![]() Drives: 2010 Camaro 2SS/RS Join Date: Dec 2009
line lock question
I have a line lock installed. Is it normal for the ''service stabilitrac'' to come on when I use it and when this message appears, is all the stabilitrac system is disabled?
Thanks
2010 2ss/rs Ls3, E-force s/c, 3.25'' pulley,Kooks long tubes w/cats, magnaflow 2.5" cat back, Rotofab cai, 65 lbs inj, MSD bap, AEM water/meth, comp cam, 621whp,577 wtq on mustang dyno
Blowin the doors off!
Drives: A 2013 SS RS 6M SR Join Date: Apr 2010
It will be if not used properly. Turn off stabilitrak and traction control ( hold button for 7 seconds ) and then use line lock. He system is sensing that something is wrong if you don't turn these systems off before using line lock.
2G1FS1EWXD9163847 |
Ah! My bad then. Forgot to turn everything off before. It will reset by itself when I drive I guess?
Ya a few ignition cycles should reset it.
2G1FS1EWXD9163847 |
| SJM Manufacturing 2010 Camaro Line Lock Kit | SJM | Suspension / Chassis / Brakes | 15 | 04-29-2010 09:38 PM |
| Line Lock on v8/m6 | GPD151 | Suspension / Brakes / Chassis | 0 | 01-19-2010 10:04 PM |
| Line Lock | chevyss | Dragstrip and Launch Techniques Discussion | 12 | 12-27-2009 01:21 PM |
| Lug wrench in SS? + wheel lock question... | DDustiNN | Wheels and Tires Talk Sponsored by The Tire Rack | 8 | 09-05-2009 01:52 AM |
| Lug wrench in SS? + Wheel lock question | DDustiNN | Wheels and Tires Talk Sponsored by The Tire Rack | 2 | 09-04-2009 05:16 PM |
