Geoff
Drives: 2022 SS 1LE Join Date: May 2013
forged 416 build
the timing chain broke and caused a fair bit of damage, that coupled with my aversion to failure, I'm hopefully going to build a motor that I can get more than 25,000miles out of.
failure and diagnosis here http://www.camaro5.com/forums/showthread.php?t=382495
Geoff
the plan
1st tore it down and assessed the damage
Good Parts: block, heads, clutch, rockers, rods, a couple of pistons and the crank could be reused, but it needed some work Bad Parts: chain (duh), cam, some pistons, most of the valves, crank needed some work, oil pump, metal everywhere.......... with the above and the plan to keep road racing on weekends and having the car as a true daily driver we decided on a few necessities and a few good to haves and some things just because forged stroked bottom end with a slight bump in compression custom grind on a 3 bolt cam motion core from BTR designed for torque and sustained high RPM keep the 660 BTR springs (tested good) reuse the comp cam trunions (checked good) LS2 "bow tie" tensioner C5R Katech chain and factory gears another high volume oil pump CNC the intake and exhaust runners on the stock heads polish the combustion chambers for heat control head studs oil pan baffle external oil cooler ATI 10% under drive balancer auxiliary oil temp gauge under hood fuel pressure gauge data logger for smart phone all I have so far is the pan baffle and the heads the pace should pick up after this weekend
![]() ![]() Drives: RY 2011 2SS A6 Join Date: Jul 2010
Sounds like a good plan! Subscribed and looking forward to seeing your build progress.
Dry sump LS7, cage, JPSS suspension, Wilwood brakes, fire suppression, ARH 3" headers/exhaust, Z/28 DSSV coilovers, Kirkey seats, TeamTech 6-point harnesses, 19" Forgeline GA3R, 325/30R19 Re11 tires, oil cooler, monster JPSS splitter/wickerbill, CAI, brake ducts. |
old school chevy rodder
be safe this time go with a nice Fluidampr harmonic balancer to help engine vibrations and a nice timing chain would help and also driven racing ls30 oil,,,, that's all the advice I can give, and your old cam did have a lot of wear and metal shavings around it in your pics. Good luck. I do know that a comp cam gear drive has been made also......
![]() Drives: 1989 GTA Trans Am Join Date: Jun 2012
Subscribing to the build.
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 SS Join Date: May 2013
Oh I like this!
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: ‘13 1LE Join Date: Jul 2013
Subscribed.
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2014 2SS M6 "CHRISTINE" Join Date: Mar 2014
This should be GOOD! Subscribed!
"But, House Mormont remembers. The North remembers! We know no King but the King of the North whose name is Stark. I don't care if he's a bastard. Ned Stark's blood runs through his veins. He's my king–from this day until his last day."
Mods: ARH headers and hi flow cats, VMAX ported throttle body, CAI air intake, Slowhawk Performance tuning |
#9 |
Drives: '15 Z06, '01 NBM SS, '97 SS Join Date: May 2009
You have my attention....
Gorgeous oil pan baffle setup. Ivan @ Southwest Speed |
#10 | |
Geoff
C5R chain is in the plan, I'm not an early adopter, so i'll pass on the gear drive...... thx for the suggestions!
#11 |
Geoff
sooooooo true, it is sweet looking. I know that I am not an early adopter, but this looks so good and I don't see how I can go wrong with it. this definitely falls into the "just because" category of purchases!
#12 |
![]() Drives: 2007 Corvette C6 983 RWHP Join Date: Dec 2011
Saw that gear drive at SEMA....very interesting but not sure I would spend that money. C5r chain is well proven.
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam YSI / 3.0 pulley, ARH 1 7/8 headers, NPP Dewitts / dual spals, A&A dual pump fuel system. 3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me. ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper Circle D Triple Disc stall 1009 RWHP @ 7000, 817 RWTQ @ 6000, |
#13 | |
![]() ![]() ![]() ![]() ![]() Drives: Camaro Join Date: Apr 2009
Give us a call if you need help on the short-block or short-block parts. With over 200 crankshafts in stock, 200 sets of rods & probably 60 sets of pistons I bet we have something to get you going. We can even machine the engine for you. With the TSP short-block setup you get cnc digitizing & blueprinting to make sure your bores, decks & cam to crank correlation is correct. That's something nobody else in the LS industry can offer!!
#14 |
Geoff
thx Jason
most things are ordered..................just waiting on the UPS man to do his thing
