#379 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Black '13 2SS/RS/1LE w/NPP/NAV Join Date: Oct 2012
Looks great man...
My Build Thread... http://www.camaro5.com/forums/showthread.php?t=285054
#380 | |
2013 Camaro SS1LECTSVZ28
Drives: 2013 AGM 1SS/1LE Join Date: Nov 2012
-Matt
#381 |
![]() Drives: Camaro 1LE Join Date: Mar 2015
I've heard nothing but REALLY good things about those ap racing brakes. Serious track capability.
#382 |
![]() ![]() ![]() ![]() Drives: 2013 Camaro 1LE 1SS Join Date: Aug 2012
3rd time is the charm.... As I know too well as well lol. Any thoughts on brake cooling upgrades? Those rotors will need a lot of air, I was searching today on if anybody put 2014 wheel liners on a 2013, it comes with extra cooling features as well as the possibility to mock up the z/28 brake ducts that work with the liners.
I work for General Motors and am not an official spokes person for General Motors. My views and opinions are my own and not those of General Motors.
#383 | |
![]() Yes, Nick S added the 14+ liners and ducts to his 2013: http://www.camaro5.com/forums/showthread.php?t=418879 -Matt
#384 |
You da man thats the one I was looking for. Ordering parts today, destroyed my wheel liners at grattan few weeks ago might as well upgrade.
Do you have pictures of the AP pad size next to oem ones by any chance?
#385 |
![]() Drives: 15 Lexus RCF, 17 Vette Grand Sport Join Date: Apr 2013
I used the quantum cooling ducts with this kit. Thats all you need!! You are going to be SHOCKED when you see how much cooler these run!! Enjoy!
2013 Summit 1SS 1LE w/NPP, SW 1 7/8" Long Tube Headers, CAI Intake, Ported TB, Cammotion 224/232 113 LSA, BTR Valvetrain, Melling Oil Pump, 468 HP 423, Apex Catch Can, Tank Plates, RPM 4 Point Roll Bar with SCCA/NASA Cross Brace, Schroth 6 Point Han's Harness, OMP WRC Front Seats, F.M.T Trailing Arms, F.M.T Solid Aluminum Subframe Bushings, Moreno Motorsports Camber Plates, BMR Bushings Front and Rear, Essex/AP Racing Radi-Cal Endurance Front Brakes, Quantum Brake Cooling Ducts, ZL1 Rockers, ZL1 Air Deflectors, Heritage Grill, Pfadt Springs.
#386 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 Camaro 1LE Join Date: Jul 2012
If you have any questions about my Z/28 brake duct install on my 2013 1LE just shoot me a message. I could try to get additional pics or something too if needed.
#387 |
Tx Nick, appreciate the write up, one thing I am looking at changing is where it mounts to bottom so that skiramps gets clean air for pick up vertically.
Summit, did you measure pre and post quantum install (rotor temps)? I use longacre brake temp probe.
#388 |
I did not measure the temps. IT was immediately apparent upon exit of the car near the front brakes how much cooler they were running.
#389 |
I added 5" ducts by the fog lights in addition to my 3 inch ducts in lower center grill, all came out at wheel liner similar to zl1/z/28 where Nick S has em now. Put a blower 6" from each opening on both passenger and driver side. the 3" straight duct blew significantly more and faster air onto corner, 5" duct was I would say a third of the 3".
This is why I was never a fan of the quatum duct, the routing is too long too many curves and a 180 in airflow is a big no no, plus the exit hole on the shield is way smaller than a 3" duct opening.... Running it straight to quantum duct is best but at that point just let the 3" outlet blow on rotor hat without the quantum shield.
#390 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '16 C7 Z51 Join Date: May 2012
C7 has an excellent brake ducting system where the air is diverted by blades on the suspension control arms. Considering the simplicity, no wear items, and relative efficiency, I think it is a great compromise.
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD) '13 Mazda MX-5 Club (Build Thread) '17 RAM 1500 Crew Cab 4x4 Night Edition '15 Nissan Rogue S AWD |
#391 | |
I think from what I have read here on the forum you are already well past the point of no return when it comes to going back to stock so I'm sure that consideration was not as important for you. Please post up some pics of the finished install if you would. It would be nice to compare what I did to how yours turned out incase there are any improvements I want to make to my set up.
#392 | |
