09-03-2014, 12:31 AM | #1 |
Negative Camber Junkie
Drives: 2010 1SS LS3/6MN ABM 1 of 23 Join Date: May 2009
Good Tech article about the Eaton Trutrac
Check it out....
The Eaton Truetrac LSD and a Road-Raced Fifth Gen Camaro http://www.lsxtv.com/tech-stories/ea...fth-gen-camaro I will do a copy/paste later. T.
"Horsepower is something that looks great in a Magazine article, but suspension is what actually gets you around the track fast.." Jack Olsen
The drag strip is like sniffing glue, it's cheap, it's a decent buzz, it doesn't last long and they are all the same. Road racing is like China White Heroin, the buzz is stronger, the high lasts for hours, it's extremely addictive and they are all different. I can't wait for my next Track fix. DA HAWKS OWN DA CUP!!!!! |
09-03-2014, 11:12 PM | #2 |
So Cal Race Team
Drives: 2013 Camaro Join Date: Mar 2010
Interesting...I might need one....
09-04-2014, 09:03 PM | #3 |
Drives: 2013 Camaro 1LE Join Date: Jul 2012
So is this the same style of differential that the Z/28 uses? I know they call the Z/28 differential a "Helical Gear" differential. And from what I can see in their video this differential is a bunch of helical gears.
Just trying to educate myself a little more here on the differences. Thanks for posting this link TBone! Very educational and interesting.
09-05-2014, 09:00 AM | #4 |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
All of the helical gear differentials are pretty similar, with bias ratios and perhaps durability for hard launches being the main differences (some of the Torsens are relatively fragile when subjected to that kind of abuse). There is, or at least was, a version of the Torsen that also included some means of obtaining preload (T2R).
On edit, I think you have to be careful about what sort of lube and particularly additives you use with any of these diffs. If you reduce the friction, or reduce it too far, the diff won't work right. I know I read that about the Quaife diffs somewhere or other. Norm |
09-05-2014, 10:23 AM | #5 | |
