Old 12-01-2009, 06:31 PM   #1
mrray13
Drives: 2010 1LT RS Rally Yellow
JBA shorties just ordered
Yep, just ordered from MRT! Hopefully will see them soon, will do a few dyno runs then too!! Can't wait for this upgrade!!
mrray13 is offline   Reply With Quote
Old 12-01-2009, 06:42 PM   #2
mike25
mike25's Avatar
Drives: 2012 Camaro 2SS/RS
i wonder what ever happened to them posting results of their dyno?
2LT/RS M6 CGM VIN#53104 SOLD
2012 Black 2SS/RS w/ Hurst-
Mods:
Corsa catback, SSE, Vararam
mike25 is offline   Reply With Quote
Old 12-01-2009, 06:45 PM   #3
mrray13
LOL, good question. Since JBA shorties seem to make good power on just about everything I've seen them on, I went ahead and took a chance, lol.
I just watched the BBK vid about the LT headers that they are going to make for the v6. On their dyno pull, the car barely reached 70mph before it redlined. I wonder what gear they did their pull in? I made mine in 4th, got it to hit the limiter, 155mph. Wonder if doing the pull in 3rd would change things?
Old 12-01-2009, 06:46 PM   #4
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
Mmray, i cant wait to see what youll end up doing to your car. Going to be a killer 6 thats for sure
Old 12-01-2009, 06:58 PM   #5
mrray13
TJ..I have set a goal of 300rwhp and 300lbft of torque at the ground, naturally aspirated, if possible. If I can't get those numbers with axleback, shorties, intake and a tune, then I'm going balls out and getting a STS turbo sytem and tune!! Then I'm shooting for the stars, lol, 300rwhp be damned!
Seriously, I want 300^2 as I've come to call my goal. I would like to do it NA, as it would make for a sick, streetable car. Of course, n2o has been entertained as well. I think the 300^2 is reachable, the tuner is going to be the big question.
Old 12-01-2009, 07:09 PM   #6
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
i think you will reach 300, but i hope you dont.. STS sounds too good
Old 12-01-2009, 07:10 PM   #7
mrray13
LMAO, that's what the guy who owns the dyno says!!
Old 12-01-2009, 07:27 PM   #8
marley.
OCD
marley.'s Avatar
Drives: 2014 2SS/RS 1LE
I want to order the JBAs but wasn't really wanting to install them myself. Most things I will do myself but these I would probably want to have an exaust shop do. So I went to my most repuatble local exhaust shop, the only one i will let touch my cars and he said he won't install them. He said it gets in to way too much work and he will not attempt them on new cars. So I either have to go out of town for my install or try it myself.
marley. is offline   Reply With Quote
Old 12-01-2009, 07:35 PM   #9
Beauwulf
Beauwulf's Avatar
Drives: '10 LT RS A6 & '04 Acura RSX Type S
Man... shorties take about an hour to install on this car! There's tons of room to work in there... you could do that yourself if you have a decent set of sockets and extensions!
Beauwulf is offline   Reply With Quote
Old 12-01-2009, 07:35 PM   #10
shad2009
"Cassie"
Drives: 2007 Tungsten Grey Mustang GT
Send a message via AIM to shad2009 Send a message via Yahoo to shad2009
to have these installed, do u just remove the old ones then add these, or do u have to order other parts as well?
shad2009 is offline   Reply With Quote
Old 12-01-2009, 07:46 PM   #11
Beauwulf
Beauwulf's Avatar
I always use new gaskets but I don't know for sure if they come with the kit or not. That should be it.....
Old 12-01-2009, 07:50 PM   #12
marley.
OCD
marley.'s Avatar
Cool man, thanks for the info. I will prolly just do it myself. I usually take on stuff like that but thought this might be tough. I plan on doing my own lowering so I should be able to handle this.
Old 12-01-2009, 07:53 PM   #13
Beauwulf
Beauwulf's Avatar
Just make sure you have anti-seize and and a torque wrench handy (aluminum heads) and you'll do fine.
Old 12-01-2009, 07:57 PM   #14
Jason@Phastek
Jason@Phastek's Avatar
Drives: 2010 Camaro
Send a message via AIM to Jason@Phastek
If they dont come with gaskets you should be able to reuse the factory gasket.You will usually find out that most Performance Shops will reuse the stock gasteks before they use the gaskets that actually come with the header kits. The factory ones are usually steel gaskets and seal very well. Yes even though they have been used you will find them to still seal very well. Alot of aftermarket Header companies will send out gaskets with their headers, but they are usually a material type gasket that will harden a leak over time. The factory ones are usually the best because the Auto Manufacture can afford to tool up for a quailty gasket that is made to last.
Jason@Phastek is offline   Reply With Quote
JBA Shorties coming for V6 HaveBlue Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 62 11-25-2009 01:19 PM
JBA Shorties + MRT Exhausts deljaso Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 8 11-01-2009 10:13 PM
Options that were not available when I ordered my Camaro SS/RS. OHIOSS 5th Gen Camaro SS LS LT General Discussions 7 10-01-2009 06:22 PM
Just Ordered - Odd Feeling Verio Camaro Price | Ordering | Tracking | Dealers Discussions 6 04-20-2009 01:45 PM
Who's ordered, moved posts. CLOSED zq8colorado04 Camaro Price | Ordering | Tracking | Dealers Discussions 112 01-05-2009 03:21 PM
