04-22-2018, 03:25 PM | #1 |
Vibration under power
Ok, so here I go. 2011 Camaro SS. cam, headers, intake manifold, heads, trunion kit, rpm transmission, eaton true track, 391 gears, DSS axles, underdrive pulley, variram cai and tune. The car started vibrating under power in 3rd, 4th, 5th and 6th gear around 3500 rpm. Doesnt do it during coasting or mild driving. Rear, axles and trans are new. Has new plugs also. Checked the axles and Drive shaft play and center driveshaft bearing and all looks good I guess. Ant ideas ?
04-23-2018, 04:33 PM | #2 |
Anyone ?
04-23-2018, 05:35 PM | #3 |
Drives: 2010 2SS LS3 and 1978 STROKER 383 Join Date: Feb 2018
Check rubber bushing on the shaft.
...between transmission and axle.. |
04-25-2018, 05:58 AM | #4 |
vibration
I did check the bushing, it does have alot of play, is that normal ?
04-25-2018, 06:26 AM | #5 | |
376 cubic inches of fun
Did you uncouple the prop shaft and then re-use the nuts and bolts? They need to be replaced each time. Now that you have looseness, you probably need to replace the coupler as well as the nuts and bolts. |
04-26-2018, 08:08 AM | #6 |
I only removed the heat shield and pushed on the Drive Shaft, which moved a lot inside if the bearing.
04-26-2018, 04:37 PM | #7 | |
You should check the bolts. If they are loose, don't tighten them, replace the bolts and the nuts. But also the coupler could be damaged if the bolts have been loose. |
04-26-2018, 08:39 PM | #8 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
Try backing off the dosage. Oh wait, I thought you said vibration under powder!
05-01-2018, 02:23 AM | #9 |
Drives: 2013 Camaro 2SS Inferno Orange Join Date: Apr 2015
having same issue i can start to fill the vibration around 80 and it gets worse and worse the faster you go.
let me know if you figure it out ive spent thousands already chassing that damn vibration and nothing |
05-01-2018, 08:07 AM | #10 |
Drives: [COTW 8/3/15] 2010 Camaro SS L99 Join Date: Mar 2015
Check your tires for proper balance. Might have lost some weights or flat spotted a tire. I had the same problem around 70 MPH and above, my rear tires were out of balance. Balanced them and the problem was gone. Cheap easy check to eliminate..
A Little bit of power. ALL WORK DONE BY ME!
Just added 2021 ZL1 1LE to the Stable! https://www.camaro5.com/forums/showthread.php?t=418273 |
05-01-2018, 08:46 AM | #11 | |
Drives: 2014 2SS blue Join Date: Jun 2016
I'm with George. If you've been flogging it, probably time from a U-joint replacement as well as the middle rubber support damper. You might consider a one-piece custom driveshaft and a safety hoop, if you're flogging it and you value your body. Here's an article on a diff and axle upgrade, but it touches on the driveshaft replacement. http://www.lsxmag.com/tech-stories/d...-rearend-woes/
05-01-2018, 09:07 AM | #12 |
Drives: 2018 1SS M6 Join Date: Nov 2014
You have quite a few modifications to your driveline. I guess the first question that needs to asked is how many miles on these modifications prior to the start of the vibration?
