Old 09-24-2010, 12:34 PM   #1
nicendrine
nicendrine's Avatar
Drives: 2010 2SSRS RY
Best oil grade for tropical country?
Hi. My SS is due for an oil change, I live in the Philippines, it is hot in here. What grade of oil would you suggest? Should I keep using 5w30? or should I use 10w30? Thanks in advance for your help C5.
nicendrine is offline   Reply With Quote
Old 09-24-2010, 03:54 PM   #2
Russell James
Russell James's Avatar
Synthetic 10w30 with spec GM 4718M.
Old 09-24-2010, 04:42 PM   #3
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
What kind of temps are you looking at on a normal day?
Remember the only differences between these two oils is cold crank viscosity (denoted by the 5w and 10w). The 5w oil is rated to be used in temperatures no lower then -30 degrees F (-34 degrees C) while the 10w oil is rated to be used in temperatures no lower then -20 degrees F (-28 degrees C). In other temperatures these two oils will behave the same way.
DIY: Camaro Oil Change adub4185 Camaro DIY & HOW-TO instructions & discussions 180 04-23-2014 07:11 PM
ON STAR OIL Life % T_MECO Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 34 04-25-2010 09:55 PM
Great Read and Info on Oil Weight Banshee Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 11-23-2009 10:03 PM
Huge offshore oil discovery KILLER74Z28 Off-topic Discussions 36 11-14-2007 07:14 PM
