01-07-2017, 05:44 PM | #1 |
Drives: New : 2017 SS 1LE Old: 2012 TTRS M6 Join Date: Oct 2015
Negative Effects of reducing overall wheel/tire diameter
As you all know.. the V8 M6 is geared towards the taller end of the spectrum for fuel economy...
I'm going down to a 19" wheel and tire combo to strip down some weight... I was going to go from 285/30R20 to 285/35R19 and 305/30R20 to 305/35R19 then I got to thinking... wouldnt it make more sense to go to 285/30R19 and 305/30R19? The overall diameter would be reduced... slightly increasing final drive ratio... giving better midrange torque and faster spool up... sure... fuel economy would suffer the other way... Is it really difficult to reprogram a new tire diameter so that the speedo/odometer becomes recalibrated? I will post this now and then add the tire diameter calculations when I get them all together heres the formula: Tire Diameter = 2 x (section width/25.4) x (aspect ratio/100) + rim diameter
. https://www.wheelwell.com/profile/56...ed9c3a/garage/ . . Project 1LE Wraith: http://www.camaro6.com/forums/showthread.php?t=474068 Last edited by aa406079; 01-08-2017 at 03:11 AM. |
01-07-2017, 05:57 PM | #2 |
http://www.onallcylinders.com/2015/0...l-drive-ratio/
EAGLE F1 SUPERCAR 3 Extreme Performance Summer Rear: 305/30ZR20 2x 305/25.4 x 30/100 + 20 = 27.2" 27.2" total diameter (rears) Front 285/30R20 2x 285/25.4 x 30/100 +20 = 26.7" 26.7" total diameter ( fronts) total rake ... .5" front to rear diameter difference 1.87 % ( important for PTMS) drop an inch from both.... 26.2/25.7= 1.94 % ( I would like to believe this very minor change shouldnt affect PTMS which relies on the difference in tire diameter to NOT change much to function properly... the Corvette guys claim square set ups really mess up the PTMS since its not originally calibrated for a square set up...) if I go with Michellin Super Sports ( since the numbers the new PS4S tire arent out yet) a 305/30R19 would be exactly 26.2" 1" smaller diameter... 285/30R19 will be 25.7" ... preserving the 1/2" rake and diameter differential for PTMS the formula means that the size should be exactly 1" smaller on the fronts as well... keeping the same rake from factory... so... now I would have a car effectively lowered 1/2" ( and that better than springs because it includes a lower CG for the unsprung rotating weights) and a higher final drive ratio of... 27.2/26.2 x 3.73 = 3.87 final drive ratio .... ...instead of the stock 3.73 thoughts? comments? predictions of disaster? essentially the speedo and the HUD will read 3.8% faster than it should... Will an aftermarket speedometer calibration affect warranty?
. https://www.wheelwell.com/profile/56...ed9c3a/garage/ . . Project 1LE Wraith: http://www.camaro6.com/forums/showthread.php?t=474068 Last edited by aa406079; 01-20-2017 at 08:01 AM. |
01-07-2017, 06:07 PM | #3 |
Drives: 2019 ZL1 1LE Join Date: Sep 2010
I won a Solo National Championship in my 2016 M6 SS running 275/35-19, it's fine.
Less rotating mass, better gearing, lower Cg. All good things. |
01-07-2017, 06:21 PM | #4 | |
I used to be Dragoneye...
On the other hand, as rotis said: lower rotating mass means you'll feel like the car accelerates quicker. Because it does. And the suspension won't need to work quite as hard to absorb bumps. Stopping distances may decrease as well (depending on the tire). Any flash to the computer will appear if a dealer ever looked for it. Which they are required to do before GM will approve most powertrain warranty repairs. Typically...if they see the computer was changed in any way, they will void the warranty. |
01-07-2017, 07:05 PM | #5 | |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
01-08-2017, 02:52 AM | #6 |
Sounds like its time to pretend I own a C7 Grandsport and head over to the "Ask Tadge" section and ask them that very question in regards to PTMS
Perhaps this is something I'll have to take up with GM and my Dealership manager... they usually have tune flash counters to snoop on non OEM tunes... perhaps I can get the dealer to supervise the recalibration "tune" to confirm its not changing any other powertrain parameters and as long as the tune flash count stays at 1 I should be OK... IF they will be open to that suggestion...
. https://www.wheelwell.com/profile/56...ed9c3a/garage/ . . Project 1LE Wraith: http://www.camaro6.com/forums/showthread.php?t=474068 Last edited by aa406079; 01-08-2017 at 05:48 AM. |
01-08-2017, 06:45 AM | #7 | |
had to redo the calculations based upon Michellin PS4S tires initially only be available in 305/30R19 285/35R19 295/30R19 ]http://www.onallcylinders.com/2015/07/30/tire-math-calculating-the-effects-of-tire-diameter-on-final-drive-ratio/[/url] EAGLE F1 SUPERCAR 3 Extreme Performance Summer Rear: 305/30ZR20 2x 305/25.4 x 30/100 + 20 = 27.2" 27.2" total diameter (rears) Front 285/30R20 2x 285/25.4 x 35/100 +20 = 26.85" 26.7" total diameter ( fronts) total rake ... .5" was original... now reduced to .35" front to rear diameter difference 1.87 % ( important for PTMS) drop an inch from both.... 26.2/25.85= 1.01 % ( I would like to believe this very minor change shouldnt affect PTMS which relies on the difference in tire diameter to NOT change much to function properly... YET while only 1% difference its almost double the %...the Corvette guys claim square set ups really mess up the PTMS since its not originally calibrated for a square set up...) if I go with Michellin Super Sports ( since the numbers the new PS4S tire arent out yet) a 305/30R19 would be exactly 26.2" 1" smaller diameter... 2x305/25.4 x 30/100 + 19 = 26.2" 2x285/25.4 x 35/100 + 19 = 26.85" ( BIGGER THAN FRONTS... definite NO NO) 2x295/25.4 x 30/100 + 19 = 25.96" ( half the normal rake ... guess it will have to do) Looks like I would have to go with 295/30 fronts to keep the (reduced) rake so... now I would have a car effectively lowered 1/2" ( and that better than springs because it includes a lower CG for the unsprung rotating weights) and a higher final drive ratio of... 27.2/26.2 x 3.73 = 3.87 final drive ratio .... (unchanged) ...instead of the stock 3.73 The other option is to go 295/30R19... but perhaps that might mess up the handling of the car by adding too much front tire.... are these changes minor and am I overthinking this?
. https://www.wheelwell.com/profile/56...ed9c3a/garage/ . . Project 1LE Wraith: http://www.camaro6.com/forums/showthread.php?t=474068 Last edited by aa406079; 01-08-2017 at 11:56 PM. |
01-08-2017, 07:00 AM | #8 |
Drives: 2017 Camaro 1SS Join Date: Aug 2016
Keep in mind that the numbers on the sidewalls are only an approximation. The true diameter of the tire does not necessarily match the theoretical, you'll need to take careful measurements if you want the real numbers.
01-09-2017, 09:38 PM | #9 | |
Drives: Hard Join Date: Feb 2016
I'm running 285/35-19's square. No PTM/rev-match freak-outs, and you can easily feel the effects of each benefit mentioned above.
'16 2SS, 6MT, MRC, NPP, sways, square 285's—and an ear-to-ear grin!
01-09-2017, 09:43 PM | #10 |
Drives: 2016 2SS, GRed/Blk MT6, NPP, MRC Join Date: Sep 2012
How does the rim size impact your figures? 9, 10, 10.5, 11? I've been contemplating 18 and 17 for snow tires when I read your post.
