Old 09-05-2010, 02:49 PM   #1
jagan323
I have no life
jagan323's Avatar
Drives: 06' Subaru STI, ex-Camaro V6 LLT
Fuse Pull gave me CEL
Hi guys,
I did a fuse pull yesterday to reset my fuel trims... and this morning, I got a CEL. Is this normal?
Well, for now, i cleared the code with my Dashhawk... but I just hope i didnt permanently damage anything. Any ideas would be nice, for peace of mind.
=D
jagan323 is offline   Reply With Quote
Old 09-05-2010, 02:54 PM   #2
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
Fuse pull is for the V8 specifically the L99 somewhat less for the LS3. Not sure if the same # fuses will have the same effect on the LLT V6. They might not have even been numbered to the same components. Chances are it will be fine it probably just thinks you blew a fuse and now that it's "corrected" it should be fine.
9/26/09 Took delivery!
Old 09-05-2010, 02:56 PM   #3
jagan323
I have no life
jagan323's Avatar
Well, yea im v6, but the Fuse numbers should be the same. Since it's resetting the same thing. #5 and #20, engine control and ignition. =p Well, hopefully the CEL wont come back and I didn't break anything.
Old 09-05-2010, 03:17 PM   #4
macwest
Drives: 10 Camaro 2SS/RS, 70 Cuda, 71 Cuda
Cel is normal. After getting the code drive for a short distance and it will go away.
macwest is offline   Reply With Quote
Old 09-05-2010, 03:19 PM   #5
formare
The Milano
formare's Avatar
Drives: 2017 Firefly ShipWorks
Yes it's normal... Drive around vary your style for about hour or so. Next time you start the cel will go off.
My first Love. She was called "Miss Carriage" (still cry when I think about her)
383, Muncie 4 speed, custom linkage mated to hurst short throw shifter.
formare is offline   Reply With Quote
Old 09-05-2010, 05:03 PM   #6
jagan323
I have no life
jagan323's Avatar
thanks guys You guys are the best. Well I cleared the Code with my OBDII scanner... so i guess it wont come back now =D
Old 09-06-2010, 06:45 PM   #7
Jefe's SS
Drives: 2010 2SS/RS IOM L99
Why would you do a fuse pull for the V6? The fuse pull is for timing/fuel reset on the V8 when a low octane fuel is detected. AFAIK the V6 does NOT require high octane fuel. Hence there will be no improvement with a fuse pull.
Jefe's SS is offline   Reply With Quote
Old 09-06-2010, 07:28 PM   #8
camaroitalia
Go Harder Than Baltimore!
camaroitalia's Avatar
Drives: 2010 CGM
what is a CEL? lol
Old 09-06-2010, 08:54 PM   #9
fearless
Drives: 2010 camaro 1ss grey/black
Originally Posted by camaroitalia View Post
what is a CEL? lol
Check engine light
fearless is offline   Reply With Quote
Fuse Pull: Low Octane Fuel Fix For L99 and LS3. Reset Fuel Map for High Octane Fuel. radz28 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2838 05-11-2024 11:42 PM
Fuse Pull - Other GM Vehicles L99SS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 08-19-2010 03:06 PM
Fuse Pull or Not zerox 5th Gen Camaro SS LS LT General Discussions 30 07-14-2010 08:44 PM
#230 1 Day After Fuse Pull 0-60 Scott@Bjorn3D Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 21 08-25-2009 08:53 PM
8327 after fuse pull redjewel Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 30 08-25-2009 03:24 PM
