Drives: 2010 Camaro, 2006 Z06 Join Date: Feb 2009
New Pfadt 2012+ Adjustable Front and Rear Sway Bars Package
Everyone knows there are a handful of changes to the suspension of the 2012 Camaro with the introduction of the FE4 and FE5 suspension packages. Here at Pfadt Race Engineering we are just as excited about it as GM and the future owners of 2012 Camaro's are! After modeling the changes to the rear suspension it's clear that with the revised suspension geometry we can now reduce body roll even further than with the previous models for even better street and track performance. This will allow your Camaro to corner flatter and establish an even better overall balance than was possible with previous Camaro sway bar packages. As of right now we are gearing up for production on our new FE4 Sport sway bar package. This new package will feature:
Every car and every driver are just a little bit different, and the ability to tune your sway bar is extremely important to get the most out of a new parts package. The new, longer endlinks that GM has included in the FE4 package provide the perfect opportunity to include an efficient adjustable bar. The prior endlinks were much shorter which means the force from your control arm was not always acting directly on the sway bar due to the high angles of articulation; This new geometry has MUCH smaller articulation angles so each unique position/adjustment is VERY influential on the Camaro's handling. One of the coolest features of the new FE4 Sport sway bar package are the new Quick Switch sway bar ends. The newly designed ends will allow for fast changes to sway bar stiffness without completely removing the endlink, saving you time at the track between runs. Proper fitment is extremely important for proper function as well, and the new Quick Switch ends match the factory bar end shape which cups the bushing material of the endlink. They are precision machined from high quality steel, then welded into the arms for excellent strength over the lifetime of the car. ![]() At Pfadt, we believe in keeping our parts both light and super strong. The FE4 Sport package's hollow bar construction is not only super stiff but also keeps weight to a minimum. The stiffness lost due to the removal of the center material for weight savings is negligible and is added back into the bar with the adjustable feature. Hollow is the strongest and lightest option. Having a front and rear adjustable bar package will give you the best tuning potential. For example when you put on different sized wheels and tires, or make other changes to your car's handling, you can dial back in the performance balance you like. It's important to keep in mind that with the FE4 Sport Package you now have the ability tune the front AND rear adjustable bars. A sway bar package without an adjustable rear bar leaves no room to reestablish handling balance after changing the grip levels with a tire change. Keep an eye out here in this thread and on our website for more updates to this really sweet package as they come available! ![]()
Nice. We always love new toys.
Thanks guys! There will be a really nice improvement over the factory bar with this upgraded package, and the 3 position adjustability will allow our users to dial their systems in how they would like!
That looks sweet, I wish I didnt need to swap control arms in my 2010 SS.
http://www.camaro5.com/forums/showthread.php?t=344754 Summit White 2014 2SS 1LE Recaros, NPP exhaust, Nav 2010 2SS A6 - sold. |
That is an amazing piece of engineering right there! I can't wait to test these bad boys! I really love the adjustment design, looks real easy to adjust. Let us know as soon as they are ready to rock guys
#6 | ||
![]() Quote:
#7 |
Drives: 2011 CG 2SS Join Date: Oct 2009
I must have missed the memo on these LOL...
Looking nice guys ! |
#8 |
#9 |
Definitely Interested!
2012 Camaro 2SS/RS: Black on Black, Hurst
[AAC DRL LED's, AAC LED's for trunk, cabin, license plate, CAI Intake, RX Catch Can, Skip shift eliminator, Pedders Sub-Frame Inserts, Pedders Radius Rod Inserts, Pedders Rack & Pinion Bushing, 1LE front and rear sway bars] |
#10 |
![]() ![]() ![]() Drives: Rally Yellow Camaro+Avalanche Join Date: Dec 2009
Awesome, Pfadt!
Please, please, please make the new front bars work with your existing adjustable endlinks!
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump. CTS-V 6 pistons.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM |
#11 |
#12 |
Drives: 2011 1lt/rs, 2010 2ss/rs, 2004 GTO Join Date: May 2011
Great job guys! Those look really trick!
#13 |
We just thought you guys would like a few progress pictures of how things are coming along. Like us on Facebook for a gallery of 25 product development photos. We think you guys should get a kick out of the last one we're posting here. Keep a close eye on what's peaking behind the pre production sway bar.
![]() ![]() ![]() ![]() What do we have here? ![]()
#14 |
![]() Drives: SW 2SS/RS M6 Join Date: Jul 2009
Subscribed, neat setup....
| Kill The Factory Understeer With Pfadt Sport Sway Bars From Apex Motorsports!!! | Apex Motorsports | Suspension / Chassis / Brakes | 185 | 08-11-2012 06:29 AM |
| Whiteline 10+ Chevrolet Camaro Front Heavy Duty Adjustable 27mm Swaybar Fits Models L | Xplosive Performance | Suspension / Chassis / Brakes | 14 | 12-18-2011 11:21 AM |
| Better Handling | Tbanks | Suspension / Brakes / Chassis | 30 | 12-15-2010 12:50 PM |
| Im sure this has been asked before.. But forgive my innocence :) | gmag21 | Suspension / Brakes / Chassis | 23 | 02-21-2010 11:29 PM |
| Pfadt Springs and Sway Bars In Stock! *Package Deal*! | PfadtRacing | Suspension / Chassis / Brakes | 0 | 10-14-2009 06:41 PM |
