![]() ![]() ![]() ![]() Drives: 2013 2LS BLK Join Date: Oct 2013
LFX cam
Ok so I'm looking into maybe getting a cam in the future. I have a few questions though. What are some good cam "kits" as I guess they would be called, would be good kits for the maximal amount of WHP but retaining my car comfortably in the DD realm. Then what are the most cost effective kits with a reputable company backing them? Also would installing a can void my PT warranty? With a cam require a tune? I am assuming it would. Do tunes void warranties? Sorry for all the questions. If you need any other info let me know.
Drives: 2016 1LT RS Camaro; 72 Chevelle Join Date: Apr 2008
There is only one company that is currently offering camS for the LFX engine, MACE Engineering in Australia. You have to replace 4 cams, not just one, it is relatively expensive. You will need a tune. Your PT warranty will most likely be void.
Dang 40 rwhp for $1,200. That's really expensive in my mind.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
You are right, it is expensive, but its 4x the cams as say the V8 engine.
That said, I'm fairly certain a member here that is doing cams on his LFX says he got the cams from MACE for half of that....but that could be because technically they are still finalizing development and tuning on the cams and maybe its a temporary deal? I don't know. So while it looks promising for the LFX, and it seems they will work, we are still waiting to see things tuning options and results, and also we have yet to see exactly how much power they can make.
2010 Camaro 1LT V6 (Sold. I will miss her!) |
Interested in seeing what comes out of this
Sent from my iPhone using Tapatalk 2
Cold Air Inductions CAI Stainless Power LT's with HFC's Flowmaster American Thunder Cat Back APEX Scoop and WW Relocation Kit VMAX Ported Throttle Body Custom Dyno Tune Pfadt 1.25" Lowering Springs ZL1 Rims on 275 front 315 Rear custome underlay vinyl wrap Anvil Spoiler heritage grill APR Front Splitter Custom Emblempros emblems ZL1 Side Skirts 416.5 whp 410 torque (CURRENTLY) Up Next: BTR Stage 3 Cam and supporting mods (in garage now)
#6 |
Interesting. Isn't there another can coming out for the lfx? I think they posted a thread on this site. How much did that kit cost.
#7 |
LMR is currently doing R&D on LFX cams/heads... What comes of it is yet to be determined. No prices yet, and I imagine it's going to take a while.
#8 | |
![]() Also how much do you think this kit would run? And someone like myself I have I would say a decent understanding of motors/engines and my future father-in-law has all of the necessary tools to put the cams in for sure but all of his experience is with carbureted engines. Would we be able to do this or is this simply over my head.
#9 |
Don't know how much it would run, I'm sure it won't be cheap as it's probably still 4 cams to be changed.
This is pretty vague, but to give you an idea of what would need to be done, check out this post: http://www.camaro5.com/forums/showthread.php?t=314677 (camshaft removal in post #6) |
#10 | |
#11 | |
Specs
TSP Stage 2 Boosted Cam 227/235 at 114 LSA Fore Innovation Triple pump staged (Walbro 342 primary and 2x Walbro 450 secondaries) Procharger D1x with a 3.85 pulley ID1050x Injectors Flex Fuel Sensor Monster LT1 Twin Disk Clutch Holley Sniper Efi Intake Manifold NW 103mm Boosted TB 747rwhp at 12psi on E85 |
#12 |
Founder - Michigan FBody
Drives: 1994 Camaro LT1, 2012 Camaro 2SS/RS Join Date: Jun 2008
With how expensive the kits are because you're changing 4 cams, it honestly doesn't sound like it's worth it at all to do cams on the LFX for minimal gain. That's why there's not a lot of options available out in the market right now ... who wants to drop $1,200 for 40rwhp?
....... Then again, plenty of people on this site love to blow thousands of dollars for other overpriced BS that probably only gains them 10-15rwhp (many of the exhaust kits for the V6 crowd comes to mind) so I guess $1,200 for 40rwhp isn't that bad.
2012 Camaro 2SS/RS L99 - "Zooma"
1994 Camaro LT1 A4 - "Red Alert" - v6-to-LT1 Swapped Cruiser; Cammed, Stalled, Enjoyed "Gone But Not Forgotten" 2016 Camaro 1LT A8 - "Elmo" 2014 Camaro 1LT M6 - "Cherry Bomb" 2012 Camaro 1LS M6 - "Clifford" Michigan FBody Association http://www.mifbody.com/ |
#13 | ||
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 CGM Camaro LS A6 Join Date: Jan 2011
#14 | |
| Tags |
| cam, kit, lfx, tune, warranty |
