Old 08-17-2012, 06:50 PM   #1
StOrM TrOOpEr
TK-421
StOrM TrOOpEr's Avatar
Drives: 2012 2SS/RS Summit White #349
DIY: HOW TO REMOVE A/C VENT BEZELS ON 2012-UP CAMARO
so i found a way to take out the A/C vent bezels for the 2012-UP CAMARO (with the help of Chris81106 and stieger)
NOTE: THE CENTER A/C VENT BEZELS IS ONLY FOR 2012-UP. FOR 2010-2011 MODELS, YOU HAVE TO REMOVE THE WHOLE DASH
tools:
trim removal tool
7mm ratchet
for the 2 circle side vents, basically you can pop off the side of the dash, like you were going to access the fuse box. there are THREE 7mm bolts that hold the vent in place. undo those screws and just pull the plastic vent and the pop the bezel out.
for the center a/c vent, first pull out the long dash strip using the trim removal tool. then remove the FIVE 7mm bolts underneath it.
next lift the shifter bezel (piece with the tray/gauges) out of the way using the trim removal tool. then remove the TWO 7mm bolts underneath radio. then pop off the radio bezel using a trim removal tool.
heres a video on how to remove the radio bezel:
then, pop off leather trim section using the trim removal tool and the unbolt SEVEN 7mm bolts from the A/C vent. next, unclip the bezel from the vent.
once done painting, reinstall in reverse order.
2012 CAMARO 2SS/RS A6 L99, TPW 7-18-2011 FIRST PRODUCTION WEEK 2012 MODEL #349
"LIKE" me on my FACEBOOK page http://www.facebook.com/stormtroopercamaro2ssrs
MY BUILD THREAD: http://www.camaro5.com/forums/showthread.php?t=209482 - COTW 6/25/13
StOrM TrOOpEr is offline   Reply With Quote
Old 08-18-2012, 02:41 AM   #2
iCamaro
iCamaro's Avatar
Drives: 2012 LT RS Camaro
Great DIY! Well done!
iCamaro is offline   Reply With Quote
Old 08-18-2012, 09:27 AM   #3
MikeMoach
MikeMoach's Avatar
Drives: 2010 RJT 2SS/RS
Would you know if it's similar on the 2010s?
MikeMoach is offline   Reply With Quote
Old 08-18-2012, 09:44 AM   #4
The Stig
knows 2 facts about ducks
The Stig's Avatar
It's the exact same procedure on 2010's and 2011's - except that we can't remove the center A/C bezel.
Click to view my build thread
Old 08-18-2012, 09:59 AM   #5
MikeMoach
MikeMoach's Avatar
that's the most important one!!!
Could of sworn I saw someone take that bezel off, thanks stieger
Old 08-18-2012, 10:18 AM   #6
The Stig
The Stig's Avatar
I mean it is removable, you just need to remove the whole dash. I said screw it and just hand painted mine. It's not perfect, but it's better than the OEM silver.
Old 08-18-2012, 10:34 AM   #7
AKA-22
AKA-22's Avatar
Drives: ELLE-1
bookmark
AKA-22 is offline   Reply With Quote
Old 08-18-2012, 10:51 AM   #8
MikeMoach
MikeMoach's Avatar
I'm definitely not removing the whole dash for a 6" wide piece of plastic
I can't hand paint mine cause of the metallic flake, but I'm gunna try and figure something out... I hope
Old 08-18-2012, 12:10 PM   #9
MikeMoach
MikeMoach's Avatar
Stieger is it possible just to unclip part of the dash near the center vent and reach behind and take the bezel off?
Old 08-18-2012, 12:26 PM   #10
The Stig
The Stig's Avatar
Don't think so though. To remove the bezel you have to pull it backwards (so further into the dash), as you can't remove it by going out the hole in the dash. If that makes sense.
Old 08-18-2012, 12:33 PM   #11
MikeMoach
MikeMoach's Avatar
What I'm Gunna try and do its removing the trim above (to paint), from there I was Gunna try and pry open just the part of the dash around that center vent, if I can get enough room to reach my hand behind to remove that piece, is there a DIY for removing the dash? Or is it just clips like everything else?
Old 08-18-2012, 01:25 PM   #12
The Stig
The Stig's Avatar
I personally wouldn't try that, you're just asking for something to go wrong and your dash be screwed up. While I don't know of any DIY I'm sure 2SSRS could explain to you how to remove it.
Old 08-18-2012, 02:54 PM   #13
MikeMoach
MikeMoach's Avatar
Just took apart my driver side vent, there is a fourth screw holding the vent itself in on the backside so you can not completely take it out but you can pry the bezel out not too hard so you don't snap anything
Starting to understand what your saying :(
Old 05-15-2013, 12:27 PM   #14
Jalberdi99
Jalberdi99's Avatar
Drives: 2014 Summit White 2SS/RS M6
how do you remove the plastic dash trim? i can find any info on this.
Jalberdi99 is offline   Reply With Quote
2012 camaro, ac vent, bezels, diy
