Old 12-19-2013, 11:34 AM   #1
camarovigoa
Drives: 2013 Camaro ZL1 Victory Red A6
Ran two Best time last night! Same Bolt-ons! 10.61@131 and 10.60@129 Camarovigoa
Stage 2 package includes:
Roto-Fab CAI
2.55 Upper Supercharger Pulley with isolator upgrade
Ported Intake Snout
102MM TB
Redline ATI 8.66 Lower Crank Assembly
1 7/8” Long Tube Stainless Steel Headers with high flow cats and X pipe
160 degree thermostat
Custom Engine and Transmission Management Calibration
Wheels used: Weld 17'' RTSs front and rears with hoosier slicks and M&H skinnies.
Other mods: Lower pulley, idler belt and recalibration!
http://www.camaro5.com/forums/attach...1&d=1387471197
camarovigoa is offline   Reply With Quote
Old 12-19-2013, 11:37 AM   #2
SinisterEcho
SinisterEcho's Avatar
Drives: 2010 2SS/RS M6/LS3
Nice times! Congratz!
My Mod Journal <-- Its updated... again!
SinisterEcho is offline   Reply With Quote
Old 12-19-2013, 11:44 AM   #3
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
Amazing..... keep up the good work!
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
Old 12-19-2013, 11:45 AM   #4
yotaman96
yotaman96's Avatar
Drives: 2017 Camaro SS1LE 2000 Trans Am WS6
Very nice.
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans
2002 Trans Am
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 12-19-2013, 11:46 AM   #5
CanadianZL1#992
ANGRY Z
CanadianZL1#992's Avatar
Drives: 2015 Camaro ZL1
Wow!! Great pass
CanadianZL1#992 is offline   Reply With Quote
Old 12-19-2013, 12:41 PM   #6
camarovigoa
Thanks everybody! Here is the video of the passes!
Old 12-19-2013, 01:30 PM   #7
Drew P
Drew P's Avatar
Drives: Camaro ZL1
Who did your trans tuning and were you launching in PTM5? Awesome et's.
2012 A6 Coupe 630RWHP 10.93@125
Mods: ID850 Injectors; D3PE HX, Reservoir & Atmospheric Catch-Can; LPE 2.55 Upper & 9.1 Lower Pulleys w/ ATI Damper; LPE Idler Pulley Relocation Bracket; "Green" Serp. Belt; Cat delete;ADM Exhaust Override; Magnaflow X-Pipe Muffler (in addition to stock mufflers); Cold Air Inductions CAI; 160 thermostat; LS9 Isolator; Port/polish snout and intake runners; LPE GT9 camshaft with dual springs and titanium retainers; Kenne Bell BAP, Install and Engine Tune by Serious Hp; Fab work by D3 Performance Engineering; Trans Tune by Keith; Coming Soon: Flex Fuel Conversion.
Drew P is offline   Reply With Quote
Old 12-19-2013, 01:34 PM   #8
camarovigoa
Redline Motorsports doses all the tuning. And I'm just taking traction control and stabilitrack off and putting it in "M" sport mode. And I'm not launching with that much RPM maybe 1000 if I try launching at anymore than that I'll just spin
Old 12-19-2013, 01:59 PM   #9
camarovigoa
Originally Posted by HRD_WRK View Post
Congrats on the awesome runs. Even over 130s
Nice video editing also.
Thanks for sharing.
Tim
Thank you buddy!! Was kinda shocked about that LOL!
I'm getting alittle better at it
I had to motivate you to come down here and run with us!
Old 12-19-2013, 02:50 PM   #10
big dave
Drives: 2017 ZL1
Congrats again Stephen!!! Getting quicker every time you go out. Pretty soon you'll be knocking on the door to the 10.4s.
'17 ZL1 10.99@129 stock. 4225# raceweight. Best 60'- 1.66 on factory tires. 10.48@132 E50, intake and tune. 4270 lbs
https://youtu.be/EyHtdH9XOkY
https://youtu.be/Lcu41obbTf8
'13 ZL1 BRM A6. 11.591 @ 119.2 factory stock with a 1.68 60'! Best stock mph 121.8. 11.29 @ 123 RotoFab, drag radials and skinnies. 4360# raceweight.
http://youtu.be/yggIA3C_kkA 2014... back to stock
http://youtu.be/spQLaTWbThs 2013... stock & RotoFab
big dave is offline   Reply With Quote
Old 12-19-2013, 03:04 PM   #11
Kelly@PCMofNC
Drives: 2010 RS/SS
Awesome. The drag wheel set up is killer!!
Kelly@PCMofNC is offline   Reply With Quote
Old 12-19-2013, 03:19 PM   #12
cam99
cam99's Avatar
Drives: 2012 ZL1
Great passes, you are on a tear!
2012 CTF ZL1-stock
2012 ZL1 (sold)
JRE 75rwhp kit
catless
ported lsa TB
11.04 @ 128.35
on hoosier drs and skinnies
@ PRP with 1100DA
cam99 is offline   Reply With Quote
Old 12-19-2013, 04:01 PM   #13
sycraft
COTW 5/06/2013
sycraft's Avatar
No you are building some steam....
Old 12-19-2013, 04:26 PM   #14
camarovigoa
Thank you buddy!!! I don't 10.4 is gonna be tough LOL! Need to find a better way of hooking up I'm spinning too much.
