Runs with scissors...
Drives: '14 Z/28s SIM/SW Join Date: Jan 2013
Camaro Z/28 multimatic suspension to be used in upcoming Mercedes AMG SLC
FROM ROAD & TRACK Mercedes-AMG C190 to get high tech suspension … from the Z/28? Upcoming baby SLS; will share Multimatic dampers with the Z/28. By David Gluckman October 28, 2013 / Photos by Multimatic ![]() What do Red Bull F1 cars, all 77 Aston Martin One-77s, the 2014 Camaro Z/28, and 20 of this year’s 56 Le Mans entries have in common? They all use a relatively new damper design from a company called Multimatic. Now, add AMG’s next solo project to that list. The Mercedes C190—that’s its internal code name; you can call it SLC or baby SLS—is AMG’s follow-up to the SLS. It's a small sports car aimed at the 911. And, as the list above suggests, it’s going to have a pretty serious suspension. Canadian OEM supplier Multimatic has been putting its Dynamic Suspension Spool Valve (DSSV) dampers on race cars for a while, and it recently hit on a new manufacturing process that brings down the time and expense required to machine the special spool valves. The solution came from a company that laser-cuts medical devices, incidentally. MultimaticThat means more applications on “affordable” road cars like the Z/28 and the Mercedes-AMG coupe. The spool valve replaces the shims in a conventional damper, providing better consistency damper to damper, more precise control of the force-velocity curve, and repeatability from impact to impact. No worries about the orifice changing shape over time. The other cool part: The use of two spool valves per damper completely decouples the compression and rebound curves, so they can be tuned independently. While I’ve never even touched a One-77, after a ride in Chevy’s track-aimed Camaro, I can say that this suspension works incredibly well. The key is that a driver can hammer on a car for lap after lap of a track like the Nürburgring with the added confidence that the suspension will react the same way every time, just how the engineers intended. And we can infer that the little AMG that’ll wear these dampers should be as track-focused as the other metal on that list. It’s a good sign, anyway, and a signal that there are probably more DSSV applications to come.
![]() ![]() Drives: Ferrari F430 Spider F1 Azzurro Arge Join Date: Sep 2013
If anyone can create, or knows where to find a slow motion "How this works" video of the Multimatic units in action that would be awesome.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: One of the baddest handling Gen 5s Join Date: Feb 2011
#4 | |
knows 2 facts about ducks
![]() Drives: Zl1 coming soon Join Date: Oct 2012
"That means more applications on “affordable” road cars like the Z/28 and the Mercedes-AMG coupe"
Anyone else find that interesting? |
#6 | |
![]() Drives: 2010 Camaro 2SS/RS L99 Join Date: Apr 2011
Still pretty cool the technology from a Camaro being used in $100k Mercedes, nothing new there I guess it has happened before.
375RWHP/399RWTQ |
#7 |
Casey Woodside
Drives: a very fun car Join Date: Jun 2010
price just went up
Instagram @caseywoodside
http://youtu.be/CSc9aPh_X_w |
#8 | |
Opinionated bugger!
Drives: Boss 302, Mazda 2, Praga & Intrepid Join Date: Feb 2011
Wonder were they developed this? http://multimaticmotorsports.com/pho...io-sports-car/
Follow me on forums everywhere as Fenderaddict2 or my kid on the track and Twitter @fastmyles |
#9 |
Downright Upright
Drives: Daily Join Date: Apr 2009
Scott Maxwell cut his door slammer teeth in the Player's/GM Challenge circa '86-forward, driving the forerunner of the 1LE Camaros/Firebirds aka A4Q or R7U.
http://www.cartersclassicmusclecars....g%20series.htm Another graduate of the Player's/GM Challenge? Mr. Ron Fellows... Scott also won the 1st race for Ford's current Mustang @ Daytona, Jan/05, as the co-team driver for Multimatic's GS-Class 'Stang, the original and well-massaged FR500C. Multimatic built the FR500Cs for Ford...and Scott was their development driver. His co-driver @ Daytona? Another Player's/GM Challenge graduate, David Empringham. We were there, for all of it... EDIT: BTW, Multimatic is a division of the mega-Tier supplier, Magna International. Last edited by LOWDOWN; 12-02-2013 at 05:00 PM. |
#10 | |
#11 |
![]() Drives: 2011 Camaro 2SS/RS M6 Join Date: May 2011
So I'm sure this has been asked before but my quick 2 second search didn't turn anything up so ....
Can you purchase these and install on an SS Camaro? Or is it not that simple, meaning they have to be tuned specifically and an entire control system integrated into the vehicle? |
#12 |
Downright Upright
They're NOT electronic, like the MRC. To do a proper job, you'd need to replicate the Z/28 suspension SYSTEM, part-by-part. For that, you'll likely need an AMEX Black...
I'm sure the shocks will be GM-available, eventually, but they're only 4 components of a true "system". |
#13 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Camaro's, always have, always will. Join Date: Oct 2010
...Find new roads....
#14 |
![]() Drives: Getaway Special Join Date: Jan 2013
Well, I doubt I'll ever see one on a normal road. I'll be checkin one out once in a great while at a cruise in out of it's niche......(maybe) ...since it's mainly a great track car!
Sip:
