Old 09-07-2010, 09:52 PM   #1
Captain McFunk
Break Necks, Cash Checks
Captain McFunk's Avatar
Drives: 2010 black Camaro 2SS/RS
Running Thread: Header Install Questions
Okay, first time installing headers, I'm going to do it over the next couple of nights, as I work 8-5 during the day. I'm going to throw all my questions here.
How do you get the spark plug wires off? Is there a plug? do they come off from the bottom or top of the wire? if so, how?
Edit: These are Kooks LT 1 7/8" headers with offroad pipes connecting to stock exhaust with an axleback and electric cutouts. Got them from Branden at Maryland Speed.
ignore my girlfriends pink computer case haha
2009 CTS-V - White Diamond - intake, exhaust, wheels, visual mods
Captain McFunk is offline   Reply With Quote
Old 09-07-2010, 09:59 PM   #2
ITGuy11
Burning up tires
Drives: 2023 ZL1 Vert
Grab the fat rubber end of the spark plug wires and pull!
Not to sound like an ass, but if you don't know how to remove the plug wires, are you sure that you are ready to install headers?
BTW - took me 4 hours start to finish to install my Kooks. Could probably do it in half the time with a lift...
ITGuy11 is offline   Reply With Quote
Old 09-07-2010, 10:03 PM   #3
ackeight
ackeight's Avatar
Drives: 10' 2SS/RS
twist them a little bit before pulling. These are newer cars, but on some cars that haven't had the plugs pulled in awhile you may rip things out of the wires you don't want to unless you break the seal between the plug and wire.
ackeight is offline   Reply With Quote
Old 09-07-2010, 10:05 PM   #4
Captain McFunk
Got it. I knew to pull them, I was just tugging more than on other cars, and thought there might be something I didn't know. I'm pretty mechanically savy, just wasn't sure since i've for the most part had newer cars that I've never had to change the plug wires on. Thanks for the tip though.
Old 09-07-2010, 10:52 PM   #5
Hicompression
Rumbly Bumble Bee
Hicompression's Avatar
Drives: 2010 2SS Camaro
Disconnecting Front O2 Sensors
Hardest thing to do in my honest opinion was disconnecting the front O2 sensor plugs at the back of each head.
2010 RALLY YELLOW 2SS 6M
-OBX Longtubes FTW!
Hicompression is offline   Reply With Quote
Old 09-07-2010, 11:12 PM   #6
Captain McFunk
How do you disconnect the rear o2 sensors? Do they disconnect at the header end or on the plug end? If on the plug end, how do you get them unplugged? I can't see up there to see exactly how to unplug them!
Old 09-08-2010, 12:24 AM   #7
Captain McFunk
Got the clips off, they're just like the front ones, they have a plastic pin that locks it in place, once that's removed, you can unclip them like normal plugs.
Update for the night:
Driver side header finally off. Onto the passenger side tomorrow night!
The reason for this thread is so when someone searches for questions about header install, they have a one stop shop for it possibly, because i'm sure i'm going to ask every question in the book! haha.
Thanks guys!
Old 09-08-2010, 12:29 AM   #8
KnightRiderSS
Voodoo Medicine Man
KnightRiderSS's Avatar
Drives: Black 2SS with RS package
Here is a tip....I would have taken the o2 sensors off the exhaust pipe while it was still attached to the car...its a PITA to get them off after...
KnightRiderSS is offline   Reply With Quote
Old 09-08-2010, 02:50 AM   #9
2010SSRSM6
2010SSRSM6's Avatar
It might help to clarify if your doing LT's or shortys.
Old 09-08-2010, 03:26 AM   #10
Ivan @ Southwest Speed
Try this out...
http://www.camaro5.com/forums/showth...stall%2Freview
Agreed, disconnecting the HO2s wires, removing the plug wires and plus first is the most important part.
Then it's all spartan from there.
Best of luck and call me if you need any help....seriously,
Old 09-08-2010, 08:35 AM   #11
Captain McFunk
I should've thought about that, dang, oh well, I'll do it on the passenger side while they're still on the car, and work with the drivers side off the car and I'll post my results!
Old 09-08-2010, 08:58 AM   #12
Captain McFunk
Originally Posted by jpizzle007 View Post
it might help to read the original post.
He was right, I didn't have it listed when he posted. i went back and edited it so everyone would know.
Old 09-08-2010, 10:30 AM   #13
ArkySS
Camaroless for now...
ArkySS's Avatar
Drives: 2014 Blue Topaz Silverado
Did you replace your factory setup with these Funk or something else?
It was fun while it lasted.....
ArkySS is offline   Reply With Quote
Old 09-08-2010, 11:17 AM   #14
Captain McFunk
Old: Factory manifolds and cats. Factory piping all the way back to the axleback. Magnaflow competition axleback exhaust.
New: Kooks LT, factory piping all the way back to the axleback, Magnaflow competition axleback exhaust.
Complete ******** install from a Novice Susantroy1 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 63 07-31-2015 02:25 PM
Trouble after Header Install!!!! HELP! Cooper2010 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 50 03-16-2013 09:40 PM
Header install: how high? Captain McFunk Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 3 09-04-2010 08:59 PM
Another "Disable Running Lights" Thread l008com Cosmetics and Lighting Modification Discussions 7 08-11-2010 09:48 PM
Check out the thread 1st v6 STS turbo installed and running! Ex-stang Canada 2 07-06-2010 02:48 PM
