Old 07-09-2009, 11:57 AM   #1
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
irpq11, L99 Dyno results.
Ok fellas. Here are the results from my Dyno this morning.
The tuner was particularly puzzled by the fuel mixture running so rich to abnormal levels. He seemed pretty concerned. Said it may be causing HP loss.
EDIT: Turns out he was exactly right. The fuse pull solved the problem.
Old 07-09-2009, 12:02 PM   #2
jdanza
jdanza's Avatar
Drives: 2010 2SS/RS VR-BLACK
Are the HP and torque #'s where they are supposed to be ?
2010 2SS/RS VICTORY RED / BLACK LEATHER - 6 SPEED M TRANS
6000 = Delivered To Customer-8/22/2009
jdanza is offline   Reply With Quote
Old 07-09-2009, 12:03 PM   #3
9c1ny
9c1ny's Avatar
Drives: C6 Zed-oh-six
seems to be pretty normal for the HP #'s
9c1ny is offline   Reply With Quote
Old 07-09-2009, 12:03 PM   #4
MTron
Drives: 99 Grand Prix
they do seem a touch low. Could indicated a program issue.
I think the more significant thing here, is that if there is a programming issue, it could also affect the way the transmission shifts, as well as the torque management, thus further compounding the issue
MTron is offline   Reply With Quote
Old 07-09-2009, 12:03 PM   #5
GTAHVIT
Blessed
GTAHVIT's Avatar
Drives: 2013 Sonic RS MT
What else did he say??? was he happy with the HP numbers? Or did he think it was under powered?
I'm sure I should know this... but what should it be at the rear wheels?
Old 07-09-2009, 12:07 PM   #6
PQ
Booooosted.
PQ's Avatar
He said that in his opinion, this car should be losing no more than 15% from crank to wheels. He thinks the rich fuel mixture is causing a loss. In his opinion it should be getting 330 HP to the wheels. He says this car should be tighter than that.
Old 07-09-2009, 12:08 PM   #7
JDBeck23
Drives: 2010 Camaro, 2SS/RS
What caused the 20 hp jump from first to third dyno pulls?
Seems low to me, I would take the first dyno run into the dealer and put up the big WTF?!
2010 2SS/RS CGM
American Racing Headers, Magnaflow axle back, Roto-Fab CAI, Audio Integrations Sub box, Alpine Type R 10, Alpine MRP-500 amp, Pro Clips iPhone Mount
JDBeck23 is offline   Reply With Quote
Old 07-09-2009, 12:08 PM   #8
Xanthos
PWA Relapse
Xanthos's Avatar
Drives: Formerly-Stick
They should be able 320 at the rear wheels, but that A/F ratio looks a bit weird to me as well... That could quite possibly be messing with your numbers. Of course, it could be something else as well.
- X
2017 1LT/RS A8 Hyper Blue Metallic
Xanthos is offline   Reply With Quote
Old 07-09-2009, 12:08 PM   #9
MTron
actually, on further inspection, those seem very wonky...
i mean run 1, the torque and hp curves are nearly idenicel.....very strange....as well the A/F graph is messed...took a major plunge at 4.5 k rpm to 10:1....NOT normal and 200lb feet of torque at 4000 rpm...i mean....wow...not normal
run 2 you A:F is low, and your torque is taking a dive, but more normal then the first
run 3, same issues as 1, A/F dive at 4k rpm torque too low for the rpm at 4000
Old 07-09-2009, 12:09 PM   #10
matt55
matt55's Avatar
Drives: CTS-V
Wow rich in the mid , I wonder if the WBO2 is off ?
10.8@130.8 610 whp, CAI, 2.5, E85, id850 on street tires.
matt55 is offline   Reply With Quote
Old 07-09-2009, 12:10 PM   #11
ElAntonius
Drives: 2010 Camaro 1SS A6
They seem in line with the lower side of what most people are pulling in on the L99 (which seems to range about 310-330 depending on the dyno and other factors)
I wouldn't say that kind of dyno pull would be indicative of a car that is losing 1.5-2 seconds to 60.
Edit: I mean the actual HP numbers. Analysis of the A/F mixture and curves is beyond my ability.
A House Divided...
ElAntonius is offline   Reply With Quote
Old 07-09-2009, 12:11 PM   #12
1320junkie
Drives: The Imperial Army
Yeah man its a tad bit off..2nd and 3rd would be acceptable but your a/f is kinda wacked...wth happened with the 1st run?
Old 07-09-2009, 12:13 PM   #13
D1BADZ
hmmmmm
D1BADZ's Avatar
Drives: 2010 IOM in-n-out 2SS
hmmm, interesting, thanks for posting this up
"Responsibility is a Heavy Responsibilty" (Cheech)
D1BADZ is offline   Reply With Quote
Old 07-09-2009, 12:16 PM   #14
ElAntonius
Looking at the low starting torque on run 1, I wonder...
irpq, you've said that you randomly had the car 'wake up' the other day, though it seems intermittent?
I've been thinking about my theory that the car doesn't respond as well to mashing the throttle from the get-go...all my best launches have been in situations where I smoothly feed the throttle in and I've had some disappointing launches where I rammed it...is it possible that some aspect of the L99 software is limiting maximum torque from a dead stop? Perhaps some sort of break-in software?
A House Divided...
Texas Speed Long Tubes & Rumbler 5 Cat-Back Dyno Results! Trevor @ Texas Speed Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 48 12-08-2018 02:37 AM
Check your Order here bvonscott Camaro Price | Ordering | Tracking | Dealers Discussions 665 06-29-2009 01:00 PM
L99 STOCK dyno video and results pharmd Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 7 06-25-2009 10:05 AM
Dyno Results on L99? pharmd Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 23 05-12-2009 10:53 PM
BUDWEISER SHOOTOUT LINE UP CamaroScotty General Automotive + Other Cars Discussion 22 02-07-2009 07:03 PM
