11-17-2015, 12:27 AM | #1 |
Drives: 2012 1LT/RS Join Date: Sep 2011
Scosche kit install issue
Hello Everyone,
I hope you are all doing well and thank you in advance for any help you can offer. I'm installing the scosche GM5201AB into my 2012 camaro 1lt rs without boston acoustics setup. Radio I'm installing is a pioneer avic8000nex. My issues. 1) ive followed the instruction saying to let the car go into sleep mode and then plugged the 8 and 24 pin connectors in then cycled the ignition from off to run twice but regardless the unit will not control the HVAC and the windshield Defroster is always on and won't turn off. Also when I hold set to select my vehicle only ford f150,edge,Edge and Explorer show up on the list. Also my touch screen does not show the bottom Defroster options. Any help with this would be greatly appreciated. I can't figure it out and I'm about to lose it. Last edited by Rb737; 11-17-2015 at 01:16 AM. |
11-17-2015, 07:00 PM | #2 |
Drives: 20’ Chevrolet Camaro 2SS 1LE Join Date: Jan 2009
You may have a defective unit.
11-18-2015, 09:33 AM | #3 |
Drives: 2012 Camaro ZL-1 SIM Join Date: Sep 2008
I agree that you likely have a defective unit. There have been a number of issues with the kit, detailed here:
http://www.camaro5.com/forums/showthread.php?t=246752
11-18-2015, 07:56 PM | #4 |
Drives: 2014 2LT/RS Ashen Gray Metallic Join Date: Nov 2011
Your kit seems to have the wrong software loaded......
11-21-2015, 05:43 PM | #5 |
BUMBL Z
Dash kit could need a firmware flash. Contact scosche to get the correct firmware and update instructions. The dash unit is also incredibly flawed to begin with, which is a shame because the alternative (the metra kit) just doesn't look as nice
Sold: 2015 ZL1 M6, Rotofab Intake, LS3 throttle body, 2.55 Upper/9.17 Lower, Custom Camshaft, DMS Reinforced Brick, ID1050X, 1 7/8" Headers, ProSpeed HX/Reservoir, DSX Aux Pump/Flex Fuel Sensor, E85, McLeod RXT, BMR 1" Drop, 680rw 93/750rw E85, Tuned by CSP
Sold: 2010 2SS, some bolt ons, 415rwhp/400rwtq |
11-28-2015, 03:33 AM | #6 |
Drives: 2013 Camaro 2SSRS Black on Black Join Date: Nov 2015
scosche unit does not support cars with factory nav... could be the issue you are having
11-28-2015, 02:12 PM | #7 |
Hey Everyone, thanks for the posts and for the help. I ended up getting a hold of scosche and they sent me new correct firmware to flash into the unit. Seems my unit had the incorrect firmware on it which was actually for a Ford. I did the update wit ha USB and now it works like a charm.
Thanks again for all the help. |
11-28-2015, 07:34 PM | #8 |
Np
02-06-2016, 08:24 PM | #9 |
Drives: 2011 2SS/RS Victory Red Join Date: Aug 2011
I love the internet.... Mine is doing this as well in a 2011, I will flash it tomorrow and cross my fingers!
Updates: BTR Stage 2 VVT Cam Kit w/Smith Brothers Trunnions, Fluidampr, RX catch can, B&M Trans pan mod, Kooks Black Headers, Borla S-tunes, Eibach Multi-Pro-R2 coilovers and Swaybars, BMR Full Bushing kit with Toe and Trailing arms, RB Rotors w/EBC Pads, GForce 1400 Axles (now on order). AVH-X5800BHS in Scosche GM5201AB. |
02-06-2016, 09:20 PM | #10 |
either firmware or defective unit...
"How do u keep it under the speed limit? YOU CANT HAHAHAHA" |
02-08-2016, 11:38 AM | #11 | |
I just got this from Scoshe Tech Support.
Greetings, You’d want to put your AC panel into demo mode in order to perform the update. Please follow these steps in sequence in order to so and perform the update: 1. Download the firmware, remove the files from the folder, and place the 2 files on an empty flash drive. 2. Turn the vehicle off. 3. Disconnect the 8 pin connector from the back of our UAC kit. 4. Plug the flash drive into the USB port. 5. Turn the car to the “On” position. 6. Press and hold the fan + and the power button (top left and bottom left buttons) on the UAC kit. 7. While pressing and holding the two buttons on the kit, plug the 8 pin connector back into the kit. 8. You should get the Scosche “splash” screen and the kit should take the firmware update. (You can let go of the two buttons once you see the unit power on.) 9. The screen will count up to 100 and say “Done” if successfully updated. If it says “Done without counting up to 100 then it already had the most up to day firmware. If it says “Failed” try again. Excuse the blurriness of the video, but this link demonstrates a successful update. This should allow you to successfully perform the update. If you are still having issues, you might want to try using a different flash drive. We have encountered instances where users have had to use 2 or 3 different flash drives before they successfully loaded the firmware. After performing the update, you’ll most likely have to cycle the key so the touch screen module can re-learn the vehicle. Turn the car off, then cycle the ignition 3 times, the first 2 times from off to run or accessory and then actually start the vehicle on the 3rd attempt. After starting the vehicle press and hold the “Set” button for 10 seconds. It should take you to the vehicle selection screen and make sure to select Camaro. Ensure all the vehicle trim and AC options are correct. Best Regards, Tony L Customer service Scosche Industries Inc. 1550 Pacific Ave, Oxnard, CA 93033 805-486-4450 x140 Office 800-363-4490 x140 Toll Free 805-486-9996 Fax tonyl@scosche.com ACCESSORIES FOR LIFE DRIVEN BY SOUND consumer technology | car audio | health + fitness ______________________________ YouTube Link: |
02-09-2016, 08:31 PM | #12 |
No Go... It updated but still nothing.
