![]() Drives: 2013 ZL1 Join Date: Oct 2014
Car Trailer
I am in the market for a car trailer.. just curious what you guys are using? Anything specific I should look for? I am concerned with how low my car is with the 1" drop. Oh and I will be pulling the ZL1 with a 2002 Tahoe.
![]() ![]() Drives: 2013 ZL1 Join Date: Jan 2015
As long dove tail as possible, long ramps, and torsion axles for low ride height. If it's an open trailer low fenders or removable fenders so you can open the doors. 16' min but 20 is perfect as you can adjust car position for ideal tongue weight and get good strap angles. Electric brakes instead of surge brakes. Swivel jack and d ring hooks. I could go on and on.
2013 A6 ZL1
Do you think a skid steer trailer would work? I can get access to one of those for free whenever.. It's a 16' and about 2800lbs... I am just not sure about the ramps.. prob need to use race ramps or something similar to get low enough.
750HP of Twisted Reaper!
Drives: Blk 2SS/Blk Carb Fibr NS-1 stripes Join Date: Oct 2010
Fear the LMR Twisted Reaper Brotherhood!
In looking at skid steers, I am guessing most are not wide enough.
#6 |
This is the one I have access to
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 ZL1 Join Date: Mar 2013
I do not see any d-rings on the floor of the trailer. Where would you tie your car down to? I also think that trailer will be to heavy with your car on it to pull behind a tahoe. Just my thoughts.
#8 |
The skid steer trailer will be plenty heavy duty but technically about as opposite of ideal as they come. That one has a 2' dove tail, skid steers have very short wheelbases so it's irrelivent for them. Second it has 8 lug heavy duty axles, which sit higher than standard 3k axles. Then the fenders are taller for the heavy duty tires. The trailer is super heavy duty which is fine but you are tugging an extra 1000lbs that you don't need. If it's free and a trailer you rarely use you should be able to use it, although it will take some effort. You will either need to crank the jack down to raise the front of the trailer to improve the approach angle or pull your tow vehicle up on some stepped boards. Then you will need to get a few 2x10's and stair step the approach for the ramps. None of this is hard or big deal but separates the ideal car trailer from a equipment trailer.
2013 A6 ZL1
#9 |
It has stake pockets on the side and you can hook the trailer frame by running the strap over the deck frame.
2013 A6 ZL1
#10 |
![]() ![]() ![]() ![]() Drives: 67RS Camaro ,Black 2013 ZL1 Join Date: Jun 2010
#11 |
I Carry!
Drives: 2013 CRT ZL1 Join Date: Jul 2011
tilt trailer!
I am a Modaholic!! Please Help!! Do Not feed my addicition....See build...
http://www.camaro5.com/forums/showthread.php?t=261540 From Oklahoma, Join us on Facebook https://www.facebook.com/groups/okcamaros/ |
#12 |
![]() Drives: ZL1 Gone but not Forgotten! Join Date: Mar 2015
#13 |
Chevy's "Rumble" Best!
Drives: 2015 ZL1 6 speed Join Date: Feb 2011
I bought this one for under $3k
Still need to carry 2x6 planks to get it up without scraping the splitter.
#14 |
2013 A6 ZL1
