![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Turbo LS3 Join Date: Dec 2009
TR6060 Upgrades When You Replace Your Clutch
It was suggested I create a thread that outlines the upgrades one might do while they have the trans out to upgrade the clutch on the TR6060, so here it is.
I did the following while I had my trans out. A lot of this can be accomplished with the trans in, but having it out certainly makes it easier and reduces duplication of effort. As with any upgrades, there varied opinions on the efficacy of each upgrade, but I felt these were cheap and easy enough to do that it made more sense to do them than have to do them later with the trans still in, or worse have to take the trans out. Only a couple are mine, so many thanks to the guys who did the others and all the guys who have done the various DIYs I have used. This site gets banged up elsewhere for the number of "what's the best CAI" threads, but it truly is the best place to get good ideas on how to mod your GenV. GTO Clutch Reservoir Install Monster Billet Support Bearing Tick Remote Clutch Bleeder Install TR6060 Bronze Isolator Cup TR6060 Tail Housing Support Bearing This list is not all inclusive as there are probably other related mods I have missed. I did also install a short throw shifter with a Hurst handle, but it was not a Hurst shifter so I did not include the DIY on that. Some also replace the line to the slave cylinder with a stouter unit to ensure all the fluid from the clutch master cylinder stroke gets to the slave, but I don't road race so I did not feel it was something I needed.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. Gen6 ZL1 brakes. |
Geoff
Drives: 2022 SS 1LE Join Date: May 2013
Thx for this cracka
![]() Drives: 2014 Saleen 620 White Label #14-011 Join Date: Dec 2014
awesome thank you! Bookmarked!
'14 Saleen 620 White Label #14-011
ADM LSA Stage 1 Kit, ADM 2.75 Pulley, DEKA 63lb injectors, ZL1 Fuel Pump, JLT 123MM Big Mouth intake, TSP 2" LTHs, BW TB, 2.5" Catback, Scott Culbert/GEN3PERF tuned! 573WHP/557WTQ @ 10psi. Build Thread Here: http://www.camaro5.com/forums/showthread.php?t=390708 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Black '13 2SS/RS/1LE w/NPP/NAV Join Date: Oct 2012
Man, I was just talking about this and searched for your support bearing thread.
Thanks for doing this. Sticky this please... Sent from my SM-G900V using Tapatalk
My Build Thread... http://www.camaro5.com/forums/showthread.php?t=285054
Good info there.
http://www.camaro5.com/forums/showthread.php?t=344754 Summit White 2014 2SS 1LE Recaros, NPP exhaust, Nav 2010 2SS A6 - sold. |
#6 |
Thanks gentlemen,
Just paying it back.
#7 |
What fluid did you go with ??
'14 1LE, Recaro, Cammed, Headers, Hi Flows, CAI, Tuned, 486 RWHP
https://www.youtube.com/watch?v=H57UfKCO0EY&feature=youtu.be |
#8 |
I went with Redline based on others recommendations. I run Mobile1 ATF in my ZF6.
I never had any grinding issues so I didn't really notice a change but if I'm replacing the fluid and leaving it in forever, I'm using a good synthetic.
#9 |
Thanks, I keep hearing different things. Gotta make up my mind soon !
#10 |
I use the Valvoline High Mileage stuff in the Red Bottle it's full synthetic and according to the Valvoline guys it's better than the Mobil 1 synthetic.
#11 |
![]() Drives: 2011 1SS LS3/ SC Join Date: Apr 2016
hey guys was installing the support bearing and bent the outer ring that holds the support some. was able to get it straightened out and back on. When I tested it by pressing the spring a couple of times and releasing real hard it pops off. Does the little ring hold the support bearing on once it goes back together, or does it get pushed down in assembly? THANKS FOR ALL INPUT
#12 |
There is constant pressure between the pressure plate and throwout bearing, but Monster warns about messing up that spring and not to install if it gets boogered up. I would contact them. Based on their site instructions, I don't think you are the first to do that.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. Gen6 ZL1 brakes. Last edited by CamaroCracka; 05-23-2016 at 11:04 AM. |
