Old 09-02-2010, 06:19 PM   #1
jordan 572
jordan 572's Avatar
Drives: none
LS3 vs Vortec 6200
The vortec 6200 is a 6.2l engine in silverados, tahoes, escalades etc. It make 403 hp and 417 hp. Is this just a detuned ls3?
jordan 572 is offline   Reply With Quote
Old 09-02-2010, 06:51 PM   #2
LS3SSRS
LS3SSRS's Avatar
Drives: 2010 IBM SS/RS
its a L92 engine with vvt
**sold** 2010 2SS/RS, 6spd manual, imperial blue metallic w/black leather
Blacked out tail/signal lights, 5% rear tint, 20% sides, Dynomax Bullet mufflers, Barton short throw shifter, Clear Image offroad downpipes
LS3SSRS is offline   Reply With Quote
Old 09-02-2010, 07:19 PM   #3
jordan 572
jordan 572's Avatar
Drives: none
how does vvt timing work I know it adjusts the time valves are opened and closed during different rpms but how?
Old 09-02-2010, 08:16 PM   #4
MG
MG's Avatar
Drives: 2011 Camaro
I asked this question before..... the L92 is an iron-block designed for truck duty. Our aluminum LS3's and L99's weigh significantly less. For 2010 they also have AFM.
MG is offline   Reply With Quote
Old 09-03-2010, 10:44 AM   #5
fastsspr
Drives: Red SS
How many pounds you think is the diferent in weigh? The heads are the same?
fastsspr is offline   Reply With Quote
Old 09-03-2010, 12:02 PM   #6
jordan 572
jordan 572's Avatar
Drives: none
the only difference i could find was that the ls3 springs and valves are lighter and a little higher compression and no vvt. They both have aluminum blocks. There had to be more stuff different but I cant find anything.
Mast Motorsports Cam Slugfest (VVT vs LS3) SGOS252382 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 05-14-2010 10:13 PM
LS3 and L99? black2black10 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 26 05-07-2010 01:58 AM
Specs on L99 vs LS3 .... Bowtie Junkman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 3 04-28-2010 01:26 PM
LS3 Specs revealed: GM's 436hp Sick 6.2L LS3 TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 07-30-2009 07:02 PM
Check your Order here bvonscott Camaro Price | Ordering | Tracking | Dealers Discussions 665 06-29-2009 02:00 PM
