Old 08-27-2010, 08:39 PM   #1
adub
adub's Avatar
Drives: Shopping
Diff Fluid question
I changed my diff fluid at 5700 miles, it was nasty with lots of shavings on the magnets. I replaced it with 1 quart of Mobil 1 75W-90 which includes LS additive. I noticed that that car groaned during low speed turns, so I turned around and went home. Drove maybe two miles. Bought a bottle of GM LS additive and put about 1.5 ounces in. Drove the same two mile course and it doesn't groan, but it whines now. Whats the deal, doesn't seem like anyone else has had any trouble with non GM diff fluid?
______________________
2010 2SS RS Auto - Black
1970 Chevelle SS 396
adub is offline   Reply With Quote
Old 08-27-2010, 09:10 PM   #2
Rob191288
Rob191288's Avatar
Drives: 2010 Camaro LS
Royal Purple is what I put in mine, nothing wrong with it at all.
Rob191288 is offline   Reply With Quote
Old 08-27-2010, 09:36 PM   #3
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
When I asked my dealer for a bottle of GM's diff fluid they pulled out a bottle of Mobil 1.
Old 08-27-2010, 10:14 PM   #4
adub
adub's Avatar
Drives: Shopping
HA! It only does it at low speeds, like parking, so I dont think its too serious. I'm thinking I may try to find some 75W-90 without LS and then use the GM additive.
Old 08-27-2010, 10:48 PM   #5
Russell James
Russell James's Avatar
Royal Purple Max Gear 75w90. Needs nothing else added. Or the GM lube with adding the GM additive. I wouldn't mix and match something that already has an additive and then add more additive. RP works great, I'd go with that.
Then go to a parking lot and do about 10 slow figure 8's. That works the additive into the clutches. If it still whines or groans after that, something is boogered up.
Old 08-30-2010, 08:43 AM   #6
adub
adub's Avatar
Drives: Shopping
That quieted it down, thanks
Old 09-02-2010, 12:29 PM   #7
clg_98ta
clg_98ta's Avatar
Drives: 2010 Camaro 2SS
Yep, you always need to drive tight circles in both directions (or figure 8's) after changing the diff oil. That's very important, you can damage the differential if you forget this step.
Old 09-02-2010, 07:56 PM   #8
molsonbrador
molsonbrador's Avatar
Drives: 2010 Camaro SS, 2018 Colorado
adub, now that you're good can I threadjack? If so I want to ask why people are changing diff fluid so early? I see you said you had shavings, anyone else?
thanks.
molsonbrador is offline   Reply With Quote
Old 09-03-2010, 08:58 AM   #9
Moriartii
Moriartii's Avatar
Drives: 11 IOM 2SS/RS M6 w/Hurst
Yeppers I changed mine and had crap on my plug and such as well.
Cheers
K
Moriartii is offline   Reply With Quote
Old 09-03-2010, 10:07 AM   #10
hypurone
I'm not totally useless..
hypurone's Avatar
Drives: ...
thanks.
Changed mine at 2500 (I'm anal about changing fluids after a "break-in" period). No, there is no "break-in" period defined by GM but I have been around long enough (was a tech for 20+ years) and had enough vehicles to see it all. Cheap insurance and you know that the fill level is correct!
No shavings but the fluid was silvery. Looked almost like liquid silver! There was fine silver powder only on the drain plug....
"You were really flyin' when I passed you back there!" - Born on 10/05/09 MyCamaroBuildInfo
hypurone is offline   Reply With Quote
Understanding Brake Fluid: DOT 3, DOT 4, DOT 5.1 TAG UR IT Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 58 12-01-2019 10:54 PM
Custom wheel offset question ... Bowtie Junkman Wheels and Tires Talk Sponsored by The Tire Rack 4 04-23-2010 06:16 PM
I want to change rear diff and tranny fluid.?? The Enforcer V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 6 04-06-2010 04:11 PM
LS3 manual trans fluid change - less noise, etc? TommyTSquared V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 33 03-14-2010 07:05 PM
MXO/REAR DIFF QUESTION PoleCat2SSRS2010 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 2 02-24-2009 08:57 PM
