Old 08-27-2013, 11:02 AM   #1
fbodfather
fbodfather's Avatar
2013 & 2014 & 2015 1LE Build Counts........
Model Options Color Count
1ES37 &1LE&1SS(1SA) GBA Black 78
1ES37 &1LE&1SS(1SA) GCN Victory Red 76
1ES37 &1LE&1SS(1SA) GAZ Summit White 72
1ES37 &1LE&1SS(1SA) GAN Silver Ice 44
1ES37 &1LE&1SS(1SA) GCO Rally Yellow 28
1ES37 &1LE&1SS(1SA) GCR Inferno Orange 32
1ES37 &1LE&1SS(1SA) GXH Blue Ray 20
1ES37 &1LE&1SS(1SA) GLJ Ashen Gray 43
1ES37 &1LE&1SS(1SA) GBE Crystal Red 20
1ES37 &1LE&1SS(1SA) All 413
1ES37 &1LE&2SS(1SB) GBA Black 451
1ES37 &1LE&2SS(1SB) GCN Victory Red 240
1ES37 &1LE&2SS(1SB) GAZ Summit White 221
1ES37 &1LE&2SS(1SB) GAN Silver Ice 47
1ES37 &1LE&2SS(1SB) GCO Rally Yellow 64
1ES37 &1LE&2SS(1SB) GCR Inferno Orange 95
1ES37 &1LE&2SS(1SB) GXH Blue Ray 70
1ES37 &1LE&2SS(1SB) GLJ Ashen Gray 139
1ES37 &1LE&2SS(1SB) GBE Crystal Red 86
1ES37 &1LE&2SS(1SB) All 1413
Old 08-27-2013, 11:04 AM   #2
RB913
RB913's Avatar
Drives: 2014 2SS/RS 1LE
2014 & 2015 1LE Counts
2014 Official 1LE Specs
Wheelbase112.3Length190.4Height54.2Front Track63.7Rear Track63.7Head Room, Front37.40Head Room, Rear35.30Shoulder Room, Front56.90Shoulder Room, Rear42.50Leg Room, Front42.40Leg Room, Rear29.90Weight3860 pound SS Coupe Manual TransWeight distribution52/48Compression ratio10.7:1 LS3HP 426(318) @ 5900 SAE certified ( LS3 )Torque 420(569) @ 4600 SAE certified (LS3 )Displacement376/6162 Maximum Engine Speed (RPM) 6600 (LS3)
Exhaust - Cast stainless steel (exhaust manifolds), stainless steel with active valves and quad 3.5" bright tips
2014 1LE COUPE TOTAL PRODUCTION
  • Assembly Oshawa, Ontario Canada
  • Total 1LE Performance Package: 2,468
    • Memo: w/1SS Package: 676
    • Memo: w/2SS Package: 1,792
2014 1LE PRODUCTION NUMBERSCOLORUSACanadaCountCrystal Red (GBE)
92
5
97White (GAZ)
533
44
577Red Hot (G7C)
309
18
327Ashen Gray (GLJ)
220
21
241Blue Ray (GXH)
104
16
120Yellow (G7D)
128
11
139Black (GBA)
627
63
690Red Rock (G7P)
136
12
148Silver (GAN)
122
7
129Totals: 22711972468
2014 COLORS
  • Black
  • Ashen Gray
  • Blue Ray Metallic
  • Red Rock Metallic ( New for 2014 )
  • Bright Yellow ( New for 2014 )
  • Silver Ice Metallic
  • Summit White
  • Red Hot ( New for 2014 )
  • Crystal Red Tintcoat
WHEEL OPTIONS
1LE offers 20-inch wheels for the 2014 model year and engineered to the highest standards.
Standard 10-spoke wheel is black with a low-gloss clear coat, forged alum and has the CAMARO logo. These wheels are 11 lbs. lighter than the current 2SS model wheels.
EXTERIOR/TRANSMISSION/INTERIOR
Exterior:
  • Forged aluminum wheels ( as listed above )
  • Power Sunroof ( option )
  • Matte Black Hood, front splitter and rear spoiler ( standard )
  • RS package ( option on 1SS & 2SS models )
  • Ground effects package ( optional )
  • Satin nickel fuel door ( optional )
  • Red brembo brake calipers, 4 piston system ( standard )
  • Dual mode exhaust ( optional )
  • Electric power steering ( standard on 2014 SS models )
  • 2014 Production version camaro 1LE will have center hood heat vent with satin black hood wrap
  • Recaro Seating ( optional ) (New for 2014)
  • 2014 Chevy Camaro 1LE, which features a new, more-streamlined front fascia, hood and heat extractor that also moves air to help create down force. The reworked rear fascia has all new trunk-lid, spoiler, tail lamps and lower fascia. It is believed the 1LE will have a collectability standard and will be low in production numbers. This in turn will make the Camaro 1LE a prized vehicle in the years to come.
  • 2014 has some small enhancements to the Camaro's front and rear alter the overall look substantially. Chevy worked on enhancing the car's aerodynamics by reshaping the front end. The upper grille is narrower while the lower grille is larger. But overall length, width and height all remain the same as before.
  • In back, the taillights are the most striking change; they go from a blocky design to one that is razor thin. These lights were the previous car's most talked about attribute because they were mimicked on other Chevy models.
Transmission:
  • Six speed manual is standard
  • No Automatic transmission for Camaro 1LE
  • Tremec TR6060 Six speed Manual SS with 1LE Package
  • First: 2.66
  • Second: 1.78
  • Third: 1.30
  • Fourth: 1.00
  • Fifth: 0.74
  • Sixth: 0.50
  • Reverse: 2.90
  • Final drive ratio: 3.91
Interior:
  • Suede-microfiber wrapped steering wheel and shift knob - ( standard )
  • Audio system 7" inch diagonal color touch screen display - ( standard )
  • Navigation integration on 7"inch touch screen mylink ( optional )
  • Embroidered center console lid , requires RS package ( optional )
  • Illuminated foot-wells ( optional )
  • Rear vision package ( standard on 2SS 1LE's )
  • Premium audio system ( standard on 2SS 1LE's )
OTHER DETAILS:
  • Four-pack auxiliary gauges
  • 6-way power driver and passenger seats
  • Bluetooth for select phones
  • Boston Acoustics premium nine-speaker system
  • Rear camera display on " 7inch touch screen dash for 2014
  • Rear park assist
  • USB port
  • PDIM (Preferred Device Interface Module)
  • XM Satellite with 3 trial months
Changes to optimize the 1LE for track-day use include:
  • Larger, 27-mm solid front stabilizer bar, and 28-mm solid rear stabilizer bar for awesome body control
  • Higher-capacity rear-axle half shafts to help with increased horsepower levels of traction
  • Strut tower brace for improved steering and response
  • ZL1-inspired 20 x 10-inch front and 20 x 10-inch aluminum wheels
  • 285/35ZR20 Goodyear Eagle Supercar G:2 tires front and rear ( same as the front tires for ZL1 )
  • ZL1 wheel bearings, toe links and rear shock mounts for track performance
  • ZL1 high-capacity fuel pump and additional fuel pickups for fuel delivery during high-load cornering.
1LE Part Numbers:
  • Strut Tower Brace (LT, SS, 1LE) - 22756880
  • Wheel Hubs (ZL1, 1LE) (4) - 25954415
  • Front Coil Spring (SS, 1LE) (2) - 92245257
  • Front Strut (1LE) (passenger side) - 22812984
  • Front Strut (1LE) (driver side) - 22812985
  • Front Sway Bar (1LE) - 22812946
  • Front Sway End Link (SS, ZL1, 1LE) (passenger side) - 22842515
  • Front Sway End Link (SS, ZL1, 1LE) (driver side) - 22842516
  • Rear Shock Mount (ZL1, 1LE) (passenger side upper) - 22836734
  • Rear Shock Mount (ZL1, 1LE) (driver side upper) - 22836727
  • Rear Coil Spring (SS, 1LE) (2) - 92195466
  • Rear Shocks (1LE) (2) - 23115372
  • Rear Sway Bar (ZL1, 1LE) - 22786260
  • Rear Sway Bar Endlink (SS, ZL1, 1LE) (2) - 22761221
  • Rear Lower Control Arm (SS, ZL1, 1LE) (2) - 20942237 (Needed for 2010-2011 car conversion)
  • Rear Toe Link (ZL1, 1LE) (2) - 22845487
  • 3.91 Gears only ( 1LE ) - 22813040
  • Hood (SS 1LE) - 22972003
  • Deflector , Hood Air (SS 1LE) - 23213078
  • Spoiler (SS 1LE RS PKG) - 23436342
  • Tail Lamp (LED RS PKG) - 23209712, 23256982
  • High mount Stop - 23172447
  • Rear Fascia lower without NPP - 22829476
  • Rear Fascia upper with backup sensors - 23164145
  • Tail Lamp Non RS PKG - 23489170, 23489171
  • Rear Fascia lower with dual mode - 22829477
  • Rear Fascia upper no backup sensors - 23164146
  • Front Fascia with RS PKG - 22997721
  • Front Fascia without RS PKG - 22997719
  • Grille Front upper without RS PKG - 22829516
  • Headlamp without RS PKG - 23187850, 23446648
  • Headlamp with RS PKG HID HALO - 23187857, 23187856
  • Emblem Front Grille - 22831295
  • Bracket Front License Plate - 22833651
  • Plate Front Grille EMB BKG with RS PKG - 22829512, 22829506
  • Plate Front Grille EMB BKG without RS PKG - 22829511, 22829505
  • Scoop, Hood Air Black - 22828242
  • Front Fog Lamp - 22830038
  • Front Fog Bezel - LH-22829542--RH-22829543
  • Front Upper Grille Chrome Trim RS PKG - CTR-22829525--RH - 22847642--LH - 22847641
  • Wheels 20x10 Black ( ZL1-1LE ) - 22798741
  • Wheels 20x11 Black ( ZL1-1LE ) - 22798743
  • SS/1LE with 1SS with black interior, so these are black "NON" heated seat cover numbers.
  • Bottom drivers side - 23127746
  • Back drivers side - 23127745
  • Bottom passenger side - 23128319
  • Back passenger side - *No part number listed yet*
  • SS/1LE with 2SS with Black heated Recaros
  • Bottom drivers side cover - 23128297 - List is $876.73
  • Back drivers side cover - 23128291 - List is $1,317.85
  • Bottom passenger side cover - 23128315 - List is $876.73
  • Back passenger side cover - 23128308 - List is $1,317.85
2014 1LE VIN DECODER
2CanadaGGeneral Motors1Passenger CarFCamaro (Fbody )SS = 1SS 1LE Manual | T= 2SS 1LE Manual | K= SS Auto No 1LE in Auto Trans (Note: 1LEs may either come with a T or an S in the VIN to designate manual transmission)137 - Coupe 2 - Door NotchbackERestraint SystemWEngine Type - LS3/ J= L99 No 1LE's in L999Check Digit ( Could be 1-Thru-9 Digit )EModel Year E=20149Plant Location - Oshawa #11 3 8 4Vehicle Sequence # 9 5
Black Hood Wrap Replacements
Original Wraps at: 1-866-944-9727
Hood Wrap Care on Camaro 1LE
The 1LE package features a matte black hood graphic manufactured and warranted by 3M. To maintain the appearance of the graphic, hand washing or a touch-less car wash is recommended.
Tip: Do NOT polish or wax the graphic. Using polish, wax or any solvent-containing products will discolor the graphic. The hood wrap on this vehicle is not a GM warranty part. Owners are directed to contact their dealer for any warranty claims. The warranty form for this graphic is included in the glove box of the vehicle. Dealers are to arrange an assessment of the claim with 3M.
I apologize as the production numbers didn't copy well.
Here they are again.
Crystal Red (GBE) US - 92, Canada - 5, Total 97;
White (GAZ) US - 533, Canada - 44, Total 577;
Red Hot (G7C) US -309, Canada 18, Total 327;
Ashen Gray (GLJ) US - 220, Canada - 21, Total 241;
Blue Ray (GXH) US - 104, Canada - 16, Total 120;
Bright Yellow (G7D) US - 128, Canada 11, Total 139;
Black (GBA) US - 627, Canada 63, Total 690;
Red Rock (G7P) US - 136, Canada 12, Total 148;
Silver (GAN) US - 122, Canada 7 Total 129.
US TOTALS - 2271
CANADA TOTALS - 197
TOTAL PRODUCTION - 2468
__________________________________________________ _________________________
2015 Build Counts
RB913 is offline   Reply With Quote
Old 08-27-2013, 11:05 AM   #3
right to travel
Drives: 2013 Camaro 1SS 1LE SW
so are we over or under 2%?
right to travel is offline   Reply With Quote
Old 08-27-2013, 11:07 AM   #4
PYROLYSIS
Remember the Charleston 9
PYROLYSIS's Avatar
Thank you very much for all the hard work.
Old 08-27-2013, 11:11 AM   #5
dixonk
dixonk's Avatar
Drives: 2011 Audi Q7
Send a message via Skype™ to dixonk
Thank you for this.
dixonk is offline   Reply With Quote
Old 08-28-2013, 11:34 AM   #6
Calicamaro
Drives: 2013 1SS/1LE Ashen Grey
43 sounds like a nice race number. That's less then one per state!
Calicamaro is offline   Reply With Quote
Old 01-13-2014, 06:27 PM   #7
jdsblueray2013
Drives: 2013 Camaro 2ssrs Blue Ray
Send a message via Yahoo to jdsblueray2013
Thanks for the 2013 blue ray #'s.
jdsblueray2013 is offline   Reply With Quote
Old 01-13-2014, 09:16 PM   #8
Blue_11RS
Blue_11RS's Avatar
Drives: 2018 SS 1LE Hyper Blue
Ill take my 1 of 20 Crystal Red WOOT WOOT!
Blue_11RS is offline   Reply With Quote
Old 01-13-2014, 09:59 PM   #9
2012-1822
2012-1822's Avatar
Drives: Black ZL1
Dad gum, more rare than a 2012 ZL1.
Check out Alabama Camaros, for Camaro enthusiasts all around Alabama https://www.facebook.com/groups/1739...group_activity
2012-1822 is offline   Reply With Quote
Old 03-04-2014, 01:48 AM   #10
Kibullseye03
Kibullseye03's Avatar
Drives: 2013 Camaro 2SS 1LE
Forgetting one! I ordered mine with Carbon Flash Metallic.
Kibullseye03 is offline   Reply With Quote
Old 03-04-2014, 07:43 AM   #11
Kibullseye03
Originally Posted by Southern Comfort View Post
Can you post up a picture of your Carbon Flash Metallic 1LE?
Try to get one in good sunlight.
Sure! She's at the shop right now but when I get out there I'll take a picture.
Old 03-04-2014, 02:06 PM   #12
Kibullseye03
Here you go. Not too far off of Ashen Gray.
Old 03-04-2014, 04:31 PM   #13
Kibullseye03
I have a correction. Looking through my order forms for the car, I saw on my build sheet I ordered it as carbon flash. On all my other order forms it says ashen gray. :( I'm officially heartbroken.
Old 03-04-2014, 06:41 PM   #14
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
I was going to say Carbon Flash was not an option so you would have had a 1/1.....When I saw the picture I was going to say that is Ashen Grey!..
-Matt
