Old 09-04-2010, 05:46 AM   #1
robertway
robertway's Avatar
Drives: 2012 Challenger SRT8 Auto
What have you broken, how did it happen, how much power do you have?
In my seemingly never-ending quest to decide which route to go with forced induction one of the things that continues to pop up is "how much can the stock bottom end and driveline handle?" What appears to be the general feeling is around 550RWHP is when one should start looking beyond the stock platform and start addressing other things.
I'd be interested to know who has actually broken something out there in the engine or the driveline be it on a stock car or a modified one so the questions are?
1) What have you broken?
2) What mods do you have?
3)If you have forced induction what kind and how much boost are you running?
4)How much RWHP and RWTQ do you have?
5)What were you doing when something broke, i.e. side stepping the clutch at the strip or just out driving miss daisy?
I know a lot of the equation is how you drive your car as opposed to an absolute number because we know it is possible to break things with just the stock power output but I was hoping if all the incidents could be noted in one thread a pattern may start to show up as to when, why, and how things are breaking. Whether something is a fluke or there is a pattern building.
Thanks in advance....
"When the people find they can vote themselves money, that will herald the end of the republic." - Benjamin Franklin
LS3 Camshaft Swap Do-It-Yourself Instructions - 2010 LS3 gone but not forgotten!!!
robertway is offline   Reply With Quote
Old 09-04-2010, 07:35 AM   #2
Kwaz1335
The Kwaz
Drives: Black 2010 Camaro 2SS/RS
Send a message via AIM to Kwaz1335
The stock internals and driveline are actually stronger than most think.I myself have not broke anything. I know I'm going to get into an argument here because some people can't get it through their thick heads that these cars were built with the knowledge that people were going to beat the piss out of them. 600hp seems to be a safe zone for these cars..anything more and your taking a chance. Anything over 8lbs and your going to have to start changing injectors,building a new bottom end, adding long tubes and a boost a pump. I have heard of people running up to 8lbs of forced induction without any problems.
The body structure is very solid as well and you won't need any bracing unless you plan on having your car see the track more than the street.
Unless you plan on dropping the clutch from redline..and only a person who didn't know what they are doing would...you won't have much of a problem as long as you stay under the 600 horsepower mark. I have heard of people dropping the clutch at 3-4000 RPM's and have had no problems...I can attest to this as I've done it myself many times without a problem.
Superchargers cause less damage than one would think. If you ever had the chance to work for a top fuel team...and I have..you would realize that the one part that is used multiple times is the supercharger.
Loss of oil pressure and mainly heat are what causes most damage to an engine. If you ever had the chace to look at the internals of a dragster you will notice a long tubular metal can with a pressure gague on it. The main purpose of this can or pressure feeder is to force oil at a high pressure to keep oil going to the front of the motor. Without this can..oil will not flow to the front of the motor under the force of speed. It's usually the rings that are the first to go in a top fuel motor. A top fuel block is usually only good for about 2 passes as they clean up the motor and resize the rings inspect all other parts and replace what looks like it can cause a problem during the next pass.
Of course there are the teams that completely rebuild the block with new parts..but most teams save money where they can and reuse parts that have been cleaned and inspected. Parts are however not reused the same day and like a conveyor belt are rotated.
I know I'm going off on a tangent here but, my main point is...it's pretty hard to screw things up with this car. I know some would argue with me...and I bet it's bound to happen..as it's happened before. It's funny how some people who have had this car for a few months are so misinformed they are willing to sit there and argue with people who have degrees in mechanical engineering, spent many years in a machine shops, built and rebuilt engines, been to perfomance oriented colleges for cars, have built and designed the parts for these cars themselves, those that have spent years on racing teams..people with knowledge banging their heads trying to teach those who want to learn. I have heard some really stupid and misinformed comments here...and quite frankly...this probably will be my last post here. I'm tired of correcting the misinformed..then arguing with someones ego because they can't admit they were wrong. I apologize to the OP for jacking this thread..but I feel what was said had to be. Ban me if you would like...I don't really plan on coming back here much more anymore anyway. Rant Over!!!
Ordered:3/13/09
1100: 3/13/09
3300: 5/12/09
Picked up and brought home 6/26/2009
2010 Black on Black SS/RS Camaro
Silver stripe package
Ground effects package
6 Speed Manual Transmission with Hurst short throw, Magnuson Supercharger, SLP loudmouth 1 kit.
Kwaz1335 is offline   Reply With Quote
Old 09-04-2010, 09:19 AM   #3
fearless
Drives: 2010 camaro 1ss grey/black
Originally Posted by Kwaz1335 View Post
The stock internals and driveline are actually stronger than most think.I myself have not broke anything. I know I'm going to get into an argument here because some people can't get it through their thick heads that these cars were built with the knowledge that people were going to beat the piss out of them. 600hp seems to be a safe zone for these cars..anything more and your taking a chance. Anything over 8lbs and your going to have to start changing injectors,building a new bottom end, adding long tubes and a boost a pump. I have heard of people running up to 8lbs of forced induction without any problems. The body structure is very solid as well and you won't need any bracing unless you plan on having your car see the track more than the street. Unless you plan on dropping the clutch from redline..and only a person who didn't know what they are doing would...you won't have much of a problem as long as you stay under the 600 horsepower mark. I have heard of people dropping the clutch at 3-4000 RPM's and have had no problems...I can attest to this as I've done it myself many times without a problem. Superchargers cause less damage than one would think. If you ever had the chance to work for a top fuel team...and I have..you would realize that the one part that is used multiple times is the supercharger. Loss of oil pressure and mainly heat are what causes most damage to an engine. If you ever had the chace to look at the internals of a dragster you will notice a long tubular metal can with a pressure gague on it. The main purpose of this can or pressure feeder is to force oil at a high pressure to keep oil going to the front of the motor. Without this can..oil will not flow to the front of the motor under the force of speed. It's usually the rings that are the first to go in a top fuel motor. A top fuel block is usually only good for about 2 passes as they clean up the motor and resize the rings inspect all other parts and replace what looks like it can cause a problem during the next pass. Of course there are the teams that completely rebuild the block with new parts..but most teams save money where they can and reuse parts that have been cleaned and inspected. Parts are however not reused the same day and like a conveyor belt are rotated. I know I'm going off on a tangent here but, my main point is...it's pretty hard to screw things up with this car. I know some would argue with me...and I bet it's bound to happen..as it's happened before. It's funny how some people who have had this car for a few months are so misinformed they are willing to sit there and argue with people who have degrees in mechanical engineering, spent many years in a machine shops, built and rebuilt engines, been to perfomance oriented colleges for cars, have built and designed the parts for these cars themselves, those that have spent years on racing teams..people with knowledge banging their heads trying to teach those who want to learn. I have heard some really stupid and misinformed comments here...and quite frankly...this probably will be my last post here. I'm tired of correcting the misinformed..then arguing with someones ego because they can't admit they were wrong. I apologize to the OP for jacking this thread..but I feel what was said had to be. Ban me if you would like...I don't really plan on coming back here much more anymore anyway. Rant Over!!!
Paragraphs are your friend.
fearless is offline   Reply With Quote
Old 09-04-2010, 09:24 AM   #4
mhood
Orange Camaros Rule!
mhood's Avatar
Drives: 2010 1SS LS3 RS IOM
Lithium too.
mhood is offline   Reply With Quote
Old 09-04-2010, 10:08 AM   #5
Kwaz1335
The Kwaz
Better?
Ordered:3/13/09
1100: 3/13/09
3300: 5/12/09
Old 09-04-2010, 11:27 AM   #6
2010 Bumblebee
2010 Bumblebee's Avatar
Drives: Transformers Edition Camaro 2SS/RS
Don't let them get to you We can agree to disagree sometimes
The Yellow Camaro Club
http://www.camaro5.com/forums/group.php?groupid=128
Northern Massachusetts & Southern New Hampshire Camaro Club
http://www.camaro5.com/forums/group.php?groupid=127
The mother of all supercharger questions thread
http://www.camaro5.com/forums/showthread.php?t=77958
My 2010 Camaro Review
http://www.camaro5.com/forums/showthread.php?p=2025442#post2025442
2010 Transformer Edition Camaro L99 Auto
2010 Bumblebee is offline   Reply With Quote
Old 09-04-2010, 11:40 AM   #7
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
PM sometime. Have some rough guidelines that may help.
Old 09-05-2010, 06:00 AM   #8
fastfaster
Drives: xxxxxxxxxxxxxx
i only broke my diff with 732 rear wheel horse.
broke it on a powershift (from 1 to 2).
fastfaster is offline   Reply With Quote
Old 09-05-2010, 12:55 PM   #9
Rockhead
Hoser.
Rockhead's Avatar
Drives: 2018 Z06
I broke the speed limit once, I was passing a Vespa, 426 hp. I promise I won't do it again.
Speed is a substitute for clearance.
Rockhead is offline   Reply With Quote
Old 09-05-2010, 01:05 PM   #10
BlaSSt Off
BlaSSt Off's Avatar
Drives: 2SS/RS
I broke my wallet at around 530hp... LoL
BlaSSt Off is offline   Reply With Quote
Old 09-05-2010, 01:20 PM   #11
DarrenJ
DarrenJ's Avatar
Drives: '67 Camaro ZZ4 & 2010 IOM 2SS
Better?
I thought it was an awesome post with real expectations. Great job!
DarrenJ is offline   Reply With Quote
Old 09-05-2010, 01:37 PM   #12
Ivas
el Ruco
Drives: 2010 Camaro SS (now runnin' TENS )
Red face What broke so far...
The OEM clutch was swapped out early on to accommodate some additional hp from a professional tune, long tubes, Borla exhaust no cats, cai and drs. Nevertheless, the new Fidanza blew out at Irwindale Dragway. Next the engine was cammed, new ported heads, valve springs and Kenne Bell charged. This time I broke the output shaft bearing and shitted the transmission.
I suppose the next weakest links to go will be the axles, drive shaft and the differential...
Ya' gotta' love goin' fast more than your wallet, eh?
Ivas is offline   Reply With Quote
Old 09-05-2010, 01:51 PM   #13
Ronn
Ronn's Avatar
Drives: 2010 Camaro
You made some good points.
1SS / RS / M6 / IOM / Black rally stripes / Polished wheels
It's a high school prom, it's a Springsteen song, it's a ride in a Chevrolet...
Ronn is offline   Reply With Quote
Old 09-05-2010, 08:18 PM   #14
robertway
robertway's Avatar
LOL, mine isn't broken but it's days are numbered
Who is going on the Power Tour? - Join us at a stop near you!!!! MTI Racing 5th Gen Camaro SS LS LT General Discussions 60 06-22-2010 12:23 AM
starter gets no power... please help zebra General Automotive + Other Cars Discussion 16 11-12-2009 10:37 PM
Would you Twin Turbo for the right price? peteypab2133 5th Gen Camaro SS LS LT General Discussions 79 11-09-2009 05:57 PM
Addressing Power Hop on the IRS Mr. Wyndham 5th Gen Camaro SS LS LT General Discussions 16 11-01-2008 07:15 PM
