Old 03-27-2010, 08:25 PM   #1
TRSS2
TRSS2's Avatar
Drives: 2010 Chevy Camaro 2LT Black RS
**SOLVED** How to run wire from outside the cabin to inside without drilling firewall
So... Fantastic news for anyone on the brink of attempting any DIY work that involves wiring from anywhere outside the cabin and needs to be wired into the interior WITHOUT DRILLING THROUGH THE FIREWALL!!! Without further a due .
1st thing first open your driver side door
I already pulled off a trim piece in the above picture, its real easy, on both ends pull OUT NOT UP 1ST! there is a tab on either end that will be released so that you can pull the trim directly up.
Next, push some wire into the hole towards the front of the vehicle
Next, its best/easiest if you take the wheel off for ease of access, there are a few star bits and some push pins remove those, then look for a circular plastic plug, pull it out
Next, you will need a flash light, look in the hole, you will see the wire is in there but you will need something to get it out, i used one of those little flexible grabbing tools
grab the wire pull it out, then you will need to poke a small slit in the plastic circular plug with a knife or something
then you can shove the wire through and go where ever you need to go with the wire!! It would be a good idea put some sealant, superglue, or silicone to fill the slit so no water/debris get in Its amazing, for those of you who do not want to breach the firewall, and better yet its EASY!
If anyone has any questions I will try my best to answer them, but I am somewhat of a novice, I stumbled onto this resolution in the midst of my frustration over contemplating to drill a hole in the firewall. Hope this helps someone.
2010 2LT/RS Black(exterior) on Black(Interior Leather) on Black(Flat Black Powdercoated Rims)
AAC interior red dome lights, footwell lights, SMD wheel well lights, led pods, afterburners(SMD), RED/WHITE halo headlights and fog lights, Nite Rider scanner times 2, illuminated bowtie, T-REX black phantom billet grill upper and lower, had vinyl blackouts-they turned out to be illegal . Soon to have LTLAudio door projectors.
Last edited by TRSS2; 04-27-2012 at 11:09 PM. Reason: moved photos on photobucket, therefore broken links for pics in post... resolved now
TRSS2 is offline   Reply With Quote
Old 03-27-2010, 08:30 PM   #2
HeavyD
HeavyD's Avatar
Drives: 1SSRS RY L99
Excellent! When there is will, there's a way!
HeavyD is offline   Reply With Quote
Old 03-27-2010, 09:11 PM   #3
orange10s.c.
orange10s.c.'s Avatar
Drives: IOM 2SS RS M6 sunroof
What are you hooking up?
Old 03-27-2010, 09:13 PM   #4
FANTA-Z
Drives: 2010 SSRS
Nice job!!
FANTA-Z is offline   Reply With Quote
Old 03-27-2010, 09:16 PM   #5
TRSS2
TRSS2's Avatar
wheel well lights, and putting aac dual colored halos on single on/off switch...
Old 03-27-2010, 10:03 PM   #6
Alain
Alain's Avatar
Drives: 2016 Challenger Hellcat, 2018 ZL1LE
wow, that deserves an academy award lol good job
Alain is offline   Reply With Quote
Old 03-27-2010, 10:49 PM   #7
CamaroSkooter
Retarded One-Legged Owl
CamaroSkooter's Avatar
Drives: 2010 Black Camaro 2SS
That's like the equivalent to the Zombie Kill of the Week!
Old 03-27-2010, 10:59 PM   #8
ron10
Drives: 2010 2SS IOM L99
thanks for the info.
Old 04-24-2010, 10:00 AM   #9
Phantom.5SS
Hell yeah I'm Guilty.....
Phantom.5SS's Avatar
Drives: 2010 2-SS ABM NON-RS
Thanks for the great info, saved me alot of headache.....
I ran a piece of 8 conductor wire and mounted a weather proof terminal block under the hood and a matching one under the dash..now hook up is easy as reading the numbers on the blocks....
Thanks again.
Phantom.5SS is offline   Reply With Quote
Old 05-01-2010, 08:15 PM   #10
skuttduck
skuttduck's Avatar
Drives: 2010 RJT 2LT Camaro
Send a message via ICQ to skuttduck Send a message via AIM to skuttduck Send a message via Yahoo to skuttduck
There is an easier similar plug on the passenger side under the cowl. You don't have to run the wire nearly as far and it comes out right in the passenger side kick panel area.
http://www.camaro5.com/forums/showthread.php?t=80843
I tried this route and don't like the area in which this wire goes as it comes out a little too far away, and the trim will pinch the wire. Under the cowl was easier to run.
skuttduck is offline   Reply With Quote
Old 05-02-2010, 03:00 AM   #11
qbert48
qbert48's Avatar
Drives: 2SS SIM
did anyone see that bad a$$ knife sweet
2SS RS SIM gray leather stick shift ground FX
thank you gary richards @ classic chevy in sugarland
welcome home
1100 4-27-09
6000 6-27-09
yes i got to the dance late don't hate me
qbert48 is offline   Reply With Quote
Old 05-02-2010, 03:42 AM   #12
hollywoodGU
Drives: 1999 Firebird Formula
lol my grandpa just got one for free in the mail cuz he is a member of the NRA
hollywoodGU is offline   Reply With Quote
Old 05-02-2010, 03:44 AM   #13
AlSuwaidi
AlSuwaidi's Avatar
Drives: BLACK LS3 GCC-Spec
great find!!
AlSuwaidi is offline   Reply With Quote
Old 04-27-2012, 10:14 PM   #14
dlluinstra
David
dlluinstra's Avatar
Drives: 2010 LT2 RS Red Jewel Tint
Could you repost the pictures?
Thanks
DL
dlluinstra is offline   Reply With Quote
firewall, install, wheel well, wiring
How To Wire Dual Halos On Single Switch kismyss Camaro DIY & HOW-TO instructions & discussions 54 05-06-2014 12:18 PM
BAD WEEKEND....hit and run damage...plz help!!! (pics inside) wlivingston04 5th Gen Camaro SS LS LT General Discussions 59 01-15-2010 11:06 AM
Installing amp and subs - Where to run remote wire? Nate_687 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 6 12-05-2009 10:58 PM
DIY: Here it is Dashboard ambient lighting ABL Tecca Camaro DIY & HOW-TO instructions & discussions 356 09-03-2009 11:46 AM
Motorgen LA Invasion Videos (58) and Pics Thread SeanPlunk USA - California 5 05-31-2009 02:23 AM
