Old 09-02-2010, 11:29 PM   #1
Cam_Cam10
Cam_Cam10's Avatar
Drives: 2010 1LT, 6 speed, no mods yet
V6 help
So I've had mt Lt for about 6 months and just hit that 7,000 mile mark.
I've been really happy except for recently. I use royal purple motor oil and a mobil 1 synthetic oil filter. My camaro has gone through and additional quart and a half of oil in a month.
There is no noticeable oil leakage anywhere.
That's only the first problem the second is that it makes an obnoxious squeaking noise from the rear passenger side tire. Only when I'm driving not when I'm braking, like around 30 MPH. I'm guessing that it might be a loose bearing. I've taken it to the dealership all they say is bring it back when it worsens.
Any suggestions
Cam_Cam10 is offline   Reply With Quote
Old 09-02-2010, 11:36 PM   #2
RubyCamaro
Jan
RubyCamaro's Avatar
I am at close to the same mileage on my Camaro V6. I changed to synthetic oil at my first oil change. Mine has only been a little low on oil a couple of times but no big deal. No noise from my wheels, but I'd tell the dealership I don't want to wait until I am broken on the side of the road or some big problem develops. It is a new car, it needs to be fixed.
Old 09-02-2010, 11:43 PM   #3
Cam_Cam10
Cam_Cam10's Avatar
I've ran full synthetic since day one.The first 2months I had it it cleared 2 quarts in a little over a month. I understand a small top off amount here and there but 2 quarts. The squeaking noise is terrible. I took it to them at the beginning all they kept saying is they can't find a problem. Now the engine light comes on randomly.
Old 09-02-2010, 11:49 PM   #4
DarkneSS
Drives: 2010 Camaro 2SS/RS 6MT
The squeaking might just be your seat belt buckle, mine needed to be oiled at 23 miles.
DarkneSS is offline   Reply With Quote
Old 09-02-2010, 11:53 PM   #5
WHIPPLECHARGED
WHIPPLECHARGED's Avatar
Drives: 2011 1SS
Dude you need to get that fixed. I check my oil regularly and it has never been low. I switched to MObil 1 at 1k miles and changed it again at 3,500.How often do you change your oil? If you don't change every 3 to 4,000 miles the engine will start to burn away some of the oil. I would tell the dealer they need to check the engine for excessive oil consumption.
WHIPPLECHARGED is offline   Reply With Quote
Old 09-03-2010, 12:14 AM   #6
Cam_Cam10
Cam_Cam10's Avatar
It's 100% not the seat belt. LOL
but I change my oil every 2,500 to 3,500 miles
the first two i did really quick like one was at 1,100 and the other at 2,000. I always ran mobil 1 full syn. Now its Royal Purple
Old 09-03-2010, 12:26 AM   #7
WHIPPLECHARGED
Drives: 2011 1SS
Then you should not be losing oil. That is unacceptable on a new car with 7k miles. Get that noise fixed also, that's why we have warranty to fix concerns that are a nuisance.
Old 09-03-2010, 12:29 AM   #8
Cam_Cam10
Cam_Cam10's Avatar
I wish it was that easy. The mechanic says the can't find it, ( it meaning the oil problem)
but for the squeak they say come back when it gets worse.
I guess I'll try in the A.M
and take it to the shop again
Old 09-03-2010, 12:30 AM   #9
Cam_Cam10
Cam_Cam10's Avatar
double post sorry
Old 09-03-2010, 11:16 AM   #10
zen
Drives: 2011 CTS CPE & 2010 2LT/RS CGM
The squeek could just be the brake pads. Re oil consumption, try using regular (fosil) oil for a few thousand miles. Check your oil consumption with regular oil. If it improves then go back to synthetic. As often as you change your oil, regular oil is more than adequate.
zen is offline   Reply With Quote
Old 09-03-2010, 12:32 PM   #11
camarofanatic
camarofanatic's Avatar
Drives: 2010 camaro
is it a squeeking noise or a clicking my v6 makes a clicking noise when accelerating
camarofanatic is offline   Reply With Quote
Old 09-03-2010, 12:32 PM   #12
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
Yeah getting the dealer to do the warranty work is such a pain in the ass, oh well, if they keep procrastinating it, ill just give GM a call again.
Also the car eats a hell of alot of oil. As much as i love my camaro, which is to death, i cant believe the number of problems im having with it. The heated seat doesnt work anymore, cabin squeaks like crazy, rattling noises, buzzing noises, blown speaker, had a tranny problem, eats oil, window indexing problem. And the list goes on. I know that these are all minor fixable problems but weve bought cars before that were first year produced and never ran into this much problems.....going to chek my oil today.
Alot of people have had an oil leak, maybe its that?
CAMARO
Old 09-03-2010, 01:12 PM   #13
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
Take it to a different dealer.
Old 09-03-2010, 10:49 PM   #14
VR Baron
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE
6500 miles on dyno oil, changedfirst at 2500 and 2nd one Iwill do soon. No consumption at all.Some synthetics burn oil as some tend to thin out to much when hot. Mobil one does this and burns up to a quart in 3000 miles on our older LS1 engines, We all hated it and dont use Mobil one for the most part.If I go synthetic it will be German Castrol 0-30 as it outperforms by a good deal and doesn't thin out at higher temps and keeps the engine cleaner.this is important for our engines as they rev higher then the v8;s normally whenwe are out having fun!
VR Baron is offline   Reply With Quote
V6 Camaro Performance Upgrades rtcat600man Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 387 09-19-2019 07:53 PM
V6 Gas Questions Markal Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 25 06-28-2010 03:49 PM
V6 Cami VS V6 Genesis..LOL MillerTime Chevy Camaro vs... 226 06-09-2010 10:00 AM
2010 Camaro SS & V6 Line Lock/Roll Control Meister@Torq Suspension / Chassis / Brakes 0 02-23-2010 12:27 PM
V8 appearance vs. V6 Discussion! jpsuperman81 5th Gen Camaro SS LS LT General Discussions 19 08-08-2009 10:01 AM
