#1 | |
Founder - Michigan FBody
Drives: 1994 Camaro LT1, 2012 Camaro 2SS/RS Join Date: Jun 2008
In lieu of the v6 forum being broken up into LLT and LFX sections, it only makes sense to have our own Dyno #s thread here.
Stealing from the LLT thread (credit to bmorecam's original thread) To add your dyno times, please do so in the following format: Type and make of dyno: (ex. dynojet model 248x, mustang, etc.) ODO at the time of the dyno: Temperature: Manual/auto: Gear used(3rd or 4th): Modification: Correction used(STD or SAE): Result: Here's our spreadsheet for keeping track: https://docs.google.com/spreadsheet/...=0&output=html More information from bmorecam in the LLT forum's dyno thread: Quote:
Here's an example of the format to post: Type and make of dyno: DynoJet (unsure of model) ODO at the time of the dyno: 9,995 Temperature: 82* Manual/auto: Manual 6-speed Gear used(3rd or 4th): 3rd gear, 4th was hitting the speed limiter Modifications: Cold Air Inductions' cold air intake and RX catch can. Otherwise stock. Correction used(STD or SAE): SAE Result: 270 hp / 232 tq
2012 Camaro 2SS/RS L99 - "Zooma"
1994 Camaro LT1 A4 - "Red Alert" - v6-to-LT1 Swapped Cruiser; Cammed, Stalled, Enjoyed "Gone But Not Forgotten" 2016 Camaro 1LT A8 - "Elmo" 2014 Camaro 1LT M6 - "Cherry Bomb" 2012 Camaro 1LS M6 - "Clifford" Michigan FBody Association http://www.mifbody.com/ |
Boosted
Drives: 2012 1LT RS... with snails Join Date: May 2012
I just got my numbers today
Type and make of dyno: DynoJet 248E ODO at the time of the dyno: 20,510 Temperature: 89.5* Manual/auto: Auto Gear used(3rd or 4th): 3rd gear Modifications: Cold Air Inductions cold air intake, V Max ported throttle body, Corsa cat back exhaust. Correction used(STD or SAE): SAE Result: 277 hp / 239 tq
IPS Twin Turbos, Corsa Exhaust, Ported Throttle Body. 461 rwhp 443 rwtq!! *Cameron Hass.ani* |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
Thanks for posting, really expected you to have slightly higher numbers since
Meissen had 270hp with cai only. 87 octane?
Sold 2012 2LT RS 12.3@112 old setup
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
Boosted
yeah me too. I was hoping for at least 280. He has less loses with a manual.
So the exhaust gave you around 4hp based on the original tb tester got 273 with cai and tb.
#6 |
Boosted
I guess so. I believe corsa stated like 6 hp, buuttt I could being pulling that number out my a**.
#7 |
Boosted
as for octane I had a bit under a half of tank of 87 and I filled with 91 the day before.
#8 |
Wonder if the 87 hurt your numbers. Maybe the ecm retarded the timing cause it still recognized 87
#9 |
Boosted
not sure. I tried to burn that tank of 87 out and I just couldnt do it.
#10 |
Jegs back ordered my exhaust a couple weeks but hope to have soon and will do dyno. Want numbers before doing a tune.
#11 |
Boosted
I'm debating the tune now. Actually was just looking at the JRE page. I can't just leave my car alone
. I'll dyno it again if I tune it. For $75 I got 5 pulls. I'd love to just skip all the little stuff and get some FI!
#12 |
I have been looking at the IPF and Triffecta Tunes? IPF claims 10% increase, so i would like to see some dyno results showing that.
#13 |
Boosted
Everyone seems to love their triffecta. I was going to look into that too. I'd need to see the numbers too.
#14 |
COTW 5/06/2013
Drives: 2017 Corvette Grand Sport-Ho-Vette Join Date: May 2012
Stock 2012 LFX LS 6sp manual
Type and make of dyno: Land & Sea “Dyno-mite” 24″ roller dyno ODO at the time of the dyno:4000 Temperature:90 Manual/auto:M Gear used(3rd or 4th):3rd Modification:none Correction used(STD or SAE):SAE Result:284.8 hp / torque clost to 246 at peak
