06-23-2010, 09:18 PM | #1 |
Drives: 2014 2SS/RS Spring limited edition Join Date: Jul 2009
Do L99's have posi in the rear end or not??
Title pretty much says it all.
For all of us out here with the L99 auto tranny set up, I am starting to hear that the auto tranny's do NOT have a posi rear end. Can some of the pros chime in on this please. I have heard the the V6 autos do Not have posi, and that the L99 V8 did. Now I am hearing that both of the Auto tranny's (V6 & V8) do NOT have a posi rear end. I also have a couple of friends that when doing a burn out in the L99 auto only one (1) back tire spins I give up, any help would be great thanx all
2014 2SS/RS, Spring Limited Edition...
Ask yourself.....when you turn on your car..... Does it return the favor..... MODS: CIA cold air intake, Oil catch can, Dynatech LT Headers, Dynatech Power cats, Dynatech Cat back exhaust, Janetty racing tune, Vitesse throttle controller, Headlight and marker tint, more to follow.... |
06-23-2010, 09:24 PM | #2 |
"Silver Street"
Drives: 2010 2SS/RS L99 Join Date: Oct 2009
Silver Street - 2010 Camaro 2SS/RS, SIM, Gray, Cyber Gray Rally Stripes, Polished Wheels, Automatic (L99) - 553 RWHP/510 RWTQ
CAI Inc., ARH LT Headers with Cats, Borla Touring Cat-Back; Pfadt Coil Overs, Sway Bars, End Links, and Trailing Arms; Comp Cams Blower Cam, Dual Springs, Push-Rods, and Lifters; GM LS2 Lifter Trays, 6.2 MLS Head Gaskets, Crank Bolt, and LS2 Front Cover; 3-Bolt Conversion Timing Gear, Katech C5R Timing Chain, ARP LS2/LS3 Head Bolt Kit, Melling Hi Volume Oil Pump, TVS 2300 Supercharger (Black); Build by Vengeance Racing; Custom Tune by Vengeance Racing |
06-23-2010, 09:31 PM | #3 |
Drives: 2013 A6 GT 5.0 Join Date: Nov 2009
Of course we have posi (limited slip). The v6 does not. I cant think of any V8 auto Camaro that did not have some sort of limited slip that I have owned.
06-23-2010, 09:33 PM | #4 |
I used to be Dragoneye...
SS Manual
SS Automatic V6 Manual All have limited-slip diff. V6 autos do not. |
06-23-2010, 09:42 PM | #5 |
Drives: 2010 2SS IOM L99 Join Date: Jan 2010
they have it.
06-23-2010, 09:46 PM | #6 |
Well that was quick, thanx all,
Sounds like the vote is in favor that my L99 has the posi rear end. Again thanx for the quick reply Have a great night all.
06-23-2010, 11:24 PM | #7 |
The V6 auto is the only one that misses out on the fun. :(
Mods: BBK Intake, BBK LT's and High Flow Cats, Corsa Cat-back exhaust, Hurst short throw shifter, SLP skip-shift eliminator. 7/1/09 Placed order for IOM/IO int/ SS/RS 6M 9/26/09 Took delivery! |
06-24-2010, 11:28 PM | #8 |
Drives: aqua 2ss l99 Join Date: Jun 2009
iceman, your car is too gutless to need a posi at this time, so stfu.
j/k.
May your exhaust note, sing in harmony with your blower.
04-12-2011, 05:16 PM | #9 |
I have a 2011 LT1 v6 with a automatic and both tires spin it doesn't matter if it is wet or dry and when it's wet it will go sideway in 2nd gear so I would think it at least has limitid slip.
Similar Threads | ||||
Modifying for " Dummies" | Dr Jkel | Tuning / Diagnostics -- engine and transmission | 209 | 06-17-2012 11:24 PM |
Rear End Noise when enabling/disabling TC/Stabilitrack | Swytch | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 0 | 06-03-2010 12:08 PM |
Richmond Rear End Gears - 3.73 & 4.10 | Sean@Phastek | Transmission / Driveline | 0 | 06-02-2010 10:47 AM |
rear end failure? | xshortd | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 1 | 04-08-2010 06:59 PM |
Rear end whine while under load | shiftz33 | 5th Gen Camaro SS LS LT General Discussions | 4 | 08-12-2009 04:15 PM |
