Old 12-11-2010, 01:13 PM   #141
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
I just finished installing a RX catch can. SC2150 says that cooling plays into getting the oil to fall out of suspension. So I decided to run with that thought.
Oh yeah Paul, while I was at it I use Plasti-Dip spay to do the spacers on the VR stays.
She is only memory now.
IndeedSS1 is offline   Reply With Quote
Old 12-11-2010, 01:28 PM   #142
Nomad
Nomad's Avatar
Drives: '11 2SS/RS RJT M6
Originally Posted by IndeedSS1 View Post
So I just finished installing a RX catch can. SC2150 says that cooling plays in getting the oil to fall out of suspension. So I decided to run with that thought.
Uh, I missed something. You installed an RX catch can? Please explain.
Nomad is offline   Reply With Quote
Old 12-11-2010, 03:29 PM   #143
IndeedSS1
IndeedSS1's Avatar
Just trying something different. Now you "can" see options. Both could be mounted on the washer bottle though. One could mount the RX on the on the bottle without the aluminum L bar. I just like the added support. The button heads on the bolts, sit in a vertical groove on the bottle. The hose clamps just happen to fit perfectly through an open area in the plastic molding. The progressive washers are there because the bottle neck is pitched. This was way too easy, it just takes me forever to get my mind made up.
Old 12-11-2010, 10:49 PM   #144
Nomad
Nomad's Avatar
"Can" I actually chuckled!
Very interesting. I like what you did with the hose routing. It really blends well and looks stock. Now I will take all of my parts back and investigate the idea of locating it in this area.
Sorry, I don't want to hijack this thread and move the focus from the intake but I was caught by surprise.
Old 12-12-2010, 09:18 AM   #145
IndeedSS1
IndeedSS1's Avatar
Thanks.
I hope BackInBlackSS/RS doesn't mind, his thread has helped us all. I think it's nice to find a thread about a VaraRam installation, and see different peoples posts on things related to having the VR. I don't think this mod, and my lack of skills, is worthy of it's own thread.
Sort of related, but I just went down to the garage and held up my other catch can to this mounting system. I believe it could easily be adapted, using a small flat bar pop riveted to the L bar. The flat bar could be used as an extension to move the can way from the washer bottle neck slightly. Then use the stock adaper with the two pass through screw holes with slighlty longer screws to mout to the flat bar...maybe.
Old 12-12-2010, 11:19 AM   #146
KEEP RT
Wonderfully Awful Idea
KEEP RT's Avatar
Drives: 2010 2SS/RS
INDEEDSS1
Sorry I didn't get back I had to fly to Idaho for the week. (hate rentals,they can't compare to the Camaro 2SS )
I did hit the 100 mile mark and WOW. Nice improvement. the millage was still all over the place. I did the fuse pull reset and that was the trick. I'd suggest it to all. I even felt a little more performance on top of the added Vararam. The millage did settle down after that. Like you catch can set up where did you buy it.
KEEP RT is offline   Reply With Quote
Old 12-12-2010, 12:31 PM   #147
IndeedSS1
IndeedSS1's Avatar
Originally Posted by KEEP RT View Post
INDEEDSS1
My mpg was rock solid from the get go. But I figured you would notice a difference after 100 miles. I think I may have 1200 on mine since installing.
Anyway the catch can is RX. PM SC2150 and he will take care of you.
The custom mounting stainless steel pieces were picked up at Ace Hardware. I love ACE because they have their stuff in bulk bins where you can do test fittiing.
Old 12-12-2010, 05:20 PM   #148
rocketman 12
SOON.........
rocketman 12's Avatar
Drives: 2010 ABM SS/RS Z-281LE
I'm glad I decided to wait till next spring to get an intake. I liked the look of the Vararam when i first saw one, but then it seemed like everybody was having trouble with them, so I figured I'd grab a CAI in the spring, but after seeing this thread, I think I'm going back to the VR, just LOVE the way they look.
No, it's not a real Z/28.....
rocketman 12 is offline   Reply With Quote
Old 12-12-2010, 06:25 PM   #149
IndeedSS1
IndeedSS1's Avatar
Like the rest of the guys that have the new version, I'm sure you won't be sorry. They do have an awesome warranty and the customer support is top notch.
Old 12-12-2010, 07:57 PM   #150
BackinBlackSS/RS
Go Blue!!!!!
BackinBlackSS/RS's Avatar
Drives: 2012 Cruze LT
Nice!! That is some cool stuff. Thanks for the idea.
You will love it.
Old 12-13-2010, 12:28 AM   #151
KEEP RT
KEEP RT's Avatar
Drives: 2010 2SS/RS
I'm totally happy. If you think about it, if for nothing else, a straight line will have the least restriction for one. Next, air coming completely from out side the engine compartment will be fresh and colder than in a mixed condition. Plus it is taken from air that is higher off the road that can be very hot in the summer on black asphalt. It is also protected from rain from the front valence. All that and it is short. A long tube through a hot engine compartment will heat up. The Vararam is the shortest distance from cold air to hot exhaust. It just makes sense. Thank you Vararam.
Old 12-13-2010, 02:46 PM   #152
toehead93
Drives: 2014 2SS/1LE
I installed the new unit yesterday to replace the original unit which still had some surging issues. I have to say I noticed an immendiate differnce in start-up, idle, and general driving. So far no surging at all, I must say I'm very happy!
I posted some comparison pics over here if anyone is interested.
http://www.camaro5.com/forums/showth...t=55604&page=4
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 12-15-2010, 01:17 PM   #153
Jayson9
Drives: 2SS
Just installed my Vararam last night. And the only issues I had was with the long screws they give you that replace the radiator support screws. Had to jimmy them and the brackets around abit to get them to line up right so that I could tighten them down. Other than that, the install went flawless. It also mates up nicely with my Diablo Tune as well. Could tell a big difference in the performance.
Jayson9 is offline   Reply With Quote
Old 12-15-2010, 02:03 PM   #154
IndeedSS1
IndeedSS1's Avatar
I don't think most are even using those long bolts. Did you try it w/o?
Camaro Dove Tail Spoilers Compilation daphatgrant Cosmetics and Lighting Modification Discussions 473 07-11-2025 10:07 PM
Racing Brake 2 pc Rotors Installed mtcwby Suspension / Brakes / Chassis 36 11-13-2010 06:07 PM
Got A Vararam for $10! (Warning long read) shadow09 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 11 04-26-2010 11:44 PM
Check Engine light on after ARH and Pipeline CAI installed se7en Tuning / Diagnostics -- engine and transmission 17 03-10-2010 09:06 AM
Another Dealer Installed Stripe Problem 69er Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 7 07-13-2009 04:32 PM
