Old 02-07-2012, 12:51 PM   #1
ShnOmac
2012 Camaro ZL1 Owners Manual
ZL1 Owner's Manual (PDF)
Download link: http://www.camaro5.com/forums/attach...3&d=1328642737
PERF TRACTION 1 – WET /
ACTIVE HANDLING ON
. Intended for all driver skill levels.
. Wet or damp conditions
only — not intended for use in
heavy rain or standing water.
. StabiliTrak is on and engine
power is reduced based on
conditions.
PERF TRACTION 2 – DRY /
ACTIVE HANDLING ON
. For use by less experienced
drivers or while learning a new
track.
. Dry conditions only.
power is slightly reduced based
on conditions.
PERF TRACTION 3 –
SPORT 1 / ACTIVE
HANDLING ON
. For use by drivers who are
familiar with the track.
. Requires more driving skill than
mode 2.
. StabiliTrak is on and more
engine power is available than in
mode 2.
PERF TRACTION 4 –
SPORT 2 / ACTIVE
HANDLING OFF
modes 2 or 3.
. StabiliTrak is off and available
engine power is available is the
same as mode 3.
PERF TRACTION 5 – RACE /
ACTIVE HANDLING OFF
in other modes.
engine power is available for
maximum cornering speed. for
Use mode 5 for most consistent
performance during drag strip use.
When the TCS/StabiliTrak button is
pressed again, the vehicle exits
PTM mode and the TCS and
StabiliTrak systems are on.
Use Mode 5 for the most consistent
ShnOmac is offline   Reply With Quote
Old 02-07-2012, 01:11 PM   #2
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
I read over the manual last night. Had some nice stuff in it. I like the shift lights in the HUD. I also liked some of the new features of the A6 trans, this thing is gonna be sweet.
Old 02-07-2012, 01:15 PM   #3
ShnOmac
It has lot's of good info in it.... Im really surprised this wasn't made into its own thread! Yall are holding out on eachother....
Old 02-07-2012, 01:17 PM   #4
Uneducated Guess
'12 ZL1 #742
Uneducated Guess's Avatar
Drives: his wife crazy
hey now! I did suggest it get put in the stickies or sub-stickies. not my fault
Uneducated Guess is offline   Reply With Quote
Old 02-07-2012, 01:18 PM   #5
kona
Drives: '12 ZL-1 #106, '10 ZR-1, 07GT-500
Has anyone read about the use of launch control for the manual? My ZR-1 is really simple and I've heard that the ZL-1 is somewhat different....
Scott...
kona is offline   Reply With Quote
Old 02-07-2012, 02:13 PM   #6
ShnOmac
Scott...
"Launch Control is only available
when the following criteria are met:
. Competitive Driving Mode is
selected or any of the PTM
modes are selected.
. The vehicle is not moving.
. The steering wheel is pointing
straight.
. The clutch is pressed and the
vehicle is in first gear.
. The accelerator pedal is rapidly
applied to wide open throttle.
The Launch Control feature will
initially limit engine speed as the
driver rapidly applies the accelerator
pedal to wide open throttle.
A smooth, quick release of the
clutch, while maintaining the fully
pressed accelerator pedal, will
manage wheel slip."
Pg 9-48
Old 02-07-2012, 02:19 PM   #7
69NMYSS
69NMYSS's Avatar
Drives: '69 Camaro SS and '12 ZL1
Yup, UG did suggest it made be sticky when it was posted in intial thread. Gobbs of info in this manual.
69NMYSS is offline   Reply With Quote
Old 02-07-2012, 03:09 PM   #8
kona
modes are selected.
straight.
manage wheel slip."
Pg 9-48
Thanks...I looked for that and missed it, my bad.....the ZR-1 holds the RPM @ 4000 and if you "Power Shift" the engine does not rev beyond that which prevents running into the rev limiter or as in the old days, you wind up with misc parts bouncing off of the pavement....sounds like the ZL-1 is either the same or very similar....can't wait to try it out.....
Thanks, Scott...
Old 02-07-2012, 03:22 PM   #9
Blake_GM
Blake_GM's Avatar
Drives: 2011 Camaro 2SS/RS in IBM
Agreed, really like "format 4" on the HUD . Wonder if it will be possible to do some sort of software upgrade on the standard HUD to include 'format 4'?
2011 Camaro 2SS w/RS, Imperial Blue Metallic - Toy.
CAI Inc. cold air intake, SOLO axle-back with j-pipes, Kooks 1 7/8" long tube headers with Kooks high flow cats, GPI SS2 VVT cam + engine goodies and dyno tuned by Ryan/Dr. L99/GPI.
Blake_GM is offline   Reply With Quote
Old 02-07-2012, 04:53 PM   #10
jazznurse
jazznurse's Avatar
Drives: 2012 ZL1;2011 Cruze
Great link. In the back, it listed a web site for purschasing service manuals. I went on the site, and they aren't available until June, but they can notify you when they're ready if you wish. The cost is $200.00. For me, it will be a worth while investment, because this is the last toy I'm going to buy.
jazznurse is offline   Reply With Quote
Old 02-07-2012, 05:28 PM   #11
mmarx82
mmarx82's Avatar
Drives: '12 ZL1 #1609
I'm gonna talk to my dealer and see if a cant get it thrown into the deal...
Life is too short to drive cars that suck.
My build Thread
mmarx82 is offline   Reply With Quote
Old 02-07-2012, 08:29 PM   #12
JohnZL1
JohnZL1's Avatar
Drives: 2001 Camaro SS
You have to love an owner's manual that plainly references "track events," "drag strip use," and even gives you instructions for bedding brake pads.
I can't wait to see what 580HP feels like on the back straight at VIR!
JohnZL1
2009 Corvette Z06
2001 Camaro SS
JohnZL1 is offline   Reply With Quote
Old 02-07-2012, 09:23 PM   #13
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Great find, guys!!! Already saved!!
Got to love having the manual before you even get the car.
Old 02-07-2012, 09:29 PM   #14
alexcfwu
alexcfwu's Avatar
Drives: 1998 Trans Am
On page 9-37, I wonder under what condition is the first to fourth gear shifting required? I wonder if I could even remember to do that...
alexcfwu is offline   Reply With Quote
PEDDERS SUCCESSFULLY FITS 305s ON ALL 4 CORNERS! Info@PeddersUSA.com Suspension / Brakes / Chassis 467 06-11-2013 09:45 PM
BREAKING: 2012 CAMARO ZL1 - 6.2L LSA Supercharged - 6MT Revealed! Tran Camaro ZL1 Forum - ZL1 Specific Topics 756 05-01-2013 06:22 AM
Jalopnik's 2012 Camaro ZL1 Review Tran Camaro ZL1 Forum - ZL1 Specific Topics 18 01-23-2012 09:07 PM
Great Motortrend Article - GM’s Reuss: Camaro ZL1 “Wait is Worth it,” IOMZL1 Camaro ZL1 Forum - ZL1 Specific Topics 21 10-10-2011 02:32 AM
The DEFINITIVE EXPLANATION OF CAMARO SUSPENSION, ISSUES, AND UPGRADES Info@PeddersUSA.com Suspension / Brakes / Chassis 106 10-19-2009 06:08 PM
