
TK-421
StOrM TrOOpEr's Avatar
Drives: 2012 2SS/RS Summit White #349
thanx man.. i need this after i get my bezels from lupe
2012 CAMARO 2SS/RS A6 L99, TPW 7-18-2011 FIRST PRODUCTION WEEK 2012 MODEL #349
"LIKE" me on my FACEBOOK page http://www.facebook.com/stormtroopercamaro2ssrs
MY BUILD THREAD: http://www.camaro5.com/forums/showthread.php?t=209482 - COTW 6/25/13
StOrM TrOOpEr is offline   Reply With Quote
Old 01-30-2012, 07:26 PM   #4
twentytwelvebee
i searched everywhere for a how-to. i ended up going to the dealer and they printed me the airbag replacement diagram. i never would have found the 2 holes on the back/bottom of the wheel.
Old 02-03-2012, 12:05 PM   #5
camaros and vettes
Drives: 2010 IBM Camaro 2008 Corvette
Is there one for a 2010?
camaros and vettes is offline   Reply With Quote
Old 02-03-2012, 12:13 PM   #6
The Stig
knows 2 facts about ducks
The Stig's Avatar
Do you mean a DIY on how to remove the trim? Yes, just search for it.
Click to view my build thread
Old 02-04-2012, 11:09 PM   #7
overhaulengines
this shows how to add audio controls, but also how to remove the steering bezels in the process
http://www.camaro5.com/forums/showthread.php?t=73511
lupe
Old 06-23-2012, 11:08 PM   #8
ABB
Transforming BumbleBee
ABB's Avatar
Drives: Bumble-Bee Camaro 2012
Thumbs up
tools needed:
T15 torx head
pry tool
what kind of color did you use, looks pretty cool.
By the way seems like you had a message showing up on the display after u got done. Was it any serious ones like air bag rest or not connected?!!
ABB is offline   Reply With Quote
Old 06-24-2012, 08:04 AM   #9
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Looks like it says window is down or door is ajar
Old 07-06-2012, 09:56 AM   #10
chizzy
chizzy's Avatar
Drives: 2010 Imperial Blue V6 RS
I think it actually says "Open and Close Driver Window" and after you do that a couple times, it'll tell you to do the same with the passenger side. I had the same thing pop up when I was finished installing my scanner. No worries!
chizzy is offline   Reply With Quote
Old 07-06-2012, 05:13 PM   #11
Chef Camaro
Cooking is My Life.
Chef Camaro's Avatar
Drives: 2012 1LS
You're right Chizzy. All it takes is doing like you said or just drive the car out of the garage. I did this removal and painted it white yesterday. I'll try to put up a picture later.
Live to Cook
Cook to Live
My Build Thread
http://www.camaro5.com/forums/showthread.php?t=222338
Chef Camaro is offline   Reply With Quote
Old 07-06-2012, 07:30 PM   #12
Chef Camaro
Cooking is My Life.
Drives: 2012 1LS
Pics
Live to Cook
Cook to Live
My Build Thread
Old 07-27-2012, 03:29 PM   #13
iCamaro
iCamaro's Avatar
Drives: 2012 LT RS Camaro
Please help - hear no clicking when trying to release the airbag
iCamaro is offline   Reply With Quote
Old 09-29-2012, 07:42 PM   #14
ecko04
Drives: Too many to list
Use the muscle.
ecko04 is offline   Reply With Quote
Recommended Tire Sizes for 2010 Camaro Nine Ball Wheels and Tires Talk Sponsored by The Tire Rack 367 04-23-2024 11:22 AM
steering wheel position and M6 kiteman 5th Gen Camaro SS LS LT General Discussions 10 11-29-2011 10:10 PM
Acronyms? KEEP RT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 20 03-11-2011 08:57 PM
steering wheel removal lightner75 5th Gen Camaro SS LS LT General Discussions 3 02-02-2011 12:18 PM
DSV Carbon Fiber Top & Leather Steering Wheel With Silver Stitching (Pictures) dsvcustoms Interior Parts & Accessories 3 08-19-2010 10:54 PM
