10-18-2018, 12:30 PM | #1 |
Winter storage!!! (1st winter with Camaro)
Hi everyone! Hope you are doing well. Sad to say but winter is coming up pretty quickly. As this is my first winter with my Camaro I need some tips on storage. What do you all recommend me to do?
10-18-2018, 12:38 PM | #2 |
Retired from Car mfrs....
Drives: 2LT RS/HR-V Join Date: May 2013
store inside? outside? AC power avail?
need more info.... |
10-18-2018, 12:47 PM | #3 |
10-18-2018, 12:52 PM | #4 |
wash it/cover optional
inflate tires to 40 fill with 90+ octane, for one winter, sta bil not needed, but ok if you want put a $30 battery tender on batt, connect thru the front engine bay do not start the car until youre ready to use it again. |
10-18-2018, 01:56 PM | #5 |
Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
https://www.camaro6.com/forums/showthread.php?t=509495
https://www.camaro5.com/forums/showthread.php?t=254887 https://www.camaro5.com/forums/showthread.php?t=23114 https://www.camaro5.com/forums/showthread.php?t=23114 https://www.camaro5.com/forums/showthread.php?t=421737 Go up to the search pulldown and type 'winter storage' into the Google search field (the threads & posts search sucks). Several pages of threads will come up giving you all the information, and disinformation, you will need
10-18-2018, 03:06 PM | #6 |
Drives: 2018 SS 1LE Join Date: Aug 2017
Hello Michibro. Here is the list of things I do.
Wash / Wax the outside. Vacuum / Clean the inside thoroughly. I turn air re-circulation on so it shuts the vent to the outside. Fill the gas tank full. I put a fuel stabilizer in it before I drive it home from the gas station. Change the oil. This year I also changed the diff fluid and trans fluid but it is not necessary. Put it on jack stands on all 4 corners. I use rubber blocks between the jack stands and the frame. Remove wheels. I also remove the windshield wipers. Probably not necessary I just like the overkill. Install trickle charger. Shove towels or what have you in the exhaust pipes (remember to remove these in the spring) I have a plastic cover I put on it. Then say goodnight and let her hibernate for the winter. |
10-18-2018, 03:36 PM | #7 |
This is why the Camaro6 forums is my go to for questions thanks guys
10-18-2018, 03:41 PM | #8 |
36.58625, -121.7568
I fill the Gas full, pull it into the garage, and walk away for 3 months.
10-18-2018, 04:02 PM | #9 | |
Drives: '19 2SS M6. Join Date: Aug 2018
Suspension is not designed to be stored full droop. Puts strain on bushings. This step is controversial........I never have done it and no problems. Why remove wheels? If you are worried about flat spotting, (Not really an issue with modern tires stored for a few months) just pump up the pressure if you are really worried. Now, what if your house caught fire? How would you move the car out? (I know, not a great possibility but hey, you never know) Plastic cover? You want that to breath and not trap moisture. People really over due storing a car for a few months. Relax!
2019 2SS, Shadow gray, 6mt, NPP, Magneride, Bose.
10-18-2018, 04:03 PM | #10 |
Yup, more important things to worry about!
10-18-2018, 04:54 PM | #11 |
Drives: '17 2SS convertible'20 Yukon Denali Join Date: Nov 2011
Be sure to include an oil change before you put it away. You don't want old oil with possible contamination on the engine parts. I've always done that with my boat even though not many hours on it (455 Olds).
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers Delivered: 08/15/2016 #TeamBeckyD |
10-18-2018, 05:02 PM | #12 |
Just got my oil changed and probably going to put another 200 miles from now till storage. Will the oil be fine?
10-18-2018, 06:12 PM | #13 |
it will be fne......
10-18-2018, 06:22 PM | #14 |
Drives: 2017 1SS Hyper Blue Join Date: Apr 2017
Take the battery out and store inside your house. I used to be an advocate for just hooking up the battery tender, did it forever on my Harley’s, but last year I put the Camaro on a tender and in spring, it started just fine, but after about a month the battery was shot. Would die intermittently. Only 7k miles on it at the time. 😡
