Old 09-04-2010, 01:40 PM   #1
toast
Toast
toast's Avatar
Drives: 2010 Camaro 2SS/RS
Line Lock
What is the best line lock for this 2010 Camaro?
2SS/RS/M6 - 628 RWHP, 564 RWTQ
Magna Charger Supercharger - ADM Stage 2 Blower Cam - ADM Race CAI - Pfadt Solid Subframe Mounts
ADM Duel Fuel System - 60# Injectors - Pfadt Rear Trailing Arms, Tie Rods, Balance Sway Bar
Pfadt Engine Mounts and Diff Bushings
- 3.73 Gears - Line Lock - MGW Short Throw Shifter
ARH Headers with 3" catted X-Pipe - MagnaFlow 3" CatBack - RPM Level VI Transmission
Street Slayer Triple Clutch - NGK TR6 Spark Plugs - 160 degree thermostat - ADM Coil System
ADM Performance Custom Tune
toast is offline   Reply With Quote
Old 09-04-2010, 03:07 PM   #2
SILVER BULLITT
Drives: 2010 SIM 2SS/RS MONSTER
HP MONSTER' SOUTHERN CALIFORNIA BUILT, LMR CAI, CUSTOM GRIND CAM, CUSTOM BUILT CNC PORTED AND POLISHED HEADS, FAST 102MM INTAKE MANIFOLD,ARH LONG TUBES AND HIGH FLOW CATS, BIGGER INJECTORS, VALVES SPRINGS RETAINERS, MGW SHORT SHIFTER, EIBACH SPRINGS, FACTORY CHROMED WHEELS, BLACKED OUT EMBLEMS, BLACKED OUT ROOF,BLACKED OUT MARKERS, 3.5 INCH ELECTRONIC CUTOUTS, FLOWMASTERS, ZEX WET 150 SHOT, FOR A GRAND TOTAL OF =630 REAR WHEEL TORQUE ,AND 600 REAR WHEEL HORSEPOWER
MY JOURNALhttp://www.camaro5.com/forums/showth...02#post2023802 SOON TWIN TURBO SETUP
SILVER BULLITT is offline   Reply With Quote
Old 09-04-2010, 04:24 PM   #3
flyby
Drives: 2010 Silver SS
SJM Manufacturing, have one on my car, works great.
flyby is offline   Reply With Quote
Old 09-04-2010, 05:32 PM   #4
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
sjm or make your own.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
danhr is offline   Reply With Quote
Old 09-04-2010, 06:15 PM   #5
TeddyP25
TeddyP25's Avatar
Drives: 2SS
SJM, works great.
2SS/RS CGM/BLK GFX MN6418 Stroker.785rwhp/885lbtq.50 SHOT NO2..Pfadt arms,toe links,coilovers,swaybars,end links,engine mounts,dif/sub bushings.MGWshifter.Tick LVL 3.ARH1 7/8 LT's/ARH exhaust.ADM gauges/race CAI.E-FORCE SC.8 rib IW 10%OD.LPE dual pump/module.85lb inj,custom valve covers.RMCR tune.TOOLEY RACING CAM.JRE posi kit.JRE fuel upgrade.RX MONSTER CatchCan.DSS axels/DS.Hammerhead rear, 3:73's. WYOSPEED builthttp://www.camaro5.com/forums/showthread.php?t=115687
TeddyP25 is offline   Reply With Quote
Old 09-05-2010, 05:53 AM   #6
SILVER BULLITT
nice thanks
Old 09-05-2010, 11:11 AM   #7
LoneStar
LoneStar's Avatar
Drives: 2011 IOM Camaro
Okay, I'll be the stupid one that asks "what's a line lock?"
LoneStar is offline   Reply With Quote
Old 09-05-2010, 11:14 AM   #8
TeddyP25
TeddyP25's Avatar
Drives: 2SS
Locks the fronts so you can do a burnout.
Old 09-05-2010, 01:05 PM   #9
SJM
Drives: Camaro
To add a bit of info to the above comment, a line lock allows you to clean/heat the rear tires easily without the brakes applied to them. The front brakes stay locked so the car is controllable while you clean/heat the rear tires. This reduces stress/wear to the driveline as well as prevents damage/wear to the rear pads and rotors. When you're finished, you release the control switch and the car will roll foward (if you're rear wheels are still spinning). You've probably seen this many times from racers at the track.
Without a line lock, you would have to either step on the brakes and the gas and overcome the rear brakes to spin the tires or stomp on the gas and try to control the car from moving forward. Either way is not the best method and places additional stress and wear on your cars components...not to mention doesn't retain the same control over your car compared to using a line lock system.
Here's a video demo of which a camaro5 member took using one of our kits on his car. I wish I knew his name, but it is a pretty good video that is self explanatory.
He changed the circuit slightly. Normally, the LED turns on when you activate the master switch, not the control switch.
SJM is offline   Reply With Quote
Old 09-05-2010, 01:36 PM   #10
LC
ou mai gad
LC's Avatar
Drives: SW 2SS x2
Steve,
Long time no see...
Can you PM me details on a set of fronts skinnys for SS brakes please...
LC is offline   Reply With Quote
DIY Brake Calipers Rotors and Line Removal Gotthat02fire Camaro DIY & HOW-TO instructions & discussions 31 02-14-2012 07:52 PM
2nd Gen. Line Lock Kit carsismeZ06 1st & 2nd Generation Camaros 2 05-29-2010 12:58 PM
2010 Camaro Line Lock Kit? Windy City Wheels and Tires Talk Sponsored by The Tire Rack 15 11-09-2009 11:05 PM
# of Cars on Line...? carguy 5th Gen Camaro SS LS LT General Discussions 6 06-09-2009 12:32 PM
