Old 09-24-2010, 03:56 PM   #1
papabearcamaro
papabearcamaro's Avatar
Drives: 2012 Chevrolet Silverado 4x4 Z71
People in cold climates...winter storage.
Decided to store my Camaro in an unheated,40,000SF building this winter. The building is all concrete including walls and floors.
My question is,since I won't have access to electricity to use a battery tender what do you guys in the north do battery wise over the winter? Owner of the building says it does not get extremely cold inside and most people do not pull out their batteries when they tuck their toys away. There are numerous motor homes,boats and cars parked in this building all winter.
Thoughts?
SOLD(Traded for 2012 Silverado Z71 4x4 and 2012 Sonic Hatch.)...2010 Camaro 1SS/RS/LS3,yellow with House of Kolor Tangerine Pearl rally stripes,manual trans.Hurst short throw shifter,4 pack rally gauges,Roto-Fab air intake,Kooks long tube headers with high-flow cats,Borla S-Type catback exhaust,Comp Cam,PRC ported heads,Maggie with 3.6 pulley and 1:1 cog drive,secondary fuel system with 65lb injectors,ADM digital A/F and Boost gauge,Pfadt trailing arms and subframe bushings.614.25rwhp/566.82rwtq on 8# of boost.
2012 Chevrolet Silverado 1500 EX.Cab 4X4 Z71.
papabearcamaro is offline   Reply With Quote
Old 09-24-2010, 03:58 PM   #2
Shift
Drives: Me 2001 F150, The wife '11 2SS RS
Just disconnect the battery if your not going visit it once in a while on nicer days, at worst you'll have to jump it when you pull it out
I'm not far north but its what I do with my boat for the winter
Shift is offline   Reply With Quote
Old 09-24-2010, 04:01 PM   #3
flyinglow57
Drives: rumble bee,2SS 6sp
disconnect the negative termanal and tuck it down somewhere so it doesnt flop back up to the neg post on the battery.. it will be fine. its probably a 10mm socket you need.
blk 2ss 6spd with sunroof.
intake,tsp cam,full exhaust,pcmforless tune,trailing arms,toe rods. hopeing for 11.9 because my g/f said she will take the cam and the suspension back if not.
flyinglow57 is offline   Reply With Quote
Old 09-24-2010, 04:14 PM   #4
Jayhawk500
Jayhawk500's Avatar
Drives: 2010 Camaro SS/RS
Although we don't get the cold weather as you do in Wisconsin, My car will sit for 95% of the winter @ about 40 degrees, + or - 20 degrees and driving rain. My car will be stored in my detached garage with no heat. I didn't disconnect anything last winter and I'll not disconnecting anything this coming winter.
The only thing I'll do is, wash and wax the car very good, fill the gas tank and add marine grade Sta-Bil (gets rid of the ethanhol), then cover it with some sort of cover. I do periodically start the car on nice days when I need the garage space for one of my wifes projects.
Good luck with your storage.
Jayhawk500
2010 2SS/RS, Six speed, Rally Yellow w/ Black Painted Stripes, Boston Acoustic Stereo, Polished 20" wheels, Solo Mach X Catback Exhaust, Solo HF Cats, Halltech CAI, Full Dash & Door ABL, ABL Lit Homelink Buttons, HUD Installed, Ride Tunes, Full Electric Passenger Seat, Fbodfather signed, VIN # 4492, PAID OFF!!!
2010 Yellow 2SS/RS with black painted Stripes...$37,000.00; Ride Tones sound system and remote...$ 40.00; Seeing the kids faces (Young and Old) light up and almost wet their pants....Priceless!!!
Jayhawk500 is offline   Reply With Quote
Old 09-24-2010, 04:19 PM   #5
papabearcamaro
Definetly will be covered and Sta-bil will be mixed in with a full tank of gas before it goes in.
Thanks for the suggestions everyone!
Old 09-25-2010, 05:16 PM   #6
mike12345
Drives: 2010 camaro 1LT
you'll need to drive the car at least once a month or put the car up on jackstands/blocks if you dont want flat spots on your tires.
I would just get a set of winter tires and drive the car, sell your winter jalopy.
Its a $30K car not a ZR1.
mike12345 is offline   Reply With Quote
Old 09-25-2010, 05:30 PM   #7
Mach
Mach's Avatar
Drives: White M6 1LT RS
I remember reading the jack stand thing is not a good idea... One member here damaged this struts because they were extended for a prolonged time.
Modern tires dont flat spot that much.. it used to be a problem with older tires.
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done!
Mach is offline   Reply With Quote
Old 09-25-2010, 05:33 PM   #8
myold88
myold88's Avatar
I've always disconnected the battery on my antique cars but its not necessary on a new car. On the type of storage facility your going to use, besides stabilzer put a few dryer-sheets under the hood, in the passenger compartment and trunk to rid off critters. Add a car cover and your good to go in the spring.
Old 09-25-2010, 05:36 PM   #9
SQUALO
Drives: CHEVROLET
That's what I do, put fuel stabalizer, and get a good quality cover. I also use outdoor carpeting, with rubber bottom cut into squares, and place it under the tires, just to keep them off the cement floor.
Here is a link from the Canada section on this topic, and you'll see my pics in post #28
http://www.camaro5.com/forums/showth...storage&page=2
Old 09-25-2010, 06:09 PM   #10
joe h
Drives: victory red 2010 camaro 2ss/rs
Steal wool in the exhaust and air intake is a must.
Add iso heet to the fuel to absorb water. Add stabil, or some other fuel treatment, then fill the tank full.
Then I fill the tires to max pressure. Take a large sheet of plastic, lay it out on the floor along with pieces of carpet, drive over it and then tuck all four sides in the doors, trunk, and under the hood, so none of the edges are touching the ground.
Disconnect and pull the battery.
Since you don't own the building, moth balls are probably out of the question. But I usually usually surround each vehicle with 2-3 boxes worth. Also rat traps along the walls and doorways is a must.
joe h is offline   Reply With Quote
Old 09-25-2010, 06:24 PM   #11
Sc0rPs
Drives: 2010 2LT / RS - 2013 ZL1
No you don't, and they are 25k - 50k cars depending on options & location.
Plus what does the sticker price got to do with anything? It's about what it's worth to YOU.
Now on topic, I would say depending on the length of your winter. If it's just a month or two then you really don't need to do anything.
I have stored cars but not due to winter, the tire warping should not happen unless you have it sitting for like 6 months. I would just recommend visiting your ride once or twice per month, fire it up, let it 'warm up' and drive it around the covered area.... that will do it, can keep an eye on it and of course visiting your baby.
Sc0rPs is offline   Reply With Quote
Old 09-25-2010, 07:42 PM   #12
papabearcamaro
Correct it is not a ZR1 but on the other hand this car was bought to be purly a summer toy. I have no intentions of having the Wisconsin salt eat it up over time.
Have an 09 Dodge Journey for the winter "jalopy".
Old 09-25-2010, 07:48 PM   #13
Sandor
Chevrolet Performance
Sandor's Avatar
Drives: Camaro Chroma
Definitely park it on a plastic sheet; concrete is almost as bad as a dirt floor in terms of allowing moisture to creep through and collect on the underside of your car. I would avoid carpet, there is no reason for it and it will simply hold humidity.
Everything else that people said is great - full tank treated with Sta-bile, wash and wax, lubricate the rubber seals with a good silcone treatment, use a car cover to keep the dust off, tires at max air pressure. To avoid flat spots you just need to move the car a foot forward and a foot back each month and they will not flat spot.
I also recommend getting the car started and up to operating temp once per month to keep things circulating, and cycle your heating and A/C. This is important becuase it will keep the A/C o-rings from drying out and shrinking, and running the heat moves the coolant through the heater core and helps prevent corrosion. Before shutting it down gun the engine to blow out the excess humidity from the exhaust system, then shut her down.
I have been following this winter storage process for over 20 years and have had zero issues.
Sandor is offline   Reply With Quote
Old 09-25-2010, 08:53 PM   #14
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
You're "supposed" to use a battery tender.....
But there's a 15 year old battery in the old '79 that cranks over every spring with no problem. So.......
The Elimination Game: Camaro colors Ant Cosmetics and Lighting Modification Discussions 2739 04-10-2014 10:37 AM
Cold Air Intakes 2010 Camaro Blowout! K&N | AIRAID | SLP | Best Price Guaranteed! PM AutoAgenda V8 Bolt-Ons & Tunes 47 01-12-2011 01:35 PM
A few quick thoughts on the March 16th startup to calm people down... fbodfather 5th Gen Camaro SS LS LT General Discussions 605 02-13-2009 01:29 PM
NEW!! Voice Your MARKETING Suggestions/Input for Focus Group on 2010 Camaro. Mr. Wyndham 5th Gen Camaro SS LS LT General Discussions 114 05-08-2008 10:24 PM
Hey Tag! Have you been trained to draw blood yet? Silverado Off-topic Discussions 16 12-30-2007 10:00 PM
