Old 09-28-2010, 07:21 PM   #1
Speaker
Drives: 2011 black SS/RS, w/ ground effects
installed my flowmasters myself... could have been a mistake
finally got my flowmaster exhaust in the mail today. and i waisted no time. took them straight to my dads garage and installed them myself. sounded good when it was idling but when i drove around the block it was making a horrible creaking noise especially when i went over bumps. this doesnt make sense cuz i torqued the hell out of all the bolts. its also producing an aweful smell. anybody no a quick fix?
Speaker is offline   Reply With Quote
Old 09-28-2010, 10:10 PM   #2
camaro2lt
camaro2lt's Avatar
I have a flowmaster for the v6 it works fine
Old 09-28-2010, 10:13 PM   #3
JJ2010
Drives: 2010 Camaro SS
Man that is strange.....
JJ2010 is offline   Reply With Quote
Old 09-28-2010, 10:15 PM   #4
spoone123
Next is SS camaro.....
spoone123's Avatar
Drives: 2010 Camaro LS, Rally yellow
over torque the bolt?, IDK man you might wanna recheck that. If can't fix go to the pro shop .
Airraid CAI, Havoc Rims, Perreli tires, Remote start
spoone123 is offline   Reply With Quote
Old 09-28-2010, 10:15 PM   #5
daphatgrant
June '10
daphatgrant's Avatar
Drives: '10 2SS/RS RJT
Well I'm not an exhaust expert by any stretch of the imagination but here's a possible guess. Maybe the exhaust or tips is rubbing against the fascia causing the creaking noise as well as the burning smell? Did you check to make sure that nothing was touching after it was off the lift and on the ground?
RJT, 2SS/RS, M6, Black Int, Sunroof.
daphatgrant is offline   Reply With Quote
Old 09-28-2010, 10:15 PM   #6
Havok1327
Havok1327's Avatar
Drives: 2010 Camaro IOM 2SS/RS
Double check your clearances and make sure the exhaust isn't rubbing.
Havok1327 is offline   Reply With Quote
Old 09-28-2010, 10:16 PM   #7
daphatgrant
June '10
Great minds
Old 09-28-2010, 10:17 PM   #8
take it to your local shop and have them check it.
Old 09-28-2010, 10:19 PM   #9
BackinBlackSS/RS
Go Blue!!!!!
BackinBlackSS/RS's Avatar
Drives: 2012 Cruze LT
I would have it welded.
Old 09-28-2010, 11:04 PM   #10
LiquidInfinity
I need a bigger garage
LiquidInfinity's Avatar
Drives: '11 SS;'09 R1;'11 Denali HD; '09 G8
My cat-back occasionally would bounce against the crossmember (being reinstalled in the attached pic, courtesy of: http://www.gmhightechperformance.com/camaro/tech/1009gmhtp_2010_chevrolet_camaro_catalytic_converte rs_headers_intake/photo_19.html):
We just used stainless steel washers to space it out a bit (the kit in this pic came with spacers).
Just another thing that could be causing the sound (or likely will in the future after driving it a bit).
-LI-
LiquidInfinity is offline   Reply With Quote
Old 09-28-2010, 11:46 PM   #11
Entaille
Drives: 2018 Camaro 2SS
Liquid said what I was going to say.
glad the mbrp catback came with a new tunnel brace with more clearance : )
Entaille is offline   Reply With Quote
Old 09-29-2010, 01:17 AM   #12
chazysoccer11
chazysoccer11's Avatar
Drives: 2011 Chevrolet Camaro SS/RS
The awful smell should be the oil burning off from the new exhaust, or if the mufflers are painted the paint will also smell. It's completely normal.
2011 2SS/RS RJT M6.
PCTXHN Ordered 8/4/2010 Built 9/28/2010
chazysoccer11 is offline   Reply With Quote
Old 09-29-2010, 09:41 AM   #13
SchwarzerDrache
No, it is not an SS
SchwarzerDrache's Avatar
Drives: SIM 2LT/RS
My tip was touching the fascia and caused a horrible vibration in the car at idle and really bad drone in the car. Bent the pipe for clearance and all is better now!
BTW...Skip the clamps and get that thing welded. Should only run you arund $60-$100.
SchwarzerDrache is offline   Reply With Quote
Old 09-29-2010, 09:48 AM   #14
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
depending on what style clamp is being used, but
clamps > welds
and i would double check your clearances... you are probably rubbing somewhere
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
danhr is offline   Reply With Quote
Camaro Dove Tail Spoilers Compilation daphatgrant Cosmetics and Lighting Modification Discussions 473 07-11-2025 09:07 PM
2010 CAMARO PRICE COMPLETE LIST -- OPTIONS + ACCESSORIES (MSRP, Invoice, Employee) Embalmer Camaro Price | Ordering | Tracking | Dealers Discussions 366 03-25-2013 12:46 AM
Racing Brake 2 pc Rotors Installed mtcwby Suspension / Brakes / Chassis 36 11-13-2010 05:07 PM
Check Engine light on after ARH and Pipeline CAI installed se7en Tuning / Diagnostics -- engine and transmission 17 03-10-2010 08:06 AM
Quick Repost... are 21"s ONLY dealer installed? Rocky918 Camaro Price | Ordering | Tracking | Dealers Discussions 2 06-17-2009 12:34 AM
