Classic Industries
Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust
Old 09-13-2009, 04:44 PM   #1
ADM PERFORMANCE
214-228-8782
Drives: 2013 ZL1 #138
ADM Performance Highflow Intake Advantages
I put together a small list of reasons why our Intake has benefits of other designs.I made this available to aid in those not sure about what they are buying or looking to buy.I hope this helps you in your decision as we aim to please each and every style of customer from the basic bolt on to the most extreme power level customer.
ADM Performance Intake – Benefits
Benefit #1
Powder Coated finish of exposed aluminum parts.
Benefit #2
Lightweight aluminum parts and pieces. Aircraft quality stainless screws and fasteners.
Benefit #3
MAF/IAT sensor is relocated into the airbox itself, out of the engine bay hot air environment.
This permits the ECM to read cooler temps which translates into increased timing and more
power without triggering any knock retard. Increased timing means more horsepower.
Benefit #4
The ADM airbox location permits cooler air to be ingested from the factory scoop located
behind the grill on the driver side as well as around the washer bottle and fender well... Not
from the hot engine bay area.
Benefit #5
Future upgrading to turbos, superchargers, etc can still utilize the ADM intake system. This
means that no money is wasted now as this system has more flexability than many others.
So as you consider added engine mods in the future this intake system can remain in your car.
Benefit #6
Should you choose to de-mod your vehicle in the future most all of the parts can be utilized in
future applications. The ADM filter is a 4” universal type not specific to this intake only. The
ADM silicone couplers can be used on other custom applications as well. Even the exclusive
6061 100mm MAF housing is universal and could be used on other applications.
Benefit#7
ADM uses a Full 4” 100mm ID system from the filter to the throttlebody.
Benefit #8
The availibity for a “FULL RACE VERSION” which enhances the factory ducting system to TRAP and DIRECT a cold air stream directly into the SEALED AIR BOX
STANDARD STREET KIT INSTALLED ON A MAGGIE S/C CAR -
ADM PERFORMANCE is offline   Reply With Quote
Old 09-13-2009, 05:42 PM   #2
ADM PERFORMANCE
214-228-8782
A few pics of our components
Here are what some of the parts look like un installed -
T-6061 Aluminum 100mm Maf Housing
High Quality 100mm Silicone Hose
100MM Mandrel Bent .062 wall T-6061 Pipe
Aircraft Grade Stainless steel hardware
Black Powder Coated CNC Cut T-6061 Aluminum Airlid with Edgeseal
Black Powder Coated CNC Cut T-6061 Aluminum Side Panel With Edgeseal
Old 09-13-2009, 05:54 PM   #3
freemaSSon
Pat @ ADM PERFORMANCE
freemaSSon's Avatar
Drives: CGM SS/RS M6
"ENGINEERED to EXCEL"
The planning, engineering and execution of this airbox has to be one of the best products I have seen you put together, brother. I’ve been around to see A LOT of things you imagined then planned, engineered and executed. This airbox has to rank towards the top of all the things I’ve witnessed.
The results on the dyno and by some members at the track is CLEAR evidence that it just plain works. PERIOD!
"old age and treachery will always overcome youth and ambition"
author unknown
"There are two types of racers: cheaters...and losers."
Smokey Yunick
freemaSSon is offline   Reply With Quote
Old 09-13-2009, 06:01 PM   #4
Melson
Melson's Avatar
Drives: Wild Cherry
2010 RJT 2SS/RS L99 CAMARO
ARH 1 7/8" LT HEADERS W/ HF CATS
MAGNAFLOW 3" COMP EXHAUST
ADM PERFORMANCE CAI
ADM PERFORMANCE CUSTOM TUNE
ADM PERFORMANCE PORTED THROTTLE BODY
ADM PERFORMANCE TRANS COOLER
3.45 GEARS
BMR TRAILING ARMS
Melson is offline   Reply With Quote
Old 09-13-2009, 06:39 PM   #5
ADM PERFORMANCE
214-228-8782
Originally Posted by Melson View Post
I agree... with both.This system is leaps and bounds better than our Trailblazer SS systems that dominated that market.
Thanks guys
Andy
Old 09-13-2009, 07:00 PM   #6
Number_9
Number_9's Avatar
Drives: 2010 2SS/RS L99
x2
Props to ADM Performance... I am loving the performance improvement and it looks good too.
Number_9 is offline   Reply With Quote
Old 09-13-2009, 07:41 PM   #7
Mike TexaSS
Drives: 454 LS7 Camaro SS
Fit and finish was top notch! When I opened the box the 100mm maf housing was a bonus!
Mike TexaSS is offline   Reply With Quote
Old 09-13-2009, 08:04 PM   #8
pharmd
Master of Medicine
pharmd's Avatar
Drives: 2012 VW GTI, 2007 TBSS, 2002 Camaro
Could you retrofit this to a TBSS...how hard would it be for you to create "this" type of system for the TBSS?
pharmd is offline   Reply With Quote
Old 09-14-2009, 06:12 AM   #9
ADM PERFORMANCE
214-228-8782
Every part but the box.
Old 09-14-2009, 06:14 AM   #10
ADM PERFORMANCE
214-228-8782
Exactly!
Old 09-14-2009, 08:43 AM   #11
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
Crowley is offline   Reply With Quote
Old 09-14-2009, 08:51 AM   #12
2010 2-Tone
2010 2-Tone's Avatar
Drives: 2010 RY 2SS with Custom Stripes
This is the unit I will be going with in the next 2 weeks. Looks like it is head and shoulders above the comp.
Andy, How much shipped?
2010 2-Tone is offline   Reply With Quote
Old 09-14-2009, 09:05 AM   #13
2010 2-Tone
Andy,
Is this a dry or wet filter?
Old 09-14-2009, 10:19 AM   #14
madmaxx18
madmaxx18's Avatar
Drives: 07_tundra/2010_IBM_2ss/rs/sc
I also am curious to know does it fit good or does it have gaps like the others I'm seeing. Veraram and roto fab both have gaps and are not sealed nearly as well as I would like to have seen them fit. All the pics show gaps at both corners. The silicone tubing looks like a condum LOL. Other than that it looks like a very nice setup.
madmaxx18 is offline   Reply With Quote
Old 09-14-2009, 11:49 AM   #15
Number_9
Number_9's Avatar
Checked my on my lunch hour today... I was pretty sure and my-recheck confirmed... no gaps here.
Old 09-14-2009, 11:50 AM   #16
Michael_Js
SoCal C5 Family Member
Michael_Js's Avatar
Drives: 2010 Camaro SS/RS - Black w/IOM; 6M
Send a message via AIM to Michael_Js Send a message via MSN to Michael_Js
I will try to take pictures of mine, but when installing, I had gaps along the fender well and against the frame rail. It's not easy to get in there and get pictures
2010 Black 2SS/RS; 6M; IOM, GFX, sunroof; ADM Race CAI; Zoomers CB; Viper Alarm; Pdaft F&R sways, Adj Endlinks, Rtrailing arms, Camber kit, strut brace, Front Trailing Arm Bushing; SLP Skip-Shift Elim; Tinted lights/windows; Hurst Short-throw; LoJack; Door & Dash ABL Mods; Subthump; JBA Shorty headers; AACStyle LEDs; Stillen DS rotors, Hawk Ceramic pads; Havoc Blk Chrome wheels: 20x9s; Lingenfelter Blk Al Pedals; RevXtreme Catch Can; Goodridge SS lines; Ported TB; RK Sport hood; Hotchkis chassis brace; KW V3 coilovers;
Michael_Js is offline   Reply With Quote
Old 09-14-2009, 11:51 AM   #17
Michael_Js
Michael_Js's Avatar
Originally Posted by 2010 2-Tone View Post
Andy,
Dry filter...
Old 09-14-2009, 01:23 PM   #18
ADM PERFORMANCE
214-228-8782
Andy,
We use K/N and S&B filters.Both require cleaning intervals and re oiling.
Andy
Old 09-14-2009, 01:41 PM   #19
Michael_Js
Michael_Js's Avatar
Hmm...didn't see anything in the instructions about oiling the filter. Can you provide details? What cleaning intervals? What kind of oil & how much?
I installed the way it came - out of the box.
Thanks,
Michael J.
Old 09-14-2009, 09:43 PM   #20
Kyle2k
LVL 50 Troll Stomper
Kyle2k's Avatar
Drives: 2010 Camaro
Do you have any pictures of the full race version ducting to show yet ?
Kyle2k is offline   Reply With Quote
Old 09-14-2009, 09:51 PM   #21
ADM PERFORMANCE
214-228-8782
Thanks,
Michael J.
It comes pre-oiled.
I recommend cleaning every 3rd oil change.
Old 09-14-2009, 11:24 PM   #22
Michael_Js
Michael_Js's Avatar
Thanks!
Old 09-15-2009, 07:26 AM   #23
Michael_Js
Michael_Js's Avatar
I posted this elsewhere too. You can see the large gap against the fender, and there's a large gap against the frame rail - which is harder to see. I pushed it ALL the way forward and all the way down, but the 1 connection point is keeping it from going forward and further down.
Old 09-15-2009, 07:42 AM   #24
freemaSSon
freemaSSon's Avatar
You do not have it installed correctly. The air box is made to go further forward than you have it mounted.
Andy was going to take some additional pictures this morning to show the proper installation. The rubber lining on the leading edge of the metal will uniformly press against the fender liner. The mounting angle bracket on the plate facing towards the back of the car will mount on the factory utilized airbox mounting post.
The additional pictures should help to clarify the proper install position.
author unknown
Smokey Yunick
Old 09-15-2009, 08:30 AM   #25
Michael_Js
Michael_Js's Avatar
Well, I hope they help! I thought I pushed it as far forward as it would go - there seems no way to get it to go further forward while it's connected to the 1 mounting angle bracket, or further down...The side piece (with the air filter pipe coming it) is jammed against the front. I can't see how it would go further - which is the only way to get the fender liner & side piece to line up.
I'll wait for the additional pictures :(
LS3 engine specifications Tran Wiki 3 10-06-2010 10:56 PM
ADM Performance CAI Installed and Rocking! Number_9 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 3 09-13-2009 08:50 AM
Teaser pics of the TVS 2300 and ADM Street Intake Crowley Camaro Photos | Spyshots | Video | Media Gallery 9 08-22-2009 10:44 PM
Hardcore racers rejoice!! GM Performance Parts to offer new Camaro body in white radz28 5th Gen Camaro SS LS LT General Discussions 23 12-22-2008 09:57 AM
existing LS3 tuners themossman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 7 10-30-2008 12:53 AM
