![]() ![]() ![]() ![]() ![]() Drives: 550+RWHP 2010 camaro Join Date: Sep 2007
new hptuners custom O/S
latest hptuners software has an upgrade-able 2.5bar operating system for the LS3,L99, now you can have an actuall VE table and cooling fan control below 192*f
- 2.5 bar (255 kPa) max MAP sensor support (calibration capability for GM 0-5V linear MAP sensors) - Rescaled MAF High Freq table supports up to 15400 Hz with 300 Hz resolution, also supports airflow up to 1024 g/sec - New VE tables with 33 x 33 cell resolution each and configurable MAP and RPM axes (choose your own resolution) - Charge Temperature based VE multiplier table, configurable axis - TPS based VE multiplier table, 33 x 17 cells with configurable TPS and RPM axes - MAP referenced Boost Enrich table - Boost Enrich MAP threshold and hysteresis value - Both MAF and Speed Density mode supported - Boost based fuel cut, selectable MAP threshold cuts fuel to all cylinders when exceeded - Rescaled fan temperature axis 163-250F (73-121C), stock is 192-250F (89-121C) you can use the 2.5 bar upgrade with the factory map sensor in N/A form since the ve/map table is fully adjustable, i just copied my vertual ve table from bluecat eq program to a junk ls2 file then copied and pasted that to my adjusted ve table, then used the interpolate function to fill in all the 0's because the 2.5bar table is 2 times as big as the ls2 style table
Banned
Drives: 2002 LS1 swapped into a 1994 Z Join Date: Sep 2009
Good news!
just got around to playing with the new 2.5bar O/S,, really nice to have an actuall VE table, and the new cooling fan controls works great
and no more resetting the pcm by disconnecting the batt or pcm after every ecm write!
![]() Last edited by camaro1; 11-20-2009 at 03:24 AM. |
![]() Drives: 2010 RJT M6 bone stock ... for now Join Date: Oct 2009
Thanks for the news, saw on HPTuners where you're having problems with your gauge pack, what is it doing?
the oil temp gauge is off about 40*f and the trans temp is off about 25*f, the gauges are just a 3 wire set-up, +, -, and serial data from the ecm,
if you compare the data for oil temp and trans temp they are way off has also happened to other camaro's i tuned,, i think most people wouldnt notice it if you were not watching the scan data while looking at the gauges the data for the gauges comes straight from the ecm serial data line, something changes after flashing with hp tuners and the gauges no longer read correctly,, i was actually in contact with an engineer from GM and he has seen this issue before with aftermarket tuning software
![]() Last edited by camaro1; 11-21-2009 at 09:57 AM. |
#6 |
![]() Drives: 2010 Inferno Orange SS Join Date: Sep 2009
Have you figured out or has there been any progress on the gauge issue?
2010 Camaro SS, M6, MTI shifter and sway bars, GM quarter flares, Corsa catback, Roto-Fab CAI, 30% tinted windows, Lloyd's custom mats, Hawk ceramic pads, Pedders lower coils, Magnuson supercharger with 3.6 pulley, BMR trailing arms & toe rods, Kook's LT's1 7/8 w/cats, Lingenfelter/SLP billet pedals, KW V'3 Coilovers, RevExtreme catch can, ---Ordered--- IconZ LS7 9 & 11" polished wheels!. Dyno'd 563.05 HP, 543.86 Torq.
#7 |
car is in storage now, hptuners thinks it was fixed in the latest beta software, ill have to wait till spring to find out
| Custom Magnaflow Exhaust | buddylok | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 49 | 05-16-2016 12:02 PM |
| Custom Painted Stripes Underway for Bumleb's Rally Yellow 2SS | RumbleBeeSS | Cosmetics and Lighting Modification Discussions | 140 | 06-20-2010 01:12 AM |
| SCT Xcal 3 w/ Custom Tunes now available!!! | Meister@Torq | V8 Bolt-Ons & Tunes | 17 | 12-24-2009 06:02 PM |
| The Official Thread about Custom Paint! | pinkcamaro10 | Cosmetics and Lighting Modification Discussions | 30 | 03-28-2009 08:17 PM |
