Old 09-08-2010, 10:25 AM   #1
TitoSS
TitoSS's Avatar
Drives: 2010 Camaro 2SS Red Black Int. L99
Advice on Wider Tire
Hey everyone i was getting new tires for my camaro needed some advice as if i should get a wider tire for the back OEM is 275/40/R20 i was thinking of going with either 295/40/R20 or 305/40/R20 ?
Tire brand choices, which one should i get ?
Pirelli P-Zero
Nitto Invo
Nitto NT05
TitoSS is offline   Reply With Quote
Old 09-08-2010, 10:44 AM   #2
d69chris
Florida C5
d69chris's Avatar
Drives: 2010 Camaro 2SS Vortech L99 IOM
Send a message via Yahoo to d69chris
I went with 275/40-20 up front on 9.5x20 wheels & 315/35-20 on rear on 11x20 wheels.
I went with Vredestein Sessanta tires. Was also thinking Nitto Invos
On tires, remember to stay at or real close to stock height. If not, it will effect speedo, ride height, and scraping stuff under your car. 315's match the 275 tire diameter. You can lower or raise your car by the tire diameter, sometimes that's not a good thing.
http://www.camaro5.com/forums/showthread.php?t=62838
Ordered 11/08/08....Del. 08/05/2009 Loving every minute of it! Don't hate me because i'm Pretty....
d69chris is offline   Reply With Quote
Old 09-08-2010, 12:24 PM   #3
clg_98ta
clg_98ta's Avatar
You're talking about aftermarket wheels?? I don't think you'll want to try to go that big on the OEM wheels.
btw, the 315's on 11" wheels look awesome on the car. That's what the Camaro should look like...
Old 09-08-2010, 12:52 PM   #4
orangeonwhite
orangeonwhite's Avatar
Drives: 2010 2SS/RS M6
looking at the chart, with OEM wheels there are no options other than 275's for the rear :(
orangeonwhite is offline   Reply With Quote
Old 09-08-2010, 12:54 PM   #5
mitchellmcfly2010
mitchellmcfly2010's Avatar
Drives: 07 Chevy Avalanche
i have 305's on my stock rear wheels, it fits perfect, the bulge is on the inner portion of tire, no bulge on the outside. no rubbing
mitchellmcfly2010 is offline   Reply With Quote
Old 09-08-2010, 03:47 PM   #6
Richy_Rich
FAVOR
Richy_Rich's Avatar
Drives: Many Different Rides
Side wall must be as perpendicular to the wheel face as possible... oversizing and undersizing tires is dangerous as the tire bead does not seat correctly in the rim bead lock. stick to stock sizing, unless you get wider wheels, then increase trad width and resuce aspect ratio.
Please be kind when you drive; thank you.
Richy_Rich is offline   Reply With Quote
Old 09-09-2010, 09:46 AM   #7
Nine Ball
Nine Ball's Avatar
Drives: 1969 & 2016 Camaro SS
Honestly, the factory rear 9.0" wide wheels are already on the narrow side for the factory 275 tire. The 275 tire is actually perfect for a 9.5" wide wheel. Will a wider tire fit? Sure. Will it be safe, or handle as well? Not likely. Of course, if you never like to take turns at speed, then it probably won't matter.
Tony
Fquick.com/NineBall
Are they rims or are they wheels?? topgun1 Off-topic Discussions 28 07-07-2010 12:02 AM
Ruined Tire scott53 Wheels and Tires Talk Sponsored by The Tire Rack 10 05-20-2010 08:00 PM
Local tire place messed up my paint, need advice philipdistefano 5th Gen Camaro SS LS LT General Discussions 35 04-21-2010 08:12 AM
Tire Monitoring System monevz28 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 7 11-22-2009 04:42 PM
500.00 per perelli tire not a myth! AVman Wheels and Tires Talk Sponsored by The Tire Rack 51 10-20-2009 04:45 PM
