Old 10-10-2014, 02:17 AM   #1
damian559
damian559's Avatar
Drives: 2015 1SS, 1LE, Recaro, NPP
Wicker bill on 1LE spoiler?
Has anybody put the wicker bill on their 1LE? I'm really curious to see what it looks like, I'm too scared to do it first.
Also, does anybody know where I can get the Z/28 carbon fiber heat extractor for my car?
2015 Summit White 1SS, 1LE, Recaros, NPP
498 RWHP 447 RWTQ (Motor)
647 RWHP 723 RWTQ (150 Shot)
12.1 @ 117 (Motor)
11.7 @ 129 (Nitrous)
Nitrous Outlet Single Nozzle Kit | Stand Alone Fuel Cell w/ C16 | Custom Grind Cam | Stainless Power 1 7/8 LT Headers | CAI Intake | ATI Super Damper | BMR Trailing Arms & Toe Links | Prothane Polyurethane Sub-frame Bushings | JDP Upper Control Arm Bushings | MT Drag Radials | Tuned by SS Motorsports
Youtube Channel:
Click Here
damian559 is offline   Reply With Quote
Old 10-10-2014, 07:26 AM   #2
SASQUATCHelvis
Drives: 2014 Camaro SS 1LE
I think the Moreno brothers are working on a CF hood extractor. If you can talk you way into a z/28 part I think they're still around the $2500 mark.
SASQUATCHelvis is offline   Reply With Quote
Old 10-10-2014, 07:28 AM   #3
AG1LE
AG1LE's Avatar
Drives: '14 1LE
I've asked the same question about the wicker bill, but no luck so-far
AG1LE is offline   Reply With Quote
Old 10-10-2014, 08:20 AM   #4
SASQUATCHelvis
http://www.camaro5.com/forums/showthread.php?t=380517
This guy did it on his ZL1 spoiler, which should be the same or very similar to the '14 spoiler.
Old 10-10-2014, 08:40 AM   #5
AG1LE
AG1LE's Avatar
Drives: '14 1LE
That's a 2013 ZL1 - not close enough to the 2014-2015 1LE spoiler IMO
Old 10-10-2014, 10:01 AM   #6
White_SS/RS
White_SS/RS's Avatar
Drives: 14 1LE
I've done a lot of research into this. No I didn't end up doing it but yes it will fit. They curve along the rear of the spoiler is really close to the same and the thickness of the material is the same as well so it will support the use of riv-nuts. You will, depending on how you position it, have holes showing in the raised position and it will hang below in the outer corners when it's down.
LMS Engineering
White_SS/RS is offline   Reply With Quote
Old 10-10-2014, 11:12 AM   #7
Bhobbs
Bhobbs's Avatar
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle
If you track your car a lot, I would think twice before adding the wickerbill. The 1LE is set up as is to reduce understeer. Al O said adding more downforce to the rear end of the car would cause understeer which is why the 1LE has the spoiler it does.
Bhobbs is offline   Reply With Quote
Old 10-27-2014, 09:36 AM   #8
Spartan01
Spartan01's Avatar
Drives: Evil Eva, 2010 2SS LS3
somebody please make a Wickerbill for a 2010 spoiler
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
Spartan01 is offline   Reply With Quote
Old 12-09-2014, 11:45 AM   #9
JOHNSONROD
JOHNSONROD's Avatar
Drives: 62 Chevy & 2021 1SS/1LE manual
the new JRod Motorsports Aluminum Gurney Lip is a nice piece for a 2010 . havent tested it yet.
JOHNSONROD is offline   Reply With Quote
Old 12-09-2014, 01:07 PM   #10
tjea
tjea's Avatar
Drives: 2014 1ss 1le Blk/Blk
If you do one end you must do the other end.
Delicate balance between front and rear aero.
tjea is offline   Reply With Quote
Old 12-09-2014, 01:20 PM   #11
JOHNSONROD
JOHNSONROD's Avatar
Check!
Old 12-09-2014, 03:31 PM   #12
RockerBox
RockerBox's Avatar
Drives: 2010 Silverado. Stock height now
Chevy sells the carbon hood insert. It's an option when ordering a camaro.
RockerBox is offline   Reply With Quote
Old 12-09-2014, 03:50 PM   #13
XxScottxXN
Huge Chevy Fan
XxScottxXN's Avatar
Drives: 14' 2SS/RS 1LE built 4/22/14
I had my hood insert done with hydrographics and it was a lot nicer paying $100 compared to $2500 for the Chevy one. The weight is almost the same too.
2014 2SS/RS Red Rock Metallic, Recaro seats, sunroof, NPP, Nitto Motivo 275/40/20 front 315/35/20 back, Cold air inductions intake, elite catch can, Stainless Works 1 7/8" long tube headers w/hiflow cats, 20% tint, Intake rod mod by Gwatney Performance, Bo White ported & polished throttle body, powerbond 25% UDP, Howards Cam 226/236 duration- 525/525 lift 110 ....with a WHOLE bunch of fun added!!
XxScottxXN is offline   Reply With Quote
Old 12-09-2014, 04:05 PM   #14
toehead93
Drives: 2014 2SS/1LE
Does anyone make a 2014+ 1LE splitter extension to go with the wicker bill?
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
