Old 08-31-2014, 02:39 AM   #1
X25
X25's Avatar
Drives: '16 C7 Z51
Arrow '14 AGM 1SS/1LE Track build [COTW 11/17/14]
I have been collecting all sorts of parts for the '15 1SS/1LE I had on order, but since the dealer turned out to be greedy, the deal fell apart. Anyways, long story short, I finally got my 1LE in the guise of a 2014 Ashen-Gray Metallic 1SS 1LE at 6500 miles, and I already have all but few parts to finish the build! It turns out, though, the issue with Camaro builds is not finding parts, but rather doing the installation.
Pics from the day I picked it up:
How it currently looks (8/23/15):
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD)
'13 Mazda MX-5 Club (Build Thread)
'17 RAM 1500 Crew Cab 4x4 Night Edition
'15 Nissan Rogue S AWD
X25 is offline   Reply With Quote
Old 08-31-2014, 02:42 AM   #2
X25
X25's Avatar
Drives: '16 C7 Z51
Current mods list. Last update: 3/26/16
Legend: Planned | Procured | Installed
  • Engine / Powertrain
    • TSP 304 LT Headers with custom 3" X Pipe (TSP's own x-pipe did not fit perfect). 20, 76
    • Improved Racing oil pan baffle.
    • DEI coil boots.
    • 2000 degrees F matte-gray header coating. 20
    • Diablosport Intune w/ custom tune from FSP - $489 shipped.
    • DeWitts radiator - $575 shipped. 12, 30
    • Improved Racing oil cooler with Setrab Series 6 / 48 rows. how-to, 39, 314, 335, 343, 472
    • Improved Racing oil sensor manifold (ENV-150).
    • Tick remote clutch bleeder. 460, 477
    • Detroit Truetrac 912A686 Helical differential - $511 after rebate. 403
    • Z/28 rear differential cooler (23216684) - $530 + shipping (use coupon code to get 5% off total). 415, 477
  • Interior
    • OEM Recaro seats. 214(manual), 227, 268(powered)
    • Custom harness bar with tank plates. 435, 499
    • Schroth Racing Profi II ASM. 435
    • Auto Meter 5286 Direct-fit Gauge Pod. 135
    • Auto Meter 6348 Oil Temp Gauge. 135
    • Auto Meter 6327 Oil Pressure Gauge. 135
    • Auto Meter 9114 Dimmer For LED Gauges.
    • SRP pedals. 577
  • Handling
    • Z/28 suspension package . $3449 shipped. 58, 104
      • Front/Rear DSSV struts,
      • Front/Rear sway bars with end links ,
      • Front control arms,
      • Rear upper and lower arms.
    • Z/28 full aero. 181, 182, 285
    • ZL1Addons see-through wicker bill. 367
    • Pegasus CNC
      • Solid subframe bushings. 545
      • Delrin (solid) rear trailing arm bushings at the knuckle. 545
      • Camber plates. 545
    • Tires
      • Hankook Ventus R-S3 305/30/19 for daily driving. 89, 137
      • Pirelli Trofeo R 305/30/19. 179
      • Michelin Pilot Sport Cup 2 305/30/19. 193, 204
    • Wheels
      • APEX ARC-8 19"x10.5" +22 spin forged wheels for daily driving / rain. 56, 89, 130, 137
      • OEM Z/28 Wheels 19"x11" +11 fronts, 19"x11.5" +26 rears. 184, 204
  • Brakes
    • Quantum - Competition Brake Cooling Kit - $239.95. how-to
      • NACA ducts: $20.
    • StopTech ST60 Front BBK 15” red (83.193.6800.71). 114, 121
    • Stock rear rotor (92245929) - $85.31 shipped x2.
    • Pads
      • Raybestos ST47 R2600.18 Front pads for StopTech ST60 caliper. 121
      • Cobalt Friction XR2 Rear (CRB-XR2-D592-15.0MM-R).
  • Fluids
    • Engine oil: Mobil1 5W-30.
    • Differential oil: Redline 75W-90NS (no friction modifier for helical Eaton TrueTrac diff).
    • Transmission oil: Amsoil Signature Series Multi-Vehicle Synthetic ATF.
    • Brake fluid: Motul RBF 600.
    • Coolant: GM DexCool @30%.
    • Suspension grease: Amsoil Synthetic Polymeric Truck, Chassis and Equipment Grease, NLGI #2.
  • Other
Old 08-31-2014, 02:53 AM   #3
X25
X25's Avatar
Drives: '16 C7 Z51
I had to ship the BC Racing ER coilovers back to the vendor's warehouse last Friday. They (Q04) do not fit since the reservoirs do not clear the rear suspension. The vendor claims they do have ER coilovers for '14+ Camaros (Q10), but I only see BR available under Q10. The updated application list is here.
Here is hoping they indeed have coilovers that fit! If not, I suppose they could also replace the hose of the reservoir with a bit longer one, so I could put it in a place where it would clear; I would not mind. FYI, I cannot just replace the connecting hose myself since it is pressurized and I'm not in the business of valving coilovers
Old 08-31-2014, 03:03 AM   #4
X25
X25's Avatar
Drives: '16 C7 Z51
As I mentioned before, this build will be challenging due to extensive labor it requires. I am starting to have anxiety! : )
Now that the rear suspension bushings are done, I'd like to tackle the fronts. In the instructions, it states that I need to jack the engine a bit up to clear the sway bars. If this is the case, I think I might as well bundle it with the oil pan baffle job.
Synner's thread here has great info about how to install the baffle without having to cut the cross-bar. I intend to do something similar, following MAPerformance's turbo install instructions, where they show how the oil pan can be removed with a bar or an engine cherry-pick.
I bought 2-jaw and 3-jaw bearing pullers in various sized from Harbor Freight. Let's hope that they work fine on the remaining front bushings.
Oil baffle:
http://www.improvedracing.com/baffle...ffle-p-41.html
Bearing pullers (the jaws' directions are reversible):
MAPerformance's engine cradle:
http://www.maperformance.com/tech/20...nstallation-1/
Old 08-31-2014, 04:17 AM   #5
gmorcos37
Drives: 2014 Summit White 1LE
Looking good!
Curious about the smart-fuse as a $1 remedy for the skip-shift issue. Care to share? Looking to do this to mine.
Thanks!
gmorcos37 is offline   Reply With Quote
Old 08-31-2014, 04:36 AM   #6
X25
X25's Avatar
Drives: '16 C7 Z51
Originally Posted by gmorcos37 View Post
Looking good!
Thanks!
Sure, the skipshift operation is controlled by a simple solenoid which has its own fuse. If you remove the fuse, it would disable the skipshift, but also light up check engine light. Smart fuse allows a very low current to still pass through to light up its LED even when it's blown. This current will not be enough to engage skipshift, but will let the engine diagnostics think that everything is good.
Old 08-31-2014, 04:40 AM   #7
gmorcos37
Oh nice! I will do this tmrw then. Which fuse/location is it?
Old 08-31-2014, 04:45 AM   #8
X25
X25's Avatar
Drives: '16 C7 Z51
It should state manual transmission solenoid. Don't forget to blow the fuse before installing it! Last time I did this (on a C6 Z06), I used my portable battery jumper to blow it (after which it is lit).
Old 08-31-2014, 04:55 AM   #9
gmorcos37
Sounds good! Thanks for the info! I've got a battery jumper as well so I'll give it a shot
Old 08-31-2014, 05:17 AM   #10
gmorcos37
Hmm just looked in the manual and couldn't find anything that stated manual transmission solenoid for any fuse. Any chance you got the fuse number?
Old 08-31-2014, 02:30 PM   #11
Bens1le
Bens1LE
Bens1le's Avatar
Drives: 2014 ss 1LE
Did you get the Dewitt's radiator yet?
Better check it and make sure it has the .625 outlet on the drivers side
For the oil cooler heat exchanger, the 1LE s use a zl1 type set up
I had to get a Ron Davis rad , which was a huge upgrade over stock
And fit perfect
Bens1le is offline   Reply With Quote
Old 08-31-2014, 05:11 PM   #12
X25
X25's Avatar
Drives: '16 C7 Z51
And fit perfect
It seems to have it; I sure hope it fits with no issues. The core looks massive!
Old 08-31-2014, 05:12 PM   #13
X25
X25's Avatar
Drives: '16 C7 Z51
I finally received the jack adapters (with magnets), too. It was very painful (but possible) to lift the car without them...
Old 08-31-2014, 05:52 PM   #14
Bens1le
Bens1LE
Bens1le's Avatar
Drives: 2014 ss 1LE
Hi
Where did you get those ?
Thx
