Old 02-26-2012, 12:04 AM   #1
saddler116
Drives: 2012 Chevy Camaro 1LS
2012 Camaro 1Ls V6 0 to 60 time???
Anyone have an idea or website that shows the official time for the Camaro v6 manual? Please help!
saddler116 is offline   Reply With Quote
Old 02-26-2012, 12:11 AM   #2
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
I could be wrong but I think it's 6 seconds if you shift right and so on
Old 02-26-2012, 12:15 AM   #3
hightower
LS3 Black Widow
hightower's Avatar
Drives: 2012 45th 2SS LS3 and 1968 Mustang
yep, 6.1 seconds give or take depending on your driving skill.
"Initial performance numbers from Chevy indicate that the V-6 Camaro will move from 0-to-60 in 6.1 sec., although they're aiming to get it to 5.9 or so. The quarter mile comes in roughly 14.2 sec. at 98 mph"
Read more: http://www.motortrend.com/features/a...#ixzz1nShWDvI6
And yes that's the 2010 camaro. I doubt the 2012 suspension change affects that much.
hightower is offline   Reply With Quote
Old 02-26-2012, 02:28 AM   #4
SoCalCamaro93
SoCalCamaro93's Avatar
Drives: 2016 2SS, 2011 RS (past)
Download the app carbuzz if you have an apple product. they have they specs on just about any car you can think of.
Past: 2011 RS, 2013 ZL1
Current: 2016 2SS
SoCalCamaro93 is offline   Reply With Quote
Old 02-26-2012, 01:09 PM   #5
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
Suspension is the same on the 2012 V6's (SS gets the new FE4 suspension), but the LFX V6 engine makes 11 hp more than the LLT in the 2010s & '11s.
The 2012's might be a bit quicker than the older cars, but I wouldn't expect anymore than a tenth in the 1/4 so 0-60 should be more or less the same.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 02-26-2012, 02:30 PM   #6
KMPrenger
KMPrenger's Avatar
Since your driving an LS with heavier rims and less sticky tires its hard to say exactly what your car is capable off, but the 2010 auto RS has been tested to do 6 seconds stock and the 2010 synergy with 19" Pirellis has done a 5.6 stock (per Motortrend).
With a perfect run, you might be able to get a tad below 6.
Old 02-26-2012, 04:53 PM   #7
hightower
LS3 Black Widow
hightower's Avatar
Ohhhh, ok gotcha. Thanks for the new info!
I think you're right, it probably has a small edge over the 2010 and 2011s.
Old 02-26-2012, 05:09 PM   #8
meissen
Founder - Michigan FBody
meissen's Avatar
Drives: 1994 Camaro LT1, 2012 Camaro 2SS/RS
According to the wiki, the 2012 lost 20lbs too.
2012 Camaro 2SS/RS L99 - "Zooma"
1994 Camaro LT1 A4 - "Red Alert" - v6-to-LT1 Swapped Cruiser; Cammed, Stalled, Enjoyed
"Gone But Not Forgotten"
2016 Camaro 1LT A8 - "Elmo"
2014 Camaro 1LT M6 - "Cherry Bomb"
2012 Camaro 1LS M6 - "Clifford"
Michigan FBody Association
http://www.mifbody.com/
meissen is offline   Reply With Quote
Old 02-26-2012, 09:49 PM   #9
BlueSteele
BlueSteele's Avatar
Drives: 2010 Camaro
Has anyone done a comparison to see if the 2012 LFX is faster than the LLT stock vs. stock? I know the torque hasn't changed but just wondering if there is any increase in performance?
BlueSteele is offline   Reply With Quote
Old 02-26-2012, 11:12 PM   #10
DGthe3
Moderator.ca
DGthe3's Avatar
Peak torque is the same, but the LFX has a bit broader torque curve and hits its peak a little bit sooner (4800 rpm vs 5200 I think). So it makes a little more power from mid-range all the way up to its redline
Old 07-23-2013, 07:43 PM   #11
chicagojoe12
chicagojoe12's Avatar
Drives: 2013 Summit White 2LS
I'm curious I have a 2013 LS with the 20" wheels and 1.25 lowering springs would any of those things makes a difference?
chicagojoe12 is offline   Reply With Quote
Old 07-24-2013, 10:26 PM   #12
tbis
tbis's Avatar
Drives: 2016 1SS Summit White
18s are lighter generally so 20s are slower. The alloy 20s would be better than 18 ls steelies but if u had 18 in alloys you would go faster. Lowering would help cut a cleaner path through the air. All super fast cars are low to the ground. A raised car is less aerodynamic
Sent from my Nexus 10 using Tapatalk HD
[SIZE="100"]
tbis is offline   Reply With Quote
Old 07-24-2013, 11:39 PM   #13
Ir0nM4n
Love me some Tacos
Ir0nM4n's Avatar
Drives: 14 1LE
I weighed the 18" steel wheels, tire and rim 63 lbs.
Ir0nM4n is offline   Reply With Quote
Old 07-24-2013, 11:44 PM   #14
Scooter11
Scooter11's Avatar
Drives: 2013 SW 2LS
I thought the LLT made 304 horsepower, and the LFX makes 323 (or at least my 2013 does)? If so that's a 19 horsepower increase...
Scooter11 is offline   Reply With Quote
Jalopnik's 2012 Camaro ZL1 Review Tran Camaro ZL1 Forum - ZL1 Specific Topics 18 01-23-2012 10:07 PM
