Old 09-01-2010, 02:21 PM   #1
UT-Engineer
Just Cruisin'
UT-Engineer's Avatar
Drives: 2010 Synergy Camaro
V6 Autos. engine lag?
Yesterday i noticed when i jumped in the car and put the gas pedal all the way down it felt as if the engine took a while to respond and take off. I have "punched-it" before from a stop and i have been able to get the wheels to spin and slide right from underneath me. This wasnt the case yesterday. I had TC and stab. control removed. Could engine temp, weather, etc play a difference. I have the v6 auto and put this in M mode. Any thoughts from othe v6 owners. Also, for future reference, which combination of TC, stability control, D mode, M mode, will give me the fastest acceleration from a stop? Thanks.
2010 Synergy Green Camaro
25% Tint - CGM Painted GM GFX - 20" Niche M102 Wheels
UT-Engineer is offline   Reply With Quote
Old 09-01-2010, 02:24 PM   #2
ghazzi1397
Hail to the GENERAL
Drives: 2011 CGM 2LT/RS
I noticed that weather makes a difference, usually around here in Jersey its around 90 degrees in the morning and around 70 at night. I find the car more responsive at night under hard acceleration and I have NO mods at all, plain STOCK
ghazzi1397 is offline   Reply With Quote
Old 09-01-2010, 02:27 PM   #3
UT-Engineer
Just Cruisin'
ok, I figured weather would be the biggest consideration. yesterday was near a scorchin 100 degrees here in south TX. any ideas on the best combo for hard acceleration with respects to TC and Stab. Control, D mode and M mode?
Old 09-01-2010, 02:31 PM   #4
ghazzi1397
Hail to the GENERAL
i dont have actual timing but i felt the car is best performing when TC and Stab Cont. are off, the car is on Sport Mode and at night (low temp.). This combination make me feel like I can beat a ZR1 in 0-60 time (j/k )
Old 09-01-2010, 02:39 PM   #5
UT-Engineer
Just Cruisin'
LMAO. Cool, yea i wish someone would post up their 0-60 numbers of the 6 different possible combos.
1) D mode alon
2) M (sport mode) alone
3) D with TC removed
4) D with TC and SC removed
5) M with TC removed
6) M with TC and SC removed
Old 09-01-2010, 02:45 PM   #6
UT-Engineer
Just Cruisin'
Originally Posted by jparnapy View Post
I can't wait for the Tx heat and humidity to go away.......
tell me about it. hey u live in rowlett? i had an internship in dallas back in 2006 and worked on constructing a wachovia bank in rowlett, Tx lol....sorry off topic
Old 09-01-2010, 03:00 PM   #7
UT-Engineer
Just Cruisin'
yeah i know. this morning was rather cool on my drive to work and the car felt a little more resposive to the throttle; however, i didnt want to test turning off my TC and SC in the morning stop n go traffic. Cant wait for the Fall and Winter so this car can breathe a little better.
Old 09-01-2010, 07:11 PM   #8
Travis64
Travis64's Avatar
Drives: 2011 Camaro 1lt rs auto 4-9-11
lol u guys have the ac on duh
Travis64 is offline   Reply With Quote
Old 09-01-2010, 07:28 PM   #9
DevilKnightFalcon
Drives: 2010 Camaro 2LT/RS
Send a message via AIM to DevilKnightFalcon Send a message via Yahoo to DevilKnightFalcon
Temperature definitely makes a difference however if your V6 is stock that is a reason also. I found that my car got much more responsive when I installed my intake, exhaust and definitely when I put the headers on. Keep in mind though you do have an auto (as do I) so there are some cases where the computer will take a second to downshift. This was being discussed in another thread somewhere. If you want to ensure you always take off immediately you can throw it in M mode and use the paddle shifters.
1) D mode alon
That would be interesting to see. Turning stabillitrek off shouldn't make much (if any) difference in your 0 to 60 times since it is really only meant to kick in if you start to spin out or something and if you are doing 0-60 you are testing (hopefully) straight line acceleration. Traction control makes a big difference as will putting it in sport mode.
Native New Yorker been here since 2003. I am so over this weather this summer.......I was out the other morning after the storms had cooled us off and the humidity had gone away and the car was like a whole different car.....
Trust me I feel your pain. When I went to lunch today it was 109 degrees. We regularly hit over 110.
DevilKnightFalcon is offline   Reply With Quote
Old 09-01-2010, 07:41 PM   #10
Michelle42780
Cracker
Michelle42780's Avatar
Drives: 2010 2LT/RS Summit White/Beige
I didn't know you were from NY, I'm from MA... woohoo, a fellow Yankee in TX!! lol
The cooler weather definitely makes a big difference. I would even notice it in my Kia, it loved the 60ish degree weather.
2010 Camaro | 2LT | RS | Summit White | Beige Interior | Born: 5/10/10 | Purchased 5/28/10
Michelle42780 is offline   Reply With Quote
Old 09-01-2010, 08:01 PM   #11
Michelle42780
Cracker
yes another yank!!!!!!!!!!!!!
I moved here in 2003 also, thankfully neither of us have that Yankee accent anymore! No offense to my fellow Yanks
I gatta go pahk my kah in Havad Yahd!
Old 09-01-2010, 08:13 PM   #12
Iomcamaro
The enjoyment never ends
Iomcamaro's Avatar
Drives: 2010 1LT/RS IOM #25223
I have found that if you turn the stabilitrak off it makes my take offs slower. My car is bonestock A6 also. I put the car into Manual mode and turn the TC off. I can spin tires doing this, but only if I hold the break which we all know that is a bad idea and bad for your car. I usually put it in first gear and hold the brake with my left foot. I rev the car to about 2-3,000 RPMs ( the limit before the car starts to pull itself or spins tires). whenever the light turns green, I drop the brake like you would drop a clutch, and floor it. This gets me a more responsive time in my car.
Iomcamaro is offline   Reply With Quote
Old 09-01-2010, 08:16 PM   #13
Speed 1
Speed 1's Avatar
Drives: 2010 LS Camaro 365 days a year
I gatta go pahk my kah in Havad Yahd![/QUOTE]
Born 5-15-09_LS_Auto_VIN. # 16507
Speed 1 is offline   Reply With Quote
Old 09-01-2010, 10:00 PM   #14
melody301
NY Football Giants YAY!!!
melody301's Avatar
Drives: 2011 LS
I noticed this with mine too when driving in automatic mode but in sports mode or manual it's an instant response from the engine when you gun the accelerator.
melody301 is offline   Reply With Quote
Supercharger / Turbocharger Results (INFO) Thread radz28 Forced Induction - V8 273 08-15-2023 05:44 PM
Hot air Intakes -By Kenne bell ADM PERFORMANCE Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 66 02-08-2011 09:33 PM
LS3 engine specifications Tran Wiki 3 10-06-2010 11:56 PM
The BEST Break for a new car. "very long" Darin Morgan General Automotive + Other Cars Discussion 346 02-04-2010 07:49 PM
Axial Vector Engine Mr. Wyndham General Automotive + Other Cars Discussion 6 06-20-2007 05:00 PM
