Old 08-23-2010, 01:09 PM   #1
shinzon
Night Fury
shinzon's Avatar
Drives: 2014 ZL1
tire plugging OK ?
Real quick question, Is plugging a tire good fix ?
The screw I picked up is right on the tread in the middle of the tire.
Does a plug compromise the structural intergrity of the tire or throw off the balance ?
2014 Black ZL1 - Toothless -
Previous Lovers :2014 1LE , 2010 2SS RS,2004 GTO, 2000 Camaro SS x 2
shinzon is offline   Reply With Quote
Old 08-23-2010, 01:12 PM   #2
x626xBlack
ARMY of one.
x626xBlack's Avatar
Drives: 2011 Black SS/RS
Probably will not cause any problems.... However if you smoke em you may pull the plug out... I am guessing
x626xBlack is offline   Reply With Quote
Old 08-23-2010, 01:14 PM   #3
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Tire plugging is a temporary fix only meant to last you 1-2 days till you can get it fixed properly. Do not rely on a plug to permanently fix the hole as they can and will come out eventually.
Old 08-23-2010, 01:15 PM   #4
helmincamaro
Official Lounge BAMF
helmincamaro's Avatar
Drives: '97 Camaro
Send a message via AIM to helmincamaro Send a message via Yahoo to helmincamaro
I used to have to plug numerous truck tires every week at my last job. They were constantly picking up nails and screws from construction sites. Now about it coming out when roasting them.... I wouldn't know anything about that on the work trucks
helmincamaro is offline   Reply With Quote
Old 08-23-2010, 01:18 PM   #5
nards444
nards444's Avatar
Drives: 1SS/RS Black
they are more then temp fixes. Ive had them just about on every car ive ever had. Sure with roasting the rear tires it might be an issue. I got one on my diesel now thats been there a year with towing, winter, etc. No issues. Whats the worst thing that can happen you get another flat. These kind of tires usually dont last that long anyways. plug is and wait till you get a new tire.. Ive never heard a mechanic say get a new tire in 2-3 days after using one
2010 1SS/RS Black, CGM stripes, polished Rims, Tinted windows, Hurst shifter
nards444 is offline   Reply With Quote
Old 08-23-2010, 01:31 PM   #6
67 Convertible
67 Convertible's Avatar
Drives: 67 Camaro Convertible
I have had many tires "plugged" over the years, continuing to drive them normally for many thousands of miles until the tire wore out and was replaced. I noticed no ill effects or performance isues from plugging the tires, nor have I ever had one come out.
2LT/RS RJT, Blk Rally Stripes, Beige Interior, Sunroof
Placed order at dealer 4/24/09
1100 - 4/28/09
2000 - 5/01/09
2500 - 5/05/09
3000 - 5/05/09
3300 - 5/30/09
3400 - 6/05/09
3800 - 6/18/09
4000 - 6/18/09
4B00 - 6/18/09
4200 - 6/22/09
5000 - 7/01/09
6000 - 7/01/09 It's Home!!
0000 - 7/14/11 Traded in with 24,000 miles. Currently 5th Gen less
67 Convertible is offline   Reply With Quote
Old 08-23-2010, 01:33 PM   #7
xcdarrel17
Drives: 2011 VR 1SS
Plug it, keep an eye on your tire pressure in case you didn't get a complete seal, but otherwise forget about it.
xcdarrel17 is offline   Reply With Quote
Old 08-23-2010, 01:34 PM   #8
Rip
Drives: 2011 SS/RS
If you have multiple plugs in a single tire it can throw off the balance. I've had it happen, but never with only 1.
Rip is offline   Reply With Quote
Old 08-23-2010, 01:35 PM   #9
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Tire plugging sucks... why ream the hole out and make it bigger... nothing replaces a gold old patch on the inside...
Then once you've reamed the hole out where you can see daylight through it you drive on it for a couple of years and the plug wears down with the tire tread and starts to eventually leak... I know I'll get flammed from those who have never had problems so let it fly.
Plug is just a lazy way to temp fix a tire... only worth it if you're stuck on the side of the road in a Camaro SS... JMHO
Old 08-23-2010, 01:35 PM   #10
nards444
nards444's Avatar
i even noticed after a while and the heat thats generated from driving the plug almost fuses with the tire. I hve had plugs where you cant even tell where the plug went. I think a good rule of thumb though is within one inch of the sidewall or on the sidewall you should get a new tire
Old 08-23-2010, 01:39 PM   #11
mulletman
Drives: 2017 Camaro SS
The 2SS can go 155 MPH. The only way to fix a leak on a high performance tire is a proper repair from the inside. Check with a Michelin dealer.
mulletman is offline   Reply With Quote
Old 08-23-2010, 01:41 PM   #12
nards444
nards444's Avatar
these are 30,000mi tires and in reality only last 20 so if its a daily driver your getting new tires every other year anyways. Multiple plugs sure. But my self or anybody i have ever know has never had an issue.
Old 08-23-2010, 01:42 PM   #13
jrc1122
Drives: 2012 Mustang GT
discount tire will repair for free.
2012 Mustang GT Premium
Performance White
6-speed Manual
jrc1122 is offline   Reply With Quote
Old 08-23-2010, 01:43 PM   #14
nards444
nards444's Avatar
well I can rob a bank if I want too, doesnt mean its legal or I should do it.
Colorado members check in here 2010 SS RS USA - Rockies / Midwest 8853 06-13-2022 08:45 PM
Reccomendation on Road coarse/Autocross Tires michael's maro Wheels and Tires Talk Sponsored by The Tire Rack 21 09-06-2010 06:52 PM
Exhaust bolt in tire = bad day GPD151 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 3 07-30-2010 12:56 AM
Are they rims or are they wheels?? topgun1 Off-topic Discussions 28 07-07-2010 12:02 AM
Bridgestone RE11 Performance Tire Review Info@PeddersUSA.com Suspension / Brakes / Chassis 4 12-28-2009 11:58 PM
