07-31-2020, 06:39 PM | #1 |
Drives: 2017 ZL1 & 2013 SS Join Date: Oct 2018
Brembo brake upgrade question
Have a 2013 SS with factory 4 piston brembos and am upgrading to ZL1 6 piston. Does the caliper bracket have to be changed or does the 6 piston bolt on to my original? Thank you.
07-31-2020, 07:11 PM | #2 |
Drives: 2010 Black 2ss Camaro SS Join Date: May 2010
bolts right on...you just need the caliper, new rotor, dust shield and brake lines
ZL1 10 spokes,Dart 388,ECS Supercharger 2200x, E85 Flex Fuel sensor, Dart 388 , B&M Tranny Cooler, Vigilante 4000 Triple Disc TC,Katech Ported Heads, Texas Speed Sheet Metal Intake, ECS Big Blower Cam,ID 1700s, Fore Triple Pumps, E85,ATI Super Dampner, KW V3 Coilovers, Pfadt front and rear sway bars,Pfadt Trailing arms and toe rods,ZL1 Rear Diff, RPM 6l90e level 10 Tranny, SW Long Tubes no cats,Nick Williams Boosted 102mm TB, Dr Phil Tune,Borla Atak
08-01-2020, 12:51 AM | #3 |
Runs on caffeine
Drives: 2010 Camaro SS Join Date: Apr 2020
You can get away with cutting your dust shield for the front brakes. You will need to trim tiny little bits on the edges. Mock up the caliper and notice where it is hitting, I believe it is the top corner. Cut that edge with dremel or any metal cutting tool you may have. I did the conversion on my car a few months back, added DOT 5.1 fluid and braided stainless steel lines. If you have any questions feel free to PM me
08-01-2020, 09:46 AM | #4 | |
08-01-2020, 08:47 PM | #5 |
Drives: 2010 ss/rs 6 speed manual Join Date: Aug 2013
I agree with this. Plus you have the ss dust shields to sell along with your ss brembo Kit to someone who wants them.
2010 camaro ss/rs, standard 6 speed, ls3 motor, bmr subframe connectors, jba 3” competition Exhaust, stainless works 1 7/8" headers, adm cold air intake, hurst short throw shifter, bo white ported tb, mishimoto aluminum radiator, mishimoto oil cooler.
08-01-2020, 10:27 PM | #6 |
Thank you! As soon as my ridetech coilovers arrive I am gonna do the swap. Again, thank you everyone for their input!!
08-01-2020, 10:43 PM | #7 |
Drives: 2015 2ss Join Date: Jun 2009
here's a very detailed thread on the 6 piston upgrade
https://www.camaro5.com/forums/showthread.php?t=418667 you're gonna love them.
2015 Camaro 2ss, NicKey Performance built/tuned |
08-02-2020, 09:00 PM | #8 |
Runs on caffeine
I got away with selling my old brakes to a V6 owner and he didn't have to modify his front rotors which are the ones you're cutting from. The only ones that did require modification were the rear as he cut his rear dust shield. There has been threads on here before which they mention cutting as to avoid removing the e-brake and speed sensor mechanisms to remove the dust shield. There are also threads that teach how to properly do it but at the end of the day you choose the method that is best for you.
08-02-2020, 09:19 PM | #9 | |
08-02-2020, 09:23 PM | #10 | |
Runs on caffeine
08-02-2020, 09:42 PM | #11 | |
08-02-2020, 09:57 PM | #12 | |
Runs on caffeine
https://www.camaro5.com/forums/showthread.php?t=247289 https://www.camaro5.com/forums/showthread.php?t=418879 These three posts should help a little when working with the ZL1 or Z28 brake ducts. On one it talks about fitting brake ducts on the earlier 5th gens, the other is how the ZL1 brake ducts work (same idea as Z28), and the other is improving the efficiency of the brake ducts. I do have a friend doing a ZL1 conversion on his boosted 1LE and we found that he cannot run the ZL1 brake ducts because of his intercooler tubing. Sometimes you have to compromise and find which one is most important to you and your build. |
08-02-2020, 10:17 PM | #13 | |
08-02-2020, 10:22 PM | #14 |
Runs on caffeine
Would you like me to ask my friend if hell be selling them? He has a set of the brake ducts that came with his front bumper
