Raining Blood
Drives: 2014 SS Performance Sedan Join Date: Oct 2009
Rough idle L99
Om my way home from work Saturday night. my car seemed to have difficulty running. Idle was harsh, the tach reflected the rough idle, dipping below 500 rpm. The rough idle was accompanied by some popping from the tail pipes on acceleration but the car runs ok.
No CEL, no warning lights of any sort. I had my car in the shop previously for a misfire in cy #5 almost exactly a year ago. Previous issue here. about 9600 miles on the odo. Mods are catback, shorty headers w/ factory cats, CAI. Driving her back to the shop Monday morning. Any ideas on what the deal might be?
Ordered 1/9/12 - Born 2/3/12 - Delivered 2/21/12 - '12 1SS/RS Summit White - TRADED.
![]() 2014 SS Performance Sedan #2974 - Red Hot 2 - S/R. & Spare. Built 01/09/14 #238 of 291 as configured |
Raining Blood
Well, she started out ok this morning but halfway to work she started idling rough again and the exhaust pops, gurgles and chokes up to about 20 mph then seems to smooth out.
MAF sensor? Dirty CAI? (doesn't look dirty and the car has less than 9600 miles) Fuel injectors? Maybe the coil packs again? I've got an appointment for Wednesday morning. Very frustrated, this should not happen on a barely two year old car.
Raining Blood
same issue has returned. Error code U0401 and P0300. Might be trading this car is very soon.
I'll be back...
Drives: Subaru, HD Road Glide Special Join Date: Apr 2012
I read through your other references, and it appears that a loose plug wire on #5 cyl. was the cause, correct? If so, was the plug changed at that time? If not, it could be leaking compression that would cause your plug wire to pop off over time. It's not as uncommon as one might think.
Bye bye, Bumblebee!
#5 | |
Raining Blood
Leaking compression from what? Cylinder? Headers?
![]() 2014 SS Performance Sedan #2974 - Red Hot 2 - S/R. & Spare. Built 01/09/14 #238 of 291 as configured Last edited by Frank in MD; 06-17-2014 at 12:40 PM. |
#6 |
Raining Blood
So I'm going to ask for leak down and compression tests.
#7 |
Geek
A missing cylinder will feel rough at low RPMs and smooth out as RPMs increase. I wouldn't drive it like that though if you don't know what is wrong yet. Mine was a sheared rocker arm bolt. I limped it to my garage and tore it open before running it again.
Your shop should at least pull the valve covers if there is nothing obviously wrong with the spark plugs or wires. They should know how to troubleshoot a misfire.
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1 x = ~x |
#8 |
Raining Blood
I hear you, but since this is the same symptoms as last year I don't believe I have bent rods or rocker bolts. It was the coil pack last year. Something is making it come loose, I just need to find out why.
#9 | |
I'll be back...
Bye bye, Bumblebee!
#10 |
Raining Blood
Well, the misfire is now in cylinder #4 instead of 5 as per the last issue. I'm not sure if it jumped to 4 because that's where the previous tech put the old coil pack or if this an indication of a larger issue. The svc writer inquired about my ARH shorties. That's troubling as now I get the feeling they'll say we fixed the issue and it's not covered b/c you modified your powertrain. We'll see, but as of today we still don't understand the problem or know of a permanent fix.
#11 |
![]() ![]() ![]() ![]() Drives: 2014 2SS L99 Join Date: Mar 2014
Do you think the headers are causing heat issue related to ignition components ? Just wondering.
#12 | |
Raining Blood
I asked for the "melted wire" and I was presented with a cracked spark plug wire. Pics of damaged wire coming soon. Nowhere do I see heat damage inside or out.... having said that it might even be correct as this is the second time this has happened. It doesn't help that I have two different explanations from two dealers on the same issue, one year apart. I'm looking into getting some hi temp spark plug wire and/or some type of harness that keeps a certain amount of separation between the wires and the headers.
#13 | |
Check these out... http://www.ebay.com/itm/BLACK-1200-S...ee85ec&vxp=mtr |
#14 |
Raining Blood
This is the wire that was replaced. It was 90% cracked when I got it, the remainder broke while showing it.
![]() ![]() ![]() The gaps are pretty consistent. There may be some that are closer than others but they're all relatively close.
